Old 10-17-2016, 09:48 PM   #183
Wh1te
Drives: BMW
Originally Posted by babybreath View Post
here is my TIS installation steps
i used MINI VCI OEM cable from http://www.obdtool.co.uk/wholesale/2...gle-cable.html
installed on windows XP
Step 1- install Toyota Teachstream
Open “Toyota Techstream 10.30.029.exe”
Select a steup language to go on
Click Next
Accept the agreement to go on
Customer information: click Next
Click Install to begin installation of Techstream 10.30.029
Finish installing Techstream
Step 2- install MVCI driver for TIS
Open “MVCI Driver for Toyota”
Click Next
Click Install to begin installation of the MVCI driver for TIS
Finish installing MVCI driver for TIS
Step 3- paste and replace Main Menu
Copy “MainMenu” application
Open Techstream Properties
Click Find Target
Paste “MainMenu” application in C:/program files/toyota diagnostics/techstream/bin, confirm file replace
Close bin folder and Techstream Properties
Connect the mini vci cable to the vehicle and then install the driver
Open “Techstream” on Desktop
Click No
Select Setup->Techstream configuration
Select an area (here: Europe), click Next
Select a language (here: English), click Next
Techstream configuration, click OK
open Desktop folder “Toyota Techstream”->notepad “serie”
Copy the key
Click Connect to vehicle in Techstream interface
Paste as the New Key when register Techstream software, click OK
Finish Option (here: VIOS, China & 1205-), click Next
Select Engine and ETC to continue
Trouble codes display
Select Data list on the left menu
(Lost communication with vehicle: click Retry)
Click Close->Main Menu->Log out (Techstream)
This site you upload changed domain,it is now MINI VCI OEM Diagnostic Cable for Toyota TIS Techstream V10.30.029 have been dealing with them for several years, to me they are the most trustworthy supplier, goods usually dispatch out within 24 hours with tracking number, have a very good personal relationship with them.
Wh1te is offline   Reply With Quote
Old 10-22-2016, 06:41 AM   #184
TheRatsWon
Drives: 2017 Subaru BRZ Limited,Mazda Miata
I ordered the $20 cable below from Amazon. It came with v10.30.029 which installed and worked great on both a 32 bit Windows 7 and 64 bit Windows 10 machines.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
TheRatsWon is offline   Reply With Quote
Old 10-23-2016, 06:06 AM   #185
HyperTech
HyperTech's Avatar
Drives: Mazda3 2013 / Scion FR-S 2015
can we acess to the TPMS id and change it on the last version with the cable of TheRatsWon
HyperTech is offline   Reply With Quote
Old 10-24-2016, 05:22 PM   #186
HyperTech
HyperTech's Avatar
Originally Posted by camry619 View Post
Today, I received notice that Techstream lite v11.20.019 tested no problem working with xhorse clone mini vci cable, and they attached a download link, I tested it with success, I would like to share with all of you guy here. Anyone who want it browse this page: http://blog.uobdii.com/toyota-tis-te...chstream-lite/
It plublics where to download lite v11.20.019.
Good luck.
how you get it to work? mine keep asking for a key to register...
Old 03-07-2017, 08:46 PM   #187
M0nk3y
Can anyone help me out?
I purchased OE TPMS (Denso) sensors (picture below) and have tried resetting the codes via techstream.
I keep on getting error for communication, even though I can see my OE TPMS sensor values and can access the ECU.
Thoughts?
Old 03-07-2017, 09:06 PM   #188
Thoughts?
Way out of my range of expertise here but what does the "Initialization Switch Off" mean? Shouldn't that e on to initialize?
Old 03-07-2017, 09:27 PM   #189
Trust86
Drives: 2016 Halo FRS
I been trying to set up techstream for months and gave up. Followed step and just can never seem to get it working
Trust86 is offline   Reply With Quote
Old 03-08-2017, 08:46 AM   #190
stevesnj
stevesnj's Avatar
Isn't the TPS motion powered? How about shaking it to energize it and enter it in Tire 5 field
My 2016 Build thread
Old 03-08-2017, 10:54 AM   #191
You would think so, but no. Most, if not all, use a small disc battery and aren't serviceable.
http://www.tirebusiness.com/article/...h-tpms-sensors
Old 03-08-2017, 11:30 AM   #192
Casey10s
Casey10s's Avatar
Drives: 2013 white limited BRZ
I had new TPMSs on my new wheels. What I was told by a tire installer and the Subaru service is that the computer on the car needs to "enable" these new sensors. The Aftermarket programming devices do not typically do this unless you get the ones that approaching $1k in cost. You can see that the car can read the sensors but will not use them until they are enabled. Took a while, but I got mine to work by having Subaru service getting them read in correctly. What took a while was one of the TPMS was bad and that just confused the issue even more on what the problems were.
Casey10s is offline   Reply With Quote
The Following User Says Thank You to Casey10s For This Useful Post:
Dadhawk (03-08-2017)
Old 03-10-2017, 12:54 PM   #193
JF86Red
Drives: GT86 C7P
Yes, how to have the key for V11.20.019 ?
JF86Red is offline   Reply With Quote
Old 03-23-2017, 10:46 PM   #194
Gunman
Drives: 2019 Mazda Miata RF
So where is the latest hot ticket download link for Techstream software, which includes patching instructions? most links I tried are either broke, or didn't include the "fix".
Also, running Win10 64bit, anyone gotten the cable drivers to work on that?
Old 03-24-2017, 09:48 PM   #195
TheRatsWon
For those having issues with a serial number key, are you using Europe for the configuration?
Select Setup>Techstream configuration>Europe
Version v10.30.029 works with Win10 64 bit, can't vouch for other versions.
Old 03-28-2017, 02:28 AM   #196
JF86Red
Drives: GT86 C7P
V10.30.029 Europe configuration worked well (with the procedure explained page 13).
But when updated the lastest version, ask me the key
I feel I need back to previous version ...
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 01:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
