Old 02-22-2017, 03:09 PM   #3935
gtengr
Drives: 2017 BRZ
Originally Posted by twag4 View Post
I was on a 93 octane tune for about one year. C30, standard pulley, oil cooler, ace 350a header and full exhaust.
Did you dyno the car that way? I've been searching for results with the standard pulley and ace header.
gtengr is offline   Reply With Quote
Old 03-02-2017, 10:59 AM   #3936
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Placed my order for the JRSC kit with dual catch cans and Jackson oil cooler. Can't wait!
Barefootdan is offline   Reply With Quote
Old 03-02-2017, 12:17 PM   #3937
D-rek07
Are catch cans common with the JRSC kit?
D-rek07 is offline   Reply With Quote
Old 03-02-2017, 01:20 PM   #3938
Barefootdan
Drives: 2017 BRZ
They're not needed but since I will be tracking the car and daily driving it, any sort of preventative maintenance is accepted here. I'd rather open an empty catch can than an oily intake pipe.
Old 03-02-2017, 01:37 PM   #3939
arren123
Drives: 2013 BRZ (RIP), now 2017 BRZ
I was doing research on this and came to the conclusion that it was not needed. I only have the oil cooler.
I've had the JSRC since 11/2016 and it is my DD. I don't seem to lose any oil.
arren123 is offline   Reply With Quote
Old 03-10-2017, 10:04 PM   #3940
zypher
Drives: WR Blue BRZ
Oil loss is not a symptom of needing a catch can. If you take off the intake elbow for the supercharger intake and there is oil residue there a catch can is a good idea.
As it is your DD you may not need one but you may want to check anyway
zypher is offline   Reply With Quote
Old 03-11-2017, 01:08 PM   #3941
PMok
Codename: Stitch
PMok's Avatar
Hi guys, just sharing some recent experiences.
I have a 2016 BRZ with the C30 supercharger. The SC was installed around 4000 miles and I now have about 11,000 miles on the car. The car has gone through roughly one season of 86CUP track days. Car is basically in CARB legal configuration with a Greddy axle back muffler.
After one of the morning track sessions last weekend, the car sounded horrible with a loud exhaust leak. No check engine lights, but we could tell the leak was coming from the header area. We took the car to a lift and removed the header and heat shields. This is what we found:
At the time my SC was installed my shop noted that the OEM catted header would trap a lot of heat. I also ran a vented hood in the summer months after seeing very high under hood and oil/coolant temps. The takeaway for me is that the OEM header isn't meant to take this kind of heat. I am running a OEM replacement for now but will be looking at uncatted aftermarket headers to address this.
Old 03-12-2017, 01:35 PM   #3942
10Tim
Here for the fun
10Tim's Avatar
Drives: 10 Series FR-S #2478
Wow, first time I've seen this. I'm running a C38/CARB tune and TRD axleback. Wondering if something like this may be in my future. Has this happened to anyone else?
So if you go with aftermarket header you will no longer be CARB legal, and you will have to take it somewhere to get tuned. Correct?
There's just Not Enough Hours in The Day
On Flickr http://www.flickr.com/photos/24663968@N00/
On Instagram XLTimbo
10Tim is offline   Reply With Quote
Old 03-12-2017, 03:01 PM   #3943
bfrank1972
Drives: 2013 FR-S Argento
I think CSG Mike ran into this a while back - probably more of an issue with people who run their cars hard & frequently at the track. That said, this is obvious evidence that the catted stock header is a significant restriction on a FA20 with FI.
Old 03-12-2017, 09:35 PM   #3944
PMok
Codename: Stitch
PMok's Avatar
Correct. This was an upgrade path that I wanted to avoid, or at least postpone, due to the additional costs/mods and the slippery slope that entails. But I track, and that obviously has a steeper toll on components than a purely street-driven car would face. Chalk this one up to the "you gotta pay-to-play" column.
If your car is never or rarely tracked, this may not ever be a concern for you.
Old 03-12-2017, 10:05 PM   #3945
bfrank1972
I wonder if you would have fared okif you had just gutted the cat on the stock header.
Old 03-13-2017, 04:36 PM   #3946
10Tim
Here for the fun
10Tim's Avatar
I do SoCal 86Cup and track my car so this is not good news. Maybe I should keep my eyes out for stock headers in the for sale section and just plan to replace when this eventually happens, because I want to keep my car CARB legal.
Old 03-13-2017, 05:36 PM   #3947
PMok
Codename: Stitch
PMok's Avatar
I heard someone say that a gutted stock header actually performs fairly close to an aftermarket header... but in the same vein, it may require a retune. If you're going that route, you might as well buy a header, in my mind.
yeah I thought about this route as well. Stock headers shouldn't be too hard to find, I know a few local shops who have spares on hand from doing header swaps for their customers.
Old 03-13-2017, 07:45 PM   #3948
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
It has happened to a few 86CUP competitors with factory header. You can still blow out the cat or HFC in the header on track.
OEM header and front pipe had blown out cats on a completely factory vehicle.
It's not a concern on a street car.
It will be a wear item as you increase your pace.
Gutting the cat is basically removing a source of restriction. Properly designed headers help scavenge exhaust gasses properly. Not all headers are designed with the same level of intent. While it does improve power output, we have proven that various headers do make different power for a JRSC setup.
CounterSpace Garage is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
