Old 03-18-2017, 08:05 PM   #57
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
This little sanding stone melted through those plastic rivets in seconds and the light came out clean. Just a suggestion. 😎
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Old 03-21-2017, 02:07 AM   #58
notout86
Drives: GTS 86 auto
Originally Posted by kev60625 View Post
I didn't disconnect my battery...dumb on my part
Use a Stanley knife to cute the shelf trim centrally along a straight line from the rear to the front of the car. SO much easier to fit or remove then and just pull out and push back under the panels.. If the join at the cut bothers you, cover the shelf with black felt.
I have cut my dash-mat too. They always shrink and holes e.g. over the vents near the doors become misaligned. Now it is easy to slide the mat back over the holes from time to time. The centre cut will gap about 30mm eventually so cover with e.g. a strip of felt about 45mm wide.
GTS86 Auto (Australia)
Old 04-09-2018, 11:24 PM   #59
bbalch404
Drives: 2014 Scion FR-S
What are the chances we can get the original first post pictures re-added to this post?
bbalch404 is offline   Reply With Quote
Old 05-01-2018, 03:33 PM   #60
86_dave
86_dave's Avatar
Drives: 2017 GT86 Pro
If you can use Google Chrome, install this extension "Photobucket Hotlink Fix" and it restores the OP to perfectly working images:
https://chrome.google.com/webstore/d...alioapbifiaedg
It's a godsend for viewing the many amazing DIY posts in this forum.
86_dave is offline   Reply With Quote
The Following 4 Users Say Thank You to 86_dave For This Useful Post:
DandoX (05-01-2018), MJones_RB (08-03-2020), sharpsicle (05-03-2018), Tristor (05-27-2018)
Old 05-26-2018, 11:11 PM   #61
MarvinC93
Drives: 2016 Subaru BRZ Limited MT
I just got this out on my 2016 BRZ. At first I thought it was superglued to the entire deck but it’s just a little sticky on the foam pads and around the white pop clip holders. A panel removal tool like the one the OP used really helps. I used it to push one clip out from underneath the deck. I can confirm that it is possible to remove this without removing the C-pillar panels. You just pull the entire deck towards you and up. It might make it a little easier to remove those panels first but not absolutely necessary. After pulling the deck out I see so many areas for potential rattles that I plan to fix with some felt or speaker gasket foam tape, especially where the brake light meets the glass.
MarvinC93 is offline   Reply With Quote
Old 05-27-2018, 09:58 PM   #62
notout86
Drives: GTS 86 auto
Originally Posted by bigdawg86 View Post
I removed my 3rd brake light entirely after I failed to stop the rattling with complete disassembling and adding silicone sealant every friggin part. I reupholstered the deck with foam and vinyl to go over all the holes and to match the car. It looks great. The annoying rattle is reduced 70%, but oddly enough the soft vinyl gives a low grade rattle against the glass now with certain bass notes. I am going to add a small black weather strip between the two and see what happens. These trunk rattles are insane to get rid of completely.
I had what I thought was a trunk rattle/clunking that I could not find. Then I noticed I was only hearing it for a short time after driving off from cold. Now I reckon it is shock absorber valves and as soon as things warm up a little it stops.
Old 09-26-2018, 03:24 PM   #63
606shooter
Drives: 2013 Scion FRS
FRS/BRZ/86 Front Grill Mods with Raptor
Has anyone ever installed the 3 yellow bulb Raptor style lights with their FRS/BRZ/ 86 front grill? Starting to wonder if this would look cool.. I've seen a few examples with the 4Runner mods: http://kustom54lighting.com/Morimoto...ts-_p_334.html
606shooter is offline   Reply With Quote
Old 08-01-2020, 09:48 PM   #64
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Dang. A lot of this was drastically overstated here lol.
You don't need to pull all of the panels to get the trim out. It's actually the four clips in the front and if you lay down and carefully look through some of the trunk holes, you can see the white clips and where they're located on the trim. Pop the light up, pop the trim up, everything comes out super easy.
The center of the plastic welds work like center punches so a half inch drill bit makes super light work of those.
And then putting it back, just make sure the white clips are lined up and straight. Again, you can lay on your back and look through some of the holes to see where the clip is and guide them in that way.
The way this thread was written, I thought this would be a bit of an ordeal. In and out of the car in 20 minutes including the isopropyl wipe down and drilling.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following User Says Thank You to Wally86 For This Useful Post:
Spankopotomous (01-07-2021)
Third brake light out? Longhorn248 BRZ First-Gen (2012+) — General Topics 21 11-23-2015 03:23 PM
How to remove third brake light (to tint back window) 96z2 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-07-2012 04:14 AM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 07:14 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
