Old 06-29-2012, 09:21 AM   #85
wcbjr
Drives: 2006 Subaru LGT
Not to argue the point, just trying to get information...
What about oil return? I assume you need to scavenge when placing the turbo behind the engine. If you mount up front, can you place the turbo high enough to have a gravity-fed return?
wcbjr is offline   Reply With Quote
Old 06-29-2012, 09:49 AM   #86
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Originally Posted by yuli8466 View Post
Yes, I think many people prefer the 3rd as you would like to.
I just wonder will this method make the intake pipe too long? may be affect the throttle response.
Is it possible to open a cool hole of the bonnet for the intercool(near the firewall) like STI does ?
Actually having the water to air intercooler, both the cold side, and hot side piping would be the shortest route because it would be a rear mount turbo, and a rear mount intercooler (located by the firewall). The longest piping would be in the traditional front mount setup, next longest v-mount front mount, next top mount, and last water to air.
G
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 06-29-2012, 09:52 AM   #87
ft86-UAE
turbo FT-86
ft86-UAE's Avatar
Drives: ft-86
can you please get us info on boost level vs Hp.
3 PSI = Hp
5 PSI = HP
8 PSI = HP this i think is max on this engine.
and is fuel injector is good for the job or we will need bigger injectors.
thanks,
ft86-UAE is offline   Reply With Quote
Old 06-29-2012, 09:52 AM   #88
Don@Accelerated
Don@Accelerated's Avatar
The only viable option is the front mount. Air to liquid is very pricey when done right. Top mount is not an option solely because there is no way to get airflow across it.
Don@Accelerated is offline   Reply With Quote
Old 06-29-2012, 09:54 AM   #89
Don@Accelerated
We'll be scavaging both front and rear. There is not a real great spot to feed oil into that will well suited gravity fed.
The Following User Says Thank You to Don@Accelerated For This Useful Post:
jedibow (06-29-2012)
Old 06-29-2012, 09:55 AM   #90
Don@Accelerated
3 PSI = Hp
5 PSI = HP
thanks,
I don't have that specific info quite yet.
-Don
Old 06-29-2012, 10:04 AM   #91
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
I'm only interested in enough boost to make my car drive up a mountain road with the same power it would have at sea level. 4 to 5 PSI.
b.e is offline   Reply With Quote
Old 06-29-2012, 10:05 AM   #92
jedibow
I know Yuli was asking yesterday about an "ALL OUT" fully built bottom end project, so I imagined he had the money HaHa.
Old 06-29-2012, 11:57 AM   #93
wcbjr
3 PSI = Hp
5 PSI = HP
thanks,
Well, the motor already has 200 crank horsepower at 14.7 psi absolute. So that equals 13.6 crank horsepower per psi. That is best case and if they keep the compression ratio at 12.5:1.
Old 06-29-2012, 02:12 PM   #94
serialk11r
Drives: '06 AM V8V Coupe
Err psi != air mass. At room temperature you can do that, but compressing the air increases its temperature.
Old 06-29-2012, 03:11 PM   #95
jedibow
Correct Serial, P=nRT is your best friend!
Remember turbos do not create pressure for free, the maximum effieciency on the turbo that Don chose is 86% which is very good aslong as you are running the turbo in this effiecency island, so AT Best you will see a drop of 14% in pressure due to the increase in air temperature from created by the compression of the turbo.
This is exactly why I state earlier that a BW EFR turbo would not be a viable option in our car UNTIL you build the bottom end.
Old 06-29-2012, 03:17 PM   #96
serialk11r
Not only that, adiabatic compression itself increases temperature. If the turbo were 100% efficient, and you had no intercooling, 8psi would correspond to about (14.7+8/14.7)^(1/1.4)=1.36 times the original air mass, despite being a 54% increase in pressure. That's why some cars can run like ~30psi boost without the engine melting from heat, you may be increasing pressure by 3 times but the amount of air and fuel you're putting in is only ~2 times greater. Okay that wasn't totally accurate about the engine heat, but anyways.
Old 06-29-2012, 03:53 PM   #97
jedibow
If you keep it up I will bring down "Corky Bell" on your butt!!!!
HaHa
Seriously, anybody not familiar with forced induction systems should read "maximum boost" by Corky Bell, it does a fantastic job of explaining the dynamics, and theory behind turbochargers and turbo systems.
G
Old 06-29-2012, 06:11 PM   #98
slow_frs
Drives: turbo scion tc
Originally Posted by jedibow View Post
One problem, when you decrease airflow into the engine the ECU doesn't retard timing, it actually advances timing because it "thinks" that you are driving in a lower load condition than you actually are, and advancing timing beyond what is allowable in forced induction vehicle ends very badly...
Holes in your pistons, holes in you block, and holes in your wallet
Good catch I meant to say advances ugh
slow_frs is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
