Old 03-26-2017, 09:49 PM   #15345
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by 15limited View Post
Cool man, iv hears great things about RCE products. What class are you running for AUTOX? Did you do STX previously?
Yes, STX. I've run Tein SRC the last two years with some success, but need to make some changes... and think they're slightly less well suited to the direction I'll be trying. So, time for a swap. Same reason I'm doing the alignments - I (theoretically) want to be able to do small tweaks between events based on data. Or big tweaks...
If nothing else, I have a codriver for one club this season - my goal is to put him in the top 5 on PAX (tough for an STX car) and be competitive with his times by the end of the year. He was 13th last year (I was 19th) so... goals. Should be an interesting season.
C
Old 03-26-2017, 09:54 PM   #15346
15limited
15limited's Avatar
C
Is there a tire limitation for the class? What kind of data do you collect besides lap times? Best of luck with your season! Do you have a thread to follow your changes/observations that kind of stuff?
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 03-26-2017, 10:25 PM   #15347
cjd
cjd's Avatar
Drives: 2017 BRZ
Yeah, 200tw on the tires, wider than fit properly (265 max?) and all sorts of fun stuff. No thread, but enough people have asked I'll be starting to collect notes/data on a website soonish.
Data collection includes Harry's laptimer, tire pressure gauge and pyrometer, and the finely tuned butt-dyno...
Old 03-26-2017, 10:28 PM   #15348
15limited
15limited's Avatar
It would be great to follow your progress in hopes for understanding more about suspension setup and tuning. What tires and wheels will you be running?
Old 03-26-2017, 10:34 PM   #15349
cjd
cjd's Avatar
Drives: 2017 BRZ
Check the right forum... So much information already here.
Starting the season on 245/40/17 RE71R on 17x9+35 Wedsport TC105N...
Old 03-26-2017, 10:58 PM   #15350
Yal
#subaruambassador
Yal's Avatar
Drives: Wheezy
Berk muffler delete. Let the beast be heard.
Yal is offline   Reply With Quote
Old 03-27-2017, 09:52 AM   #15351
trd87t
Drives: Supra, BRZ
Did the hail damage mod last night. woot!
1997 Toyota Supra TT 6MT - RR
2014 Subaru BRZ Limited 6MT - WRB
trd87t is offline   Reply With Quote
Old 03-27-2017, 10:19 AM   #15352
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
drove mine to work because I gets ish DONE!
Old 03-27-2017, 10:30 AM   #15353
bababooey
Drives: BRZ SWP Limited -6MT
boo! @mothernature
bababooey is offline   Reply With Quote
Old 03-27-2017, 11:29 AM   #15354
EnoOnraefi
EnoOnraefi's Avatar
Drives: MY17 Asphalt 86
I hear ya there. I was driving a Maxima last year when the "Goliath Hail" in Wylie demolished it... but that's the catalyst that got me on the road to my new 86! So, it wasn't all bad. Best of luck to you. How did the house make it out?
EnoOnraefi is offline   Reply With Quote
Old 03-27-2017, 12:22 PM   #15355
tacos
Drives: 09 impreza, 01 crv, 17 brz PP
just think of it as increased aerodynamics. like a golf ball. or the underside of a cadillac.
tacos is offline   Reply With Quote
Old 03-27-2017, 01:22 PM   #15356
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Originally Posted by Somerandom18 View Post
Yep, just take apart and clean.
I've got something similar on my bike. They are great tbh.
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Somerandom18 (03-27-2017)
Old 03-27-2017, 02:14 PM   #15357
trd87t
Drives: Supra, BRZ
Well, some good came out of it then!
House is fine. Even my daughter's playhouse in the backyard didn't get hurt (besides getting marked up) and it has thin wood for a roof. Shed is fine too.
So i'm assuming that the main house is fine since the roof has way way thicker wood than my shed or playhouse. And I can't visually see anything wrong
Old 03-27-2017, 02:15 PM   #15358
tacos
installed the Rexing v1p dashcam
