Old 03-10-2017, 05:41 PM   #113
trinidadj
Drives: '16 FRS-MT Ablaze Red
Im putting on lcas is it okay to only jack from the rear? I'll support it with two jack stands at the rear jack points and choke the front wheels?
trinidadj is offline   Reply With Quote
Old 03-10-2017, 11:39 PM   #114
Cole
Not a troll
Cole's Avatar
Yep
Cole is offline   Reply With Quote
Old 07-23-2017, 12:31 PM   #115
radroach
Drives: car
Car slipped of jack this morning and broke a bracket and bent the radiator. 0/10 would not do again.
Old 07-23-2017, 01:53 PM   #116
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
The jack couldn't support the extra weight of the battery.
The Following User Says Thank You to Andrew025 For This Useful Post:
zc06_kisstherain (07-26-2017)
Old 07-23-2017, 04:01 PM   #117
radroach
Drives: car
Shut up douche
Old 07-23-2017, 04:08 PM   #118
Andrew025
Andrew025's Avatar
Shut up douche
Old 07-23-2017, 04:25 PM   #119
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
What's are the recommended jacking points on the sides of the car when the front is too low to get a jack on under?
ApexEight is offline   Reply With Quote
Old 07-23-2017, 04:32 PM   #120
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
I would just get a 1"thick or more board and drive up on it. Then slide a low profile jack under the front
SuperTom is offline   Reply With Quote
The Following 2 Users Say Thank You to SuperTom For This Useful Post:
Tcoat (07-23-2017), zc06_kisstherain (07-26-2017)
Old 07-26-2017, 05:58 PM   #121
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
this.
i usually do this for quick check up under the car.
otherwise, i just use my quickjack for other works.
Old 07-26-2017, 06:55 PM   #122
Gunman
Drives: 2019 Mazda Miata RF
I made myself some ramps. Later I modified them, so I could remove the lower section, to allow the jack to get to the side jack points, or put jack stands under the car.
The Following 8 Users Say Thank You to Gunman For This Useful Post:
ApexEight (07-27-2017), Busybee (06-27-2022), new2subaru (07-26-2017), Overdrive (07-26-2017), radroach (07-27-2017), SuperTom (07-26-2017), Tcoat (07-27-2017), _sams86_ (07-27-2017)
Old 07-26-2017, 09:37 PM   #123
SuperTom
SuperTom's Avatar
Brilliant!
Old 07-27-2017, 09:40 AM   #124
Moue
Drives: 2014 Lightning Red Subaru BRZ
Foolishly bent my front jacking point by not using a wooden block. I've found the scissor jack with a proper crank is really fast to get the car up for oil changes or other header/exhaust work.
Moue is offline   Reply With Quote
Old 07-27-2017, 11:59 AM   #125
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
Just keep in mind that the sicssor jack the car comes with is intended for emergency use (meaning infrequently, unless you're just the most unlucky guy on the road), not to get the car lifted to accomplish regular maintenance on a regular basis.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Tcoat (07-27-2017)
Old 07-27-2017, 12:32 PM   #126
Originally Posted by Overdrive View Post
Just keep in mind that the sicssor jack the car comes with is intended for emergency use (meaning infrequently, unless you're just the most unlucly guy on the road), not to get the car lifted to accomplish regular maintenance on a regular basis.
And even then you want to only need it on a nice firm and level place.
There are some places you just do not want to have to use a jack for any reason.
Busybee (06-27-2022), Overdrive (07-27-2017)
Jacking up car - using garage jack NYNOMAD BRZ First-Gen (2012+) — General Topics 2 06-27-2012 08:36 AM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 05:19 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 08:07 AM
