go_a_way1, MisterSheep
Old 03-22-2017, 07:36 PM   #16045
Ashikabi
Ashikabi's Avatar
Originally Posted by arxm View Post
@Ashikabi and @humfrz I had my grandpa take a look at it (he's a mechanic) and he says its my clutch, i guess i notice it now too cuz if i don't rev match perfectly when i downshift i can feel the car lurch a split second after i release the pedal as if its slipping before it catches and spins the engine up, new clutch will be in shortly and if anyone wants i can do a quick write up of it (Excedy oem) and compare it to the stock clutch, i guess the previous owner couldn't drive stick very well, ill use this as a good time to change my trans and diff fluid, thanks for the help guys
Suggest you replace the shift fork and pivot with Velox's billet options while you are at it
The Following 3 Users Say Thank You to Ashikabi For This Useful Post:
arxm (03-22-2017), Clipdat (03-22-2017), johan (03-23-2017)
Old 03-22-2017, 08:28 PM   #16046
Grandpas know best ......
arxm (03-22-2017)
Old 03-22-2017, 08:44 PM   #16047
arxm
Drives: 2013 FR-S, 2023 BRZ
what are the advantages, do you have it installed?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 03-22-2017, 09:03 PM   #16048
Ashikabi
Ashikabi's Avatar
I don't have one but I have kept an eye on development and reviews. The stock fork is a stamped thin piece of steel. Velox is billet aluminum. Much stiffer as the stock one bends under load. Users are claiming far superior clutch feel and engagement over stock. The pivot is cheap. Not a big fail item but for 15$ or whatever it's silly not to swap it IMO. There is a big thread on the forum for the fork you can look at yourself to read reviews and such.
Old 03-22-2017, 09:26 PM   #16049
Apex-Apex
Apex-Apex's Avatar
Unpack the Varis!
Varis 2JZ Build Thread
IG: @apexapexapex
Apex-Apex is offline   Reply With Quote
The Following 8 Users Say Thank You to Apex-Apex For This Useful Post:
dhuang (03-23-2017), FujiwaraTofu86 (03-24-2017), MisterSheep (03-29-2017), MJones_RB (03-23-2017), Nsot (03-23-2017), Overdrive (03-23-2017), Senoko (03-23-2017), zeal86 (03-22-2017)
Old 03-22-2017, 09:37 PM   #16050
zeal86
zeal86's Avatar
Drives:
Today I wrapped my rear seat delete center channel. I am almost complete with my RSD! I still need to install some more velcro on the underside of the center channel and repaint and rivet the hinge. Then I have the seat back panel door to upholster. That one will be tricky because I want both sides to be upholstered as clean as possible.
Check out my build thread to see more... link in sig.
I will use this as a pull handle...
And these to secure the door...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
Old 03-22-2017, 09:38 PM   #16051
arxm
ahh i see i don't think i can justify spending 170 for that just yet, but ill definitely think about it for the future
Old 03-23-2017, 12:17 PM   #16052
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Actually occurred yesterday, but took my boss for a ride on our way to a facility inspection, and his first question about 14 seconds in was, "So, what made you want to get this car?" While I proceeded to explain in some detail, in my mind I was just immediately like:
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following 4 Users Say Thank You to Overdrive For This Useful Post:
Lorico (03-24-2017), OrangeGuitar (03-23-2017), Quentin (03-23-2017), trvth (03-28-2017)
Old 03-23-2017, 01:40 PM   #16053
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
I have been in the newspaper business for a long time. Years ago there was an older guy who reviewed cars. he would have a new car at the paper all the time and I would talk to him about them. I gathered from my conversations that he related the size of the car to the value of it. He liked large luxurious cars and thought you weren't getting your money's worth with a small car. I thought How narrow minded especially for someone reviewing cars.
fx1mark is offline   Reply With Quote
Old 03-23-2017, 01:50 PM   #16054
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
You either get it or don't get it, in this life their are "Drivers" and people that merely think of a car as an appliance or status symbol.
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
The Following User Says Thank You to wrh3 For This Useful Post:
ToySub1946 (03-23-2017)
Old 03-23-2017, 02:13 PM   #16055
Datcrazyeric
gotta go slower
Drives: 2014 FR-S
Took a nap in my car and reserved the 860 in Halo when it comes in.
"While you have to push it to be fast, it always wants to be pushed, abused even. It can live at those high RPMs just fine. Zero to 60 mph arrives in who gives a shit."
Datcrazyeric is offline   Reply With Quote
Old 03-23-2017, 06:29 PM   #16056
TougeFT86
Drives: 2014 Argento Monogram
Got my Monster sport shift knob in today. Was cheaper to order direct from Japan than it was to order from 86worx or Amazon, and only 5 days.
TougeFT86 is offline   Reply With Quote
Old 03-23-2017, 08:04 PM   #16057
Pbrown
Drives: 2013 Scion FRS Raven
Geeezuz this is a tough time of year.
After 4 months of hibernation my new daily routine is: check outside for conditions check the weather network, leave house through the garage where I swear the little black silhouette starts to speak----- " pssst. Hey! Go ahead. Fire me up. I know you want too. Roads aren't to bad. Just a little warm up. C.mon. Feed your soul." Sigh !!! Tomorrow---- repeat routine.
Pbrown is offline   Reply With Quote
The Following User Says Thank You to Pbrown For This Useful Post:
Old 03-23-2017, 08:57 PM   #16058
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Late post but finally got the cracked weld on my exhaust fixed
