Old 03-20-2017, 10:38 AM   #4565
doctor_driver
Drives: 17' BRZ - PP
Originally Posted by imnotsureaboutbrz View Post
Any pics of the wheel mounted, how much do they poke with the spacers? I haven't much information on wheel figments for the PP cars. I'm planning on going with a different size tire I really like those wheels.
No pics yet, I'll get some good ones when I run an event this weekend with the Gulf Coast Region though!
doctor_driver is offline   Reply With Quote
Old 03-20-2017, 10:39 AM   #4566
doctor_driver
Originally Posted by justinco View Post
Same as any other car for the front bar. I use the common Whiteline 20mm on my 2017 BRZ, used the same one on my 2013 FRS. Brake pads are kind of personal preference. I've used Hawk HPS on both my twins (and other cars) and also like Ferodo which I use on my BMW (DS2500). Good street/autox pads, not great for track (BMW has Hawk DTC60's for track).
EDIT: I should mention that front bar is used for STX classed autocross, but stock class guys use the same thing usually.
Good to hear. Thanks!
Old 03-22-2017, 02:36 AM   #4567
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by Twinz View Post
Day two was better for the WRX. The launch was long and straight so they probably started 3-5 tenths ahead of the pack.
Ugh I hate when they do that. There are actual rules that prohibit launch starts that would give an unfair advantage and I believe you can bring them up prior to competition.
That's my major concern going to DS is that we'll just be way too underpowered for most of the national level course designs.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 03-22-2017, 12:09 PM   #4568
renfield90
The Stig's German cousin
Yup. The January or February fastrack addressed how to protest course design, you need to file the protest within a certain amount of time after the course is closed for walking before the day's first runs.
Old 03-23-2017, 04:41 PM   #4569
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Originally Posted by Biggins View Post
It looks like you coned your fast run today but still held on?
-Just realized I forgot to reply to this question...
My first run was a decent clean run as planned, but I screwed up my second run at the launch when I somehow kicked her a little sideways whilst launching in a straight line. I had to lift off the throttle to get the back end to miss hitting the staging cone. Solo Storm says I was down 4 tenths before I even got to the first element.
Buy the time I got to my third run, my primary competition had used up all their runs and I was still holding a slim lead. So, for my third run, I basically decided to see how fast I could get the car around the course with a high-risk run. The time was nice, but I also picked up two cones.
FWIW Ricky Crow made a high-risk run work, on his last run, after he had coned himself out of the trophies with his first two runs. He probably could have got himself into contingency with a solid "safe" run, but he apparently decided he was going to win or go home empty handed. I saw workers going out to recenter cones after that run, but he was clean and the time was just enough to get him the win. That two day STR battle between him and David Marcus was impressive.
Twinz is offline   Reply With Quote
Old 03-27-2017, 03:53 PM   #4570
TMF
TMF's Avatar
Drives: '14 FRS TT5
I'm probably opening a can of worms here...but...does anyone have the cam plate leak? And if so, what have you done to resolve the leak?
Using RTV to create a new gasket seems like it doesn't fix the issue all the time. ( http://www.ft86club.com/forums/showthread.php?t=53949 ) There are some aftermarket plates that use an o-ring (instead of having to make a gasket: http://www.ft86club.com/forums/showthread.php?t=46520 ). Not sure if the aftermarket plate would be illegal or if it would be legal under this provision from the rules:
"All repairs must comply with factory-authorized methods and procedures,
or industry standard methods, as follows: If the OEM does not provide an appropriate
method of repair, industry standard methods and procedures may
be used. Such repairs may not result in a part or combination of parts that
provides a competitive advantage (e.g., significant change to weight, suspension
control, power, etc.) as compared to the standard part(s). Competitors
are strongly cautioned to use this allowance to make common-sense repairs
only"
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 03-28-2017, 12:57 AM   #4571
renfield90
method of repair
only"
The bolded parts are your problem.
One, the OEM does provide an appropriate procedure for the problem. Just because it's not always successful doesn't mean it isn't appropriate; if you can't convince a PC otherwise (and I really doubt you can), the part is illegal regardless of the rest of the clause.
Two, most of these plates are probably lighter. The question is what "significant" means. You are probably not going to like the PC's answer.
Now, in practical terms: for your local lot, probably no one will care. It will help your case if you at least try RTV first. At a national event, but you're outside the trophies: again, probably no one will care, and I will help you make fun of the sorry SOB that protests you so he can be slightly less mid-pack than he is. At a national event and you're in the trophies: protest bait, and they're in plain sight.
