Old 08-14-2015, 01:11 PM   #29
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by fika84 View Post
That's a nice surprise! My understanding is that none of the lexus rear ends are clutch type. Where did you read/see that they were?
You're boosted though right? So are you just going to bolt up this rear and for the longer gears?
Yes I wanted a longer gear as I am turning up the boost and turbo size, longer gears mean more time in boost. I was just searching around some where it mentioned a clutch type but you never know if you can trust what people write. Exactly why I opened this diff to confirm.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
fika84 (08-14-2015)
Old 08-14-2015, 03:51 PM   #30
fika84
fika84's Avatar
Nice! I also bought a used IS300 carrier, but just for the carrier to put a new diff and fd into so my car wasn't out of commission I'm selling the 3.909 that I took out of it. Good times! I love reading your build thread btw, you make some awesome stuff!
fika84 is offline   Reply With Quote
The Following User Says Thank You to fika84 For This Useful Post:
mrk1 (08-14-2015)
Old 08-14-2015, 03:57 PM   #31
mrk1
Thanks, I saw your for sale thread right after ordering this diff. I would have bought those from you other wise haha. Looks like my impulsive habits actually paid off this time.
The Build Thread
fika84 (08-14-2015)
Old 08-14-2015, 05:01 PM   #32
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I have an M85 in my car. It was a direct swap from the Y38.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
fika84 (08-14-2015)
Old 12-14-2016, 01:00 PM   #33
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
is the IS250 the same carrier?
B T is offline   Reply With Quote
Old 03-02-2017, 10:09 PM   #34
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Yes, but different internals (no LSD).
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following User Says Thank You to Jeff Lange For This Useful Post:
B T (03-07-2017)
Old 03-27-2017, 07:14 PM   #35
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
I am building my motor and running E85 this year on my turbo FRS so I would like to do this differential swap. However, I am having a heck of a time finding a M85 3.73 differential.
Is it possible to just swap the ring and pinion from Lexus into the stock FRS differential? The ring and pinion can be puchased brand new if needs be: https://www.lexuspartsnow.com/parts/...201-80781.html
STR also-ran
TRACE_on is offline   Reply With Quote
Old 03-27-2017, 08:33 PM   #36
mrk1
Sure you can buy new, 3.73 ring and pinion also came in MK3 Supra.
The Build Thread
TRACE_on (03-27-2017)
Old 03-27-2017, 09:44 PM   #37
TRACE_on
TRACE_on's Avatar
Sweet, are there any other pieces that are needed for a swap other than the ring and pinion? I am assuming that most people are doing this for the 3.73 instead of the stock 4.10, not because the M85 diff is stronger than the stock FRS diff.
STR also-ran
Old 03-28-2017, 01:19 PM   #38
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
You can also look at aftermarket ring and pinion gears that were made for toyota trucks but fit the IS250/300/FRS/BRZ carrier and diff without problems. I built a pumpkin with new gears and OS Giken diff using a IS250 casing with gears from https://www.nitro-gear.com/category-s/594.htm
There are plenty of parts required with a ring and pinion swap, namely:
- new crush spacer between pinion bearings
- new set of shims for pinion depth
- new shims for differential side bearings
- new pinion shaft seal (very difficult to remove pinion without damaging this seal)
- if using the Nitro ring and pinion, then a new pinion yoke (nitro pinions have a different spline on yoke attachment)
- no matter where gears are from, getting the pinion bearings on and off to set pinion depth and preload is a pain in the a$$ and inevitably destroys one or more. So i would say 2 sets of bearings
not expensive, just a lot of things to keep in mind, maybe it would be easier to buy a low mileage M85
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
The Following 4 Users Say Thank You to 200hp/tonne For This Useful Post:
mrk1 (03-28-2017), Rybot (03-14-2019), Teseo (03-28-2017), TRACE_on (03-28-2017)
Old 03-28-2017, 05:07 PM   #39
TRACE_on
TRACE_on's Avatar
Thank you for all the info. I think you are right, it would be a lot easier to find a good-condition M85 diff. If that doesn't play out I will look at the other options.
STR also-ran
Old 03-28-2017, 08:28 PM   #40
mrk1
Right
The Build Thread
FBM 8.8 IRS Rear Diff Conversion FullBlown Forced Induction 133 12-26-2015 10:35 AM
Rear Suspension Video (Look at diff bushings!) d1ck Tracking / Autocross / HPDE / Drifting 0 07-01-2013 10:02 PM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 10:23 PM
T1R Rear Diff colars ! AJ PwR Engine, Exhaust, Transmission 0 10-09-2012 10:00 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 03:28 PM
