Old 03-26-2017, 12:33 AM   #1
trex510
trex
Drives: brz
brake calliper painting
I was wondering if I could just paint the calliper with it still on instead of taking the calliper off to paint it. I am just worried that there might be stuff happening if I accidentally get paint into some parts. Is that possible or do I really have to take the whole calliper off in order to paint it? I tried looking for videos on how to take the callipers off. The only thing about that is that I am just scared that I'm going to mess up while putting it back on.
trex510 is offline   Reply With Quote
Old 03-26-2017, 12:59 AM   #2
tomm.brz
Drives: brz 2017 hksv2
just do it, I did this yesterday, with the calipers on
Old 03-26-2017, 12:59 AM   #3
Learning how to properly (remove, disassemble, reassemble, install, bleed) your calipers is way more important than painting them.
A clean set of OEM calipers is much classier than painting them in a vain attempt at disguising them. Everybody knows. At best it looks immature and cheap. It goes downhill from there.
Tcoat (03-26-2017)
Old 03-26-2017, 03:05 AM   #4
trex510
trex
Drives: brz
did you mask any parts of the callipers?
Old 03-26-2017, 03:05 AM   #5
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Sure looks easy to me.
The brake caliper support (metal bracket) can be painted off the car...just two bolts to remove.
Brake caliper itself can be painted, loose, but still with brake hose attached, on car.
You just don't want paint on the brake pads, brake caliper piston area, or any rubber parts.
If you want paint to stick, must wash, scrub, and rinse, dry all metal parts before any paint application.
Reinstalling calipers over brake pads may require pinching slightly (retracting) caliper piston with large channel lock pliers, or similar tool. Rear brake piston must be twisted clockwise to get it to retract. Generic pics here:
https://www.google.com/search?site=&...akes&*&imgrc=_
Worth any and all effort, as you'll certainly learn in the process.
Caliper and Caliper support >how to< removal here:
[ame="https://www.youtube.com/watch?v=s8P5TSadb_w"]How to replace front brake pads and disc rotors on SCION FRS FR-S SUBARU BRZ - YouTube[/ame]
ToySub1946 is offline   Reply With Quote
Old 03-26-2017, 04:26 AM   #6
tomm.brz
Just a bit near the hub and the disk, then i just painted patiently with a small brush
of course they need to be cleaned very well
Old 03-26-2017, 05:49 AM   #7
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Oh dear...
Scrappydoo is offline   Reply With Quote
Old 03-26-2017, 07:19 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It's not a problem painting them on the car. You don't have to remove them or anything. If you spray paint them, tape everything off. I used a kit with a brush so I had to do very little taping. If you get any paint on your rotor, it'll get scrubbed off after your first drive.
guybo is offline   Reply With Quote
Old 03-26-2017, 10:05 AM   #9
Ernest72
First of all it looks fine for a daily driven car. Color choice is key. Is it cheap sure, but for daily driving the Brembos or other BBK offer nothing but looks at a huge cost.
Besides the stock brakes are pretty good anyway.
Old 03-26-2017, 10:12 AM   #10
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
I left mine on and brushed them.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 03-26-2017, 10:31 AM   #11
Last Lemming Alive
Drives: WRB 2017 BRZ Limited w/ PP
Painting stock calipers just reinforces you have typical calipers. But hey it's your car, do what you want.
Last Lemming Alive is offline   Reply With Quote
The Following User Says Thank You to Last Lemming Alive For This Useful Post:
JD001 (03-26-2017)
Old 03-26-2017, 11:00 AM   #12
EnoOnraefi
EnoOnraefi's Avatar
Drives: MY17 Asphalt 86
If you want the big brake look without doing it right you might as well just go ahead and go all the way. Why stop at paintinting? Just get you some of these.... Brembo Covers
EnoOnraefi is offline   Reply With Quote
Old 03-26-2017, 03:05 PM   #13
Gunman
Drives: 2019 Mazda Miata RF
Who said the op was trying to make it look like the car has a big brake kit?
You can't just make something look better anymore? and the owners opinion of what looks better, is the only one that matters.
The Following 5 Users Say Thank You to Gunman For This Useful Post:
FT86Z (05-08-2018), guybo (03-26-2017), Is Always Angry (03-26-2017), Keenercarguy (06-10-2017), stevesnj (08-12-2017)
Old 03-26-2017, 03:29 PM   #14
Last Lemming Alive
You are right, however if you stick it up for public viewing you have to accept the fact that people will voice their opinion - rightly or wrongly.
callipers, diy, paint
DIY Brake Caliper Painting post_break DIY (Do-It-Yourself) Guides 18 07-20-2018 12:54 PM
Brake Caliper Painting Frishkorn DIY (Do-It-Yourself) Guides 4 09-29-2014 06:50 PM
Autobody Shop/Painting Near Me ? Issue with Painting Carbon Fiber Hood? ScionFR-S Cosmetic Modification (Interior/Exterior/Lighting) 20 11-08-2013 01:51 PM
Painting the Brake Calipers Wasta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-26-2013 08:12 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
