Old 03-16-2017, 10:18 AM   #15
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Thinking about adding on a short shifter and shifter springs while they are in there.
B-R-Z is offline   Reply With Quote
Old 03-16-2017, 10:21 AM   #16
jasonojordan
Drives: 2013 satin white brz limited
These don't really have much to do with a clutch job and is quite easy to do yourself. Just an option.
jasonojordan is offline   Reply With Quote
Old 03-16-2017, 10:22 AM   #17
I just emailed them for a copy of the quote and I guess I heard wrong. Quote is $1143! Sold
That is right bang on what I would expect. Enjoy the new clutch!
Oh and see if you can get a new fork as well. Would be worth the extra money.
Old 03-16-2017, 10:39 AM   #18
StraightOuttaCanadaEh
Wes
That's what I love about this car. Maintenance is very reasonable. Changing the clutch and flywheel on my cooper s took 14 hours of labour cause they had to take the front suspension out or something, cause that's just how it's engineered. Paid about $3500 in the end
Old 03-16-2017, 10:42 AM   #19
jasonojordan
Ow my butthole.
Old 03-16-2017, 11:28 AM   #20
Originally Posted by jasonojordan View Post
I guess I need to read more threads then because I have only heard of 6 instances or so since being on here.
http://www.ft86club.com/forums/showt...40#post2873340
jasonojordan (03-16-2017), Zentec (09-08-2017)
Old 03-16-2017, 11:39 AM   #21
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
My TOB gave out a few thousand miles ago, but the only sound it would make is when the clutch pedal was not engaged. As soon as I stepped on it, the sound would stop. Not very consistent with your issue, I know, but I'm not a car expert anyway.
carsebuco is offline   Reply With Quote
Old 03-16-2017, 12:41 PM   #22
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Mine really started to go bad after 60k miles, for yours to last past 100k is incredible!
I paid about ~$1,100 for my clutch replacement & install, and that is at the "friend" rate. Granted, my replacement clutch kit was ~$550, so getting the labor done at $600-700 would be a good price.
dhuang is offline   Reply With Quote
Old 03-16-2017, 02:09 PM   #23
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I've had a throwout bearing issue 3x with my car. First time was the OE making depressing the clutch heavier than it really was. It didn't damage anything, and I only found out after I upgraded the clutch. The other two times were because the TOB that came with my south bend clutch was faulty and caused damage to the input shaft. So yeah...
MS, CSCS, TSAC-F, CPT
Old 05-30-2017, 07:37 PM   #24
Mchilese
Mchilese's Avatar
Drives: '14 BRZ Limited
Thought my synchros were going bad, so I took it into the dealer. The tech and I were able to replicate the problem I'd been having. He and the foreman diagnosed it further to be the TOB.
They said it was covered under warranty, and should be ready tomorrow. Why was it costing you guys over $1k?
Mchilese is offline   Reply With Quote
Old 05-30-2017, 08:59 PM   #25
B-R-Z
B-R-Z's Avatar
Im no longer under warranty.
Standard labor rates to drop a trans. I paid $1100 which included labor + replacement exedy clutch + mobil1 trans fluid.
Old 05-30-2017, 09:18 PM   #26
Mchilese
Mchilese's Avatar
Roger. That makes sense. I was worried what I was going to find waiting for me when I went to pick the car up tomorrow. lol.
Old 05-30-2017, 09:34 PM   #27
Technically speaking the TOB is a wear item that isn't covered by warranty. Some dealers will cover them and others will not. If yours covers it then you have a good dealer.
Old 05-31-2017, 11:36 AM   #28
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Labor $600-$700 is reasonable i think
Throwout bearing. bdanisi Issues | Warranty | Recalls / TSB 54 07-17-2016 06:13 AM
63,000 and throwout bearing ruined everything riironman Issues | Warranty | Recalls / TSB 188 05-14-2016 11:02 AM
Throwout bearing? RavioliG Issues | Warranty | Recalls / TSB 3 10-31-2015 01:17 PM
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 02:17 AM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 08:08 PM
