Old 11-10-2016, 02:28 PM   #1149
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
Originally Posted by Yoda View Post
I think you need to identify how much risk you are willing to take on. The car does not come FI from the factory nor are you building the engine. If you want the safest possible then you would be at about 250whp according to Cosworth. They did some engine bench testing and concluded that is the safe limit that engine can handle without degrading much. I would have to conclude that above that you are now taking on some risk that goes up as the power level increases. A proper sorted tune mitigates that risk in proportion to how well the tune is.
The reason I say this is because tunes can vary so the mileage you get out of the kit will also vary. Just don't want you to think that just because someone got 80k miles out of the kit that you can just assume you will also get similar results. I have been burned by that logic before on previous projects. Just sharing some knowledge to help you better as many have done for me. So in short focus on the tune, not just any tune, the best tune. I know I didn't answer your question but food for thought.
@kanundrum (E85) @ogrowup (water meth) @MooKz (pump gas only)
Freddy@PTUNING is offline   Reply With Quote
The Following User Says Thank You to Freddy@PTUNING For This Useful Post:
kanundrum (11-10-2016)
Old 11-10-2016, 02:48 PM   #1150
Freddy@PTUNING
Originally Posted by Joe's86 View Post
This might have been posted awhile, but I'm not about to read all the pages again
Anyone pushing 300s on pump and 400s on E85 / WM on a stock motor care to comment how many miles you guys are at now with and without being boosted? . Not that I don't believe freddy, but it's always nice to hear the miles!
Old 11-11-2016, 12:41 PM   #1151
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Always good to be reminded of that. I should have specified further. Same question but add on that the tune was done by ptuning. I will definitely be making my drive out there when I get the kit
If you go with PTuning and you can make the drive to tune there, it will be worth it.
To comment on your other post, I'm not quite at the HP you mentioned, but I trust the tune and my car completely. I'm running about 240whp on a Mustang dyno on 91 octane at 8-9psi and around 280whp on 100 octane 12-14psi.
rb6freak is offline   Reply With Quote
The Following 4 Users Say Thank You to rb6freak For This Useful Post:
Hicklinc (01-29-2018), Joe's86 (11-11-2016), kanundrum (11-13-2016), SkAsphalt (03-20-2017)
Old 11-22-2016, 11:26 AM   #1152
Freddy@PTUNING
Bump for Black Friday specials!
http://www.ft86club.com/forums/showthread.php?t=113048
www.ptuning.com
Old 11-22-2016, 07:33 PM   #1153
Blizzz
PTuning was one of the best shops that I've been to with regards to quality of work and professionalism. I unfortunately got the unlucky end of the stick when it comes to getting miles out of a boosted setup. I only got 1800 miles or so out of the car on the kit before spinning a bearing (which happened on both the stock and built blocks). Figured I would share. I ended up selling the car because of it. If I could do it all over again, I probably would roll the dice and still do it.
Blizzz is offline   Reply With Quote
The Following 5 Users Say Thank You to Blizzz For This Useful Post:
Freddy@PTUNING (11-23-2016), Hicklinc (01-29-2018), Joe's86 (11-22-2016), kanundrum (11-22-2016), rb6freak (03-21-2017)
Old 11-22-2016, 09:37 PM   #1154
kanundrum
Drives: 2013 Whiteout FR-S
So to share some of my story
May of 2012: Got Car, put 900 miles on it in 3 days and dropped it off to Ptuning for Turbo Development. 6 to 9 months later they had a the beta ready and then another 6 to 9 months later the full kit was released. I have had their kit off and on the car since the first few thousand miles and then permanently on (production version) at 8,000 miles with most of its earlier life spent on the dyno.
Car is somewhere near 40k miles now and still running strong at 400whp (detuned when 93 octane is put in) and while I sold it to get something a bit fancier and more family friendly(needed a 4 door that could carry a potential kid) I miss the vehicle every day and I am in contact with the owner who also has another ptuning turbo setup FRS (Yes he loves Ptuning so much he has 2 FRS's with 2 ptuning turbo kits) who tells me how flawless it is running.
TLDR: I Trust only them to touch and modify my vehicles.
The Following 3 Users Say Thank You to kanundrum For This Useful Post:
Freddy@PTUNING (11-23-2016), Joe's86 (01-19-2017), rb6freak (03-21-2017)
Old 03-17-2017, 03:45 PM   #1155
Rougenite
Drives: Raven FR-S
Any of you guys have the Mishi Rad and shroud combo? If so...did the Ptuning stuff all fit in with no modifications?
I am kinda worried the IC and piping is going to be the problem area for me.
Rougenite is offline   Reply With Quote
Old 03-17-2017, 04:04 PM   #1156
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Run the koyo radiator with stock fans. hard to beat the flow and reliability of stock fans.
Mrc@ptuning is offline   Reply With Quote
Old 03-17-2017, 04:21 PM   #1157
Rougenite
Drives: Raven FR-S
Already got the Mishi rad. . Dont have the shroud yet, but its thinner and the CFM was supposed to be more. Might sell the Mishi, but hard to beat that lifetime!
New build path means selling everything else off anyway!
Package deal!
Old 03-17-2017, 04:45 PM   #1158
mkivsoopra
Package deal!
+1 on Koyo with stock fans. I would even say use the stock radiator, unless you're pushing lots of power and pushing very hard at the track. We used to track in 100F+ weather with no problems, using the stock radiator, good oil cooler, good air flow, and 300+ whp.
mkivsoopra is offline   Reply With Quote
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
Hicklinc (01-29-2018), rb6freak (03-21-2017)
Old 03-18-2017, 01:46 AM   #1159
kanundrum
Package deal!
Sell Mishi, best move you will ever make.
Old 03-18-2017, 09:50 PM   #1160
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
*whiny voice* any luck w that automatic setup?
i love my auto but I am having an existential crisis because no ptuning turbo for it Q.Q
nos145 is offline   Reply With Quote
Old 03-19-2017, 02:22 PM   #1161
Silent_Dan
Drives: 2013 Scion FRS
As an automatic owner also I wish to have a p-tuning turbo on my car also but I don't see it happening though .
Please reconsider making a kit for the auto owners.
Silent_Dan is offline   Reply With Quote
Old 03-20-2017, 09:41 AM   #1162
ptuning
ptuning's Avatar
Drives: White FR-S
Due to the much larger transmission housing on the automatic, our low mount turbo setup would have to be completely re-design. Unfortunately, we currently are not looking to release a kit for the automatic. We made revisit this in the near future. If we decide to develop a kit for the automatic, we will definitely announce it way in advance.
Thanks again for your interest in the PTUNING turbo kit.
Regards,
Mike @ PTUNING
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
