Old 03-28-2017, 11:12 AM   #43
Originally Posted by billwot View Post
Yup!
OK, so, if you had a FR-S fuel pump (pumping fuel out), in the tank, with 12 gallons of gasoline, how long would it take to raise the temperature of the gasoline 1.0 degree C ......
Old 03-28-2017, 11:18 AM   #44
...Note the keyword in my previous statement was "measurable", maybe I should have used "significant" ...
Sounds like we are saying the same thing, it "could" but unlikely it "will", at least not enough to make a difference to either the fuel or the pump.
humfrz (03-28-2017)
Old 03-28-2017, 12:10 PM   #45
Yep, now I can focus on the more important things in life ....... what should I put on my oatmeal this morning ..... dates, wheat germ or malted milk ......
Old 03-28-2017, 12:44 PM   #46
Yep, now I can focus on the more important things in life ....... what should I put on my oatmeal this morning ..... dates, wheat germ or malted milk ...... humfrz
I would go with a little butter, flour, brown sugar, raisins, maybe a little cinnamon, and a few chocolate chips, then bake for 8 to 10 minutes...
humfrz (03-28-2017)
Old 03-28-2017, 03:09 PM   #47
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
The answer is: Imhotep is invisible, and the train will arrive in Nova Scotia in 27 hours.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Tcoat (03-28-2017)
Old 03-28-2017, 03:25 PM   #48
No no no you screwed up the calculation. You divided by the watermelon and dropped the aardvark.
Overdrive (03-28-2017)
Old 03-28-2017, 03:31 PM   #49
Overdrive
Sittin' Sideways
Overdrive's Avatar
Wait, what aardvark? I was using Mr. Lahey as an exponent and assuming a frictionless surface due to a supersaturation of Crisco.
-O/D
2016 FR-S, Hot Lava
Tcoat (03-28-2017)
Old 03-28-2017, 03:50 PM   #50
I'll tend to you guys ....... after ma nap ....... ZZZZZZZZZZ
Old 03-28-2017, 03:53 PM   #51
reeves
Originally Posted by FR-Sky View Post
When the light comes on, I think you have about 1.5 gallon left.
But I think you should fill your car when 1/5 left becus it is bad for your fuel pump if you drive low on gas.
Not sure how accurate Torque App is, but it always indicates 2.4 gallons left every time the fuel light comes on. And that light's come at least a dozen times for me.. it's always at 2.4 gallons.
So you can go 60 miles at least on the highway if you drive conservatively (using 93 octane). I've driven 62 miles once after the light came on.. cruising at 65-70mph. And still had 0.5 gallons left (again, according to the Torque app). Wasn't trying to get myself stranded on the side of the road or anything, just wanted to run the tank as empty as possible before filling up with E85.
Old 03-28-2017, 04:00 PM   #52
Dude you need to draw it out!
Dadhawk (03-28-2017), humfrz (03-28-2017), Overdrive (03-28-2017)
Old 03-28-2017, 04:03 PM   #53
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
[QUOTE=Dadhawk;2880650
As long as the temp of the device remains warmer than the space around it heat will dissipate in order to equalize it.
[/QUOTE]
...and the rate of heat transfer is directly proportional to the delta T between the 2 entities. So any heat added to the fuel will slow that rate at which the pump can give up its heat to the fuel.
billwot is offline   Reply With Quote
The Following User Says Thank You to billwot For This Useful Post:
Old 03-28-2017, 04:04 PM   #54
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I wouldn't risk it to that situation lol. I usually fill it up when 1/5 to prevent fuel pump damage.
Also, I have been using E85 for almost a year, E85 run faster than you think if it is low, so be careful.
FR-Sky is offline   Reply With Quote
Old 03-28-2017, 04:14 PM   #55
Ya. Not a hope in hell I would do my normal habits on E85. I would also need to fuel up every day though so it would be a pain.
Old 03-28-2017, 04:34 PM   #56
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I once had a problem with constipation but managed to draw it out with a pencil.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Tcoat (03-28-2017)
Easy way to empty your catch can...maybe BirdTRD DIY (Do-It-Yourself) Guides 7 04-15-2016 08:18 PM
Does anybody know any empty fields in LA? Tofu-86 Southern California 2 09-13-2015 12:06 AM
OFT Tuner Help, Empty Zip Files? mopar591 Software Tuning 7 03-24-2015 01:57 PM
big empty parking lots andrew5826 BRZ Photos, Videos, Wallpapers, Gallery Forum 11 02-20-2014 11:39 AM
empty parking lots Tt3Sheppard New England 10 09-04-2012 11:36 AM
