Northern California NorCal
Old 03-12-2017, 08:26 PM   #8849
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
It was in the sun for a while, but I didn't try directly heating it.
Originally Posted by Kaotic Lazagna View Post
Did you try heating up the emblem/tape?
Originally Posted by humfrz
I'm old and lazy
Old 03-12-2017, 08:29 PM   #8850
Kaotic Lazagna
Drives: GR Corolla
I found slightly warming it up with either a blow drier on high heat or a heat gun on low heat helped. Maybe if you ever need to remove the Toyota emblems in the future, give them a few passes with a blow drier.
Old 03-12-2017, 10:13 PM   #8851
Clipdat
Proud of BOXER
Clipdat's Avatar
@finch1750 Dell is playing tonight!
I'm old and lazy
finch1750 (03-13-2017)
Old 03-12-2017, 10:31 PM   #8852
spike021
spike021's Avatar
Boring learning-manual update for the day:
Slowly getting better. TBH my parents' neighborhood kinda sucks for learning. It basically has medium hills, medium-small hills, and then most of the "flat" areas have a very very slight incline that still causes the car to fall back in neutral.
Went to a parking lot in the area and spent about 45 mins working on things. Mostly moving with clutch and no gas, stopping, repeat. Then trying to go into first from a stop, going 5 feet, stopping, and repeating. For the most part I stopped stalling on that stuff.
Still stalling occasionally though and sometimes it takes a couple tries to get going again.
Occasionally I think I smell the clutch or squeal the wheels from a stop (less often now though) and I feel bad about the car, but I'm counting on the fact that these cars can handle some shitty abuse at the beginning. My dad even made a comment along the lines of "hopefully this car can withstand this shit."
Again, really thankful for your advice guys. Someday I'll buy you all a round or something.
spike021 is offline   Reply With Quote
The Following 2 Users Say Thank You to spike021 For This Useful Post:
Clipdat (03-12-2017), My Key (03-13-2017)
Old 03-12-2017, 10:35 PM   #8853
Clipdat
Proud of BOXER
Clipdat's Avatar
Wow, he was being rude by saying that. Yes, the car can absolutely handle this with no long term effects.
It's probably more damaging to the car to rest your foot on the clutch and have it partially depressed during normal driving, to ride the clutch in stop and go traffic every day, to try to release the clutch when the shifter isn't in a gear, to keep the clutch depressed while sitting at a stop light, and to rest your right hand on the shifter while driving.
And I'll take you up on that beer sometime.
I'm old and lazy
spike021 (03-12-2017)
Old 03-12-2017, 10:53 PM   #8854
spike021
spike021's Avatar
There have been times when I probably partially depressed the clutch too long and whatnot but in the last couple times I drove today I got myself to do it less and less. Trying to minimize bad habits.
My dad has good intentions but generally he'll assume things when he doesn't _really_ understand them and get a little..stubborn/annoyed. Like he supported me getting it in manual in the first place, but just the learning aspect he doesn't really understand, coupled with the car sounding sad sometimes when I'm not perfect/whatever.
For sure.
Old 03-12-2017, 10:56 PM   #8855
spike021
spike021's Avatar
I consider anything between 2000-4500 rpm a reasonable range to be cruising in. Obviously anything at the higher end will be less fuel-efficient. Maybe he's used to being with people who have larger displacement engines and lower redlines. If it's a V6 or V8 with a redline of 6000 I could see how they'd have plenty of torque down low and 3000 RPM is too high for normal driving. But this is a fairly low-torque 2.0L 4-banger and you need to keep RPMs higher to have any semblance of torque. If you are below 2000 rpm you are lugging the motor and that is bad for the motor too. So... maybe he's not *wrong* but remind him that redline is up at 7400 RPM on this motor. Well maybe you don't want to get into that conversation with him just yet. You might be better off just agreeing with him and keeping RPMs between 2000-3000 when he's in the car, and during the break-in period.
Argh, just realized I left this response in another tab:
Gotcha, that makes sense. There've definitely been a few times when I was around 1000-2000 but I try not to keep it there long. Still getting used to even considering RPMs at all. I set the setting for the RPM limit (I think it's called that?) to 4000 RPM, but maybe I should drop it to 3000 for now instead.
Old 03-12-2017, 11:09 PM   #8856
Kaotic Lazagna
Drives: GR Corolla
Yup, do the throwout bearing a favor and don't clutch in at stop lights or sitting in traffic. And I forget why it's bad to rest your hand's weight on the shifter, but it's bad mmmkay?
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Old 03-12-2017, 11:09 PM   #8857
Kaotic Lazagna
Drives: GR Corolla
Drove the FR-S to work today. Filled her up with some 100 octane on the way home.
The Following 2 Users Say Thank You to Kaotic Lazagna For This Useful Post:
My Key (03-13-2017), spike021 (03-12-2017)
Old 03-12-2017, 11:13 PM   #8858
spike021
spike021's Avatar
How much does that cost?
Old 03-12-2017, 11:14 PM   #8859
Clipdat
Proud of BOXER
Clipdat's Avatar
Are you on the stock tune?
I'm old and lazy
Old 03-12-2017, 11:15 PM   #8860
spike021
spike021's Avatar
I've been doing that a bit at stop signs and stuff, but once I'm used to everything I'll be switching to neutral at stops. In fact, even my dad had me do stuff in the parking lot where I'd start into first, slow down and stop, then switch the shifter to neutral, then back again. So that was good advice to get me ready for stalls or just going into neutral at stops.
Haha yeah. I've been good about not leaving my hand on the shifter so far. That's like the easiest thing to do so far :| lol.
Old 03-12-2017, 11:19 PM   #8861
Kaotic Lazagna
Drives: GR Corolla
It cost a pretty penny at $9.199/gallon. But this is only my second time doing it. I'm running OFT OTS stage 1 91 tune, but I figured since the car's going to sit, might as well have a 93 octane mix in it (don't think the gas will degrade that fast tho). Since I've been getting stuff for the Yaris, I figured I should do something for the FR-S.
Edit: only filled up with 3.5 gallons (3.496 if you want to be exact). That's more than enough to get a slightly higher than 93 octane mix for our cars (assuming the rest of the tank is 91).
As long as you don't get in the habit of clutching in at stops, you'll be fine.
Clipdat (03-12-2017), spike021 (03-12-2017)
Old 03-12-2017, 11:25 PM   #8862
spike021
spike021's Avatar
Dang, lol. If you can make use of it then it's definitely worth it haha.
Yeah, I don't want to do that. If in traffic or being at a red light, does moving forward in 1st by just releasing the clutch to the engagement point count or would you say I need to just completely get to moving in 1st with gas and no clutch?
*Chat* Vancouver FR-S/BRZ Members Mumbo Jumbo Thread peazs CANADA 1397 06-28-2019 12:17 PM
NorCal (Bay Area) AutoX Thread! BlaineWasHere Northern California 1398 02-08-2019 01:27 PM
Mid-Atlantic Chat Thread clevrname Mid-Atlantic 5296 08-25-2016 01:30 PM
FS: Five Axis Five:AD Aero Kit w/ Rear spoiler Whiteout - NorCal Bay Area firebert Exterior Parts (Aero, Lighting, Etc.) 13 01-08-2013 11:07 PM
NorCal Bay Area ecutek tuning AsphaltLover Southern California 0 11-11-2012 12:38 AM
