#16017 |
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Plasti-dipped some center caps in preparation for changing out my wheels...
First time I have worked with plasti-dip and it seems very forgiving. Not sure I want to commit to the color, so I thought this would be a good way to test it out prior to powder coating... |
#16018 | ||
#16019 | |
The first thing that I would recommend is that you check the fluid level in the clutch fluid reservoir, if it's low, fill it up (then find out where the fluid went). If it's full, I'd suggest you bleed the hydrolytic clutch system to purge the system of any air. If all that doesn't help, I'd adjust the clutch ..... (have you been messen with the adjustment .. ??) Come back. humfrz |
#16020 | |
Did you oil it ..? Too much oil will gum up the MAF .. ![]() Are you sure you got it in with the correct end up and situated so as the direction of air flow is proper .. ?? Are you sure you got the bottom of the case positioned correctly before snapping the top closed .. ?? Are you sure it's all the way closed .. ?? Did you put the sticker on .. ?? 15 seconds, huh ........ ![]() Are you going out to check it ...... (jest ah messen wich ya) humfrz |
#16021 |
Drives: 2015 Ultramarine FR-S AT
![]() Deleted the 3rd brake light and child seat anchors then covered the shelf in fresh felt. 🏎 Sent from my SAMSUNG-SM-G900A using Tapatalk |
#16022 |
#16023 |
too much is never enough.
Drives: 2015 FR-S RS1.0, 2005 Corolla XRS
While waiting on the bumper cover and front lip to be painted from the racoon damage,
had some time this weekend to install the some parts!!Mishmoto Oil Cooler Greddy Air Intake Snorkel Replaced the damaged Hella Horns Replaced Condenser bug screen Mishmoto Oil Cooler The oil cooler was pretty easy install, fun part was getting the lines in a position they were happy about. Not easy bending braided lines, a lil heat from a heat gun helps. Chose the thermostat sandwich plate at 185/F ![]() ![]() ![]() ![]() ![]() ![]() ![]() Greddy Air Intake Snorkel I cut about an inch off the snorkel so it doesn't hang down so low, to block the oil cooler. left it just low enough to be in position to catch the air flow. ![]() Took some 3/4 in velcro strip and used it as a gasket. The stuff the came with the snorkel was a joke Fits nice and tight for no leaks. Also channeled out the styrofoam bumper cover support for the snorkel ![]() New Condenser screen ![]() Wating for its clothes ![]() damn racoons
Too much is never enough.......
2016 Colorado Z71 Trailboss, 2005 Corolla XRS, 1987 Cavalier RS Wagon ![]() Nanako's Mod Thread |
#16024 |
#16025 | |
Drives: GTS 86 auto
I got the lights module out of the "spaceship", covered it in felt and just pushed it into the crack at the base of the glass. Very stealth. Next time I would try one of those flexible tape-strips of LEDs backed with a black strip of black felt for even more "stealthlinessity".
GTS86 Auto (Australia)
#16026 |
Huge E85 fan!
Drives: 2016 Scion FRS
Radium Engineering adjustable front strut tower bar
#16027 |
Drives: 2015 FR-S
Took a 200 mile joy ride theough the mountains around Massachusetts, New Hampshire, and Vermont. :-D Startin to warm up, hopefully the snow's all done!
![]() Sent from my SM-N920P using Tapatalk |
#16028 |
Huge E85 fan!
#16029 |
Drives: 2015 FR-S
#16030 |
Huge E85 fan!
Just so you feel kind of bad- it's 80 here right now. my biggest weather related problem of the past month has been avoiding a sunburn
![]() Shit that didn't work at all, I really wish I was tearing up Pinkham Notch or driving along Shore Rd between York, ME and Ogunquit.
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