Old 03-28-2017, 11:03 AM   #4572
TMF
TMF's Avatar
Drives: '14 FRS TT5
Fair enough, I completely agree with your sentiments.
I was able to find a local that had the leak successfully fixed by a local dealer. Since my car is still under warranty (which is half the reason why I bought a newer frs) and that repair would be free, I'm going to go that route and hope it fixes the issue.
Thank you for your feedback.
Old 04-02-2017, 04:40 PM   #4573
doctor_driver
So I finally got to do an event on the Rival S 1.5 (245/40/17) in my 17 BRZ - PP. Felt like I was having a lot of understeer in the bigger sweeping turns. Only other thing I have on the car is a Sped-D Tuning catback.
Any thoughts on the understeer issue? Was running 30 psi (cold) all the way around and it didnt look like the sidewall was collapsing at all. Wear was right on the markers perfectly.
Old 04-02-2017, 05:41 PM   #4574
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Where in the corner was the push? Entry, mid, exit?
You probably want to max out front camber w/ the crash bolts if you have not already. Adding more air to the rear tires might help too. A little of a push is not necessarily a bad thing, assuming the car will rotate/turn when you lift or brake.
justinco is offline   Reply With Quote
Old 04-05-2017, 02:41 PM   #4575
doctor_driver
Push was worst during mid turn and exit. It might be a while til I can get the front camper maxed out (in medical school and am about to go in lock down modes prepping for boards on June 10th). But I'll try that out as soon as I can.
Old 04-05-2017, 04:12 PM   #4576
TMF
TMF's Avatar
Drives: '14 FRS TT5
I actually have the opposite issue with my FRS...understeer on entry (but mainly only when I come in too fast), and oversteer on corner exit, sometimes mid-turn. Granted that is with the TRD springs, koni's, and TRD sway bars, so my setup is very different.
I'd check:
1. Alignment, specifically getting as much negative camber in front by using the OEM crash bolts (you can search for the part number and find it easily). If you still don't get enough rotation, then you can start experimenting with some toe-out. I personally always run 0 toe, but a small bit of toe-out (I believe in the rear) can help quite a bit.
2. Hot tire pressure (not cold). The 225 RE71's seem to like low 30's psi in the front, high 20's PSI in the rear. Might be different for the Rival's, esp in the 245. You generally want to set the tire pressure to maximize grip and not change tire pressure up to alter handling. Using chalk on the sidewalls can help to see how far you are rolling onto the sidewalls. Once you get the fronts and rears to roll just to the edge of the sidewall, that should be the right tire pressure. However, since you're limited on adjustments in a stock car, tire pressures can be used to alter handling. Understeer on exit can be helped with higher rear tire pressures.
3. (this should almost be #1) Check the nut behind the wheel. Sometimes it is your driving "style" (or bad habits) that are causing the car to understeer. Asking for advice from a competent local instructor at an event is invaluable. Even the best drivers still take instructors sometimes...you can always learn something from another driver.
4. Consider getting adjustable struts. Adjustable struts give you another dial to adjust how the car is handling. Koni offers a direct replacement (not sure if they have them for the 2017's yet. It's possible they are the same as the 13-16 struts) and they are relatively (to other other aftermarket struts) inexpensive.
5. If the above don't help enough, you could consider swapping out the rear sway bar for a larger one. In general, autox'ers want a bigger front bar to help in quick transitions (at the expense of grip during sweepers), but if you're running a lot of courses with a lot of big sweepers, you might consider a bigger rear bar.
I'd focus on 1, 2, and 3 before dropping money on parts. You will become a better driver if you learn to hone your skills first before trying to learn on a modified car with more knobs to turn.
Others, please feel free to chime in as well!
Old 04-05-2017, 06:56 PM   #4577
dvalue
Drives: 15 BRZ
I was having similar issues until I got the car aligned.
Hop in with me and I'll hop in with you at the next event. We can try some different things.
Delta/CENLA Region SCCA - DS
dvalue is offline   Reply With Quote
Old 04-05-2017, 07:19 PM   #4578
CCJ
I'd check:
Both bars? That might be your problem. I tried one event last year, same setup as you (springs, both bars, konis) and it was a mess. Codriver and I couldn't keep the back end behind us. Went back to stock rear bar and was much better. That or an even bigger front bar might do it.
CCJ is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
