Old 03-12-2017, 02:30 PM   #1023
Wondark
Driver
Wondark's Avatar
Drives: MY17 CWP BRZ Limited w/PP
My sales guy said the same thing even tho I told him it had to be enabled. Ended up having issues on some small hills with stop signs driving it home :|
Don't you love how we know more about a car than the dealer does and we don't even own the car yet. We are enthusiast to a degree and you can expect that. I guess it isn't a big deal knowing more than the dealership about a particular car but when you tell them it's off by default and they assume they know better than you it can be a bit insulting.
I asked 3 questions of my salesperson just before I drove the car off the lot.
Q1: Is the car alarm enabled? It is off by default from the factory.
A1: Yes it is enabled from "DPI" that way. It is not "off" by default, we do not sell cars without an alarm being enabled.
Q2: Is hill assist enabled? It also is off by default from the factory.
A2: It is enabled also (with a bit of confused look on his face).
Q3: Is the passenger door lock unlocked when I unlock the driver side door?
A3: You may have to turn that on yourself.
Q4: How do I turn on the dash "gear indicator", it does not appear to be on? I have seen in pictures where the dash has an indicator right in this area.
A4: What? (Fumbles with the buttons on my steering wheel) I dunno.
None of these options were on! Consult the manual if you have questions, the dealership doesn't know this car from his Keurig coffee maker at home. Don't ask me why I know he has one...please.
I'm done with being mad about my dealership and salesperson, just want to make sure everyone figures this stuff out before they are handed .
Wondark is offline   Reply With Quote
Old 03-12-2017, 05:45 PM   #1024
That is 4 questions.
Old 03-12-2017, 06:46 PM   #1025
spike021
spike021's Avatar
I probably missed it in the manual so far but random question: do your guys' windows seem to re-seal to the top or go up a little when you shut the doors?
spike021 is offline   Reply With Quote
Old 03-12-2017, 06:49 PM   #1026
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
Thats normal. Its a function of the frameless windows. I'm sure theres another thread about it somewhere in the forums, but most cars with frameless windows do that little up/down dance.
mjanmohammad is offline   Reply With Quote
Old 03-12-2017, 07:02 PM   #1027
spike021
spike021's Avatar
Ohhh that makes sense. Haha that was a dumb question. Thanks dude.
On my phone now so I'll just search for the post later when I get home.
Old 03-12-2017, 09:17 PM   #1028
Wondark
Driver
Wondark's Avatar
Thanks Tcoat but only put that in there to see if you were watching. I have also hidden messages in my posts but you don't seem to have found them yet.
Old 03-13-2017, 06:35 AM   #1029
Or we need you to think we didn't notice.
Old 03-13-2017, 10:12 PM   #1030
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
My car hit the port today. Oh so close now.
trippinbillies40 is offline   Reply With Quote
Old 03-14-2017, 12:07 PM   #1031
jmark
Drives: '97 NSX-T, '18 Type R
Originally Posted by jmark View Post
Ordered : 1.13.17
Von assigned : 1.17.17
Allocation 201703
(ETA : Month of March)
Vin received : 2.18.17
Estimated arrival : 3.20.17
Anybody looking for a nice 2009 Honda Civic Si Sedan?
Sold the Si Friday 3/10. Car arrived on the truck today 3/14 & picking it up this afternoon.
My 2017 Limited with PP.
jmark is offline   Reply With Quote
Old 03-19-2017, 10:54 PM   #1032
BRZ FAMILY FUN
Drives: 2017 Series Yellow BRZ
Originally Posted by BRZ FAMILY FUN View Post
I'm waiting on a 720 Form GTF1 in a 17X8 and a 17X9 both +35 offset to test fit. They weigh 15.5 Lbs. and 16.8 Lbs. respectively and are made using the flow form process. I ordered them from CARID about a week ago. They were NOT able to confirm fitment on the 2017 with PP. I really hope they fit because I think they may be an ideal track/autocross wheel. I will post results when they get here.
Update: I just got notice that the wheels are scheduled to ship on Thursday March 16th. I don't know if they're shipping from the manufacturer in Canada or a distribution center in the lower 48. I'm in California, and know they have a distribution center here, so I'm hoping that's where they're coming from.
I'm quoting myself:-) The wheeles arrived on Friday night. They look both fantastic as well as unique, and the quality seems to be exceptional.
Unfortunately, the spokes of the wheels interfere with the 4 piston Brembo Calapers on the front of the PP equipped car. From what I can tell, it looks like 8mm spacers, or at a bare minimum (seems a little tight) 5mm spacers would be necessary to clear the Brembos with the 8" wheels. If my math is correct, 5mm spacers with a +35 offset (stock is +48 offhset) = 18mm further out (more scrub radius). From my calculations (I could not mount a tire and set the car down), the outer edge of the rim would extend about 1/4" (poke) beyond the fender directly above the center cap of the wheel (stock on the PP Wheel is about 3/4" (tuck) in, or inside the fender).
On the 9" wheels, the spokes of the wheels interfere with the 4 piston Brembo Calipers, although not as much as on the 8" wheels. From what I can tell, it looks like 5mm spacers, or at a bare minimum (seems a little tight) 3mm spacers would be necessary to clear the Brembos. If my math is correct, 3mm spacers with a +35 offset = 16mm further out (more scrub radius). From my calculations, the outer edge of the rim would extend about 5/8" (poke) beyond the fender directly above the center cap of the wheel. Also, please note that without a tire mounted, and the car sitting on the ground, I can't be sure about interference with the PP springs.
The rear 2 piston calipers did not interfere with the 8" or 9" wheel and would not require any spacers. From my calculations, the outer edge of the 8" rim would be in about a 1/4" (tuck) inside the fender directly above the center cap of the wheel, and the outer edge of the 9" rim would extend about 1/4" (poke) beyond the fender directly above the center cap of the wheel (stock on the PP Wheel is about 1" (tuck) in, or inside the fender).
I had intended on taking pictures, but got caught up in all the excitement and calculations. Sorry!
Let me know what you think.
BRZ FAMILY FUN is offline   Reply With Quote
Old 03-25-2017, 05:35 PM   #1033
Wondark
Driver
Wondark's Avatar
Congrats! Sorry I'm late to the show lol
Old 03-26-2017, 09:57 AM   #1034
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
HEY! That's my car!!
JSube is offline   Reply With Quote
Old 03-26-2017, 01:52 PM   #1035
trippinbillies40
Drives: '22 WRB
It's killing me knowing that my car is at the dealer 5 minutes away but I can't go pick it up. Back in town but they're closed today. Maybe tomorrow, but more likely Wednesday.
Old 03-27-2017, 07:35 PM   #1036
trippinbillies40
Drives: '22 WRB
Yep, Wednesday. Fiance wants to go with me. grrrr, lol.
2017, brz, delivery, package, performance
Controlling the nannies in 2017 vs. pre 2017 mdm Scion FR-S / Toyota 86 GT86 General Forum 23 10-04-2016 11:11 PM
2017 delivery time frame? AndrewC BRZ First-Gen (2012+) — General Topics 480 09-25-2016 09:57 PM
How many k's on delivery ? ZZT86 AUSTRALIA 78 12-20-2012 05:00 AM
Another FR-S delivery raphymartinez BRZ Photos, Videos, Wallpapers, Gallery Forum 3 06-24-2012 05:19 PM
delivery in UK FIRECAR Scion FR-S / Toyota 86 GT86 General Forum 2 06-04-2012 02:36 AM
