Old 06-29-2012, 11:42 AM   #15
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Drives: 2016 Hot Lava 6MT FR-S
Originally Posted by FT-86GOD View Post
Caltex 98 or BP 98
Is that really 98 octane? is that calculated as (r+m)/2?
I know in Vietnam everything says 98 octane, but it's RON (research octane) which only calculates the isooctane, not the heptane... rather than RON+MON/2 (which is how we calculate in US/CAD).
EsoBOFH is offline   Reply With Quote
Old 06-29-2012, 11:48 AM   #16
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Shell 93, im trying out mixing 93 with a bit of ms109 to see what happens.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
Hanzo (06-29-2012)
Old 06-29-2012, 11:51 AM   #17
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Its 98RON..
Regular is 91 then there is 95 premium and ultimate is 98.....
Caltex:
BP: Apology for size...
FT-86GOD is offline   Reply With Quote
Old 06-29-2012, 11:55 AM   #18
SL
Drives: S2000
normal UL is 95 here in the UK, but find my (performance) cars always run better on 99 octane (Shell V Power, Tesco Momentum99) so will be treating her.
SL is offline   Reply With Quote
Old 06-29-2012, 11:57 AM   #19
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
NorCal, only Chevron 91 octane from a set of stations I normally use. Occasionally would use Valero if no Chevron around.
I found Shell gas to be, how do I put it... watery - burns out quick, lesser mpgs on our family car. And I can feel that I'm getting less power out of the engine with Shell too (not BRZ, cause I avoid Shell for those reasons). Maybe I'm paranoid.
76 - actually found that regular gas from them can cause detonation (happened to me on several occasions with rental cars). So, I avoid 76 as well, regardless of grade.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
Oriental Life is offline   Reply With Quote
Old 06-29-2012, 11:58 AM   #20
EsoBOFH
Senior Hoonigan
EsoBOFH's Avatar
Its 98 octane...
Regular is 91 then there is 95 and premium is 98.....
Just read this on another forum:
America and Australia use two different methods for grading their fuel. Australia is RON, America is RON+MON/2.
The highest "octane" fuel readily availible in America is 92 which is equivilent to our 98RON.
So it looks like your 98 is equivalent to the US 92.
Old 06-29-2012, 12:04 PM   #21
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Cali
91 ARCO, 76, or Shell so far. :/
Old 06-29-2012, 12:05 PM   #22
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Conventional 'standard' "Premium Unleaded" petrol in the United Kingdom, Europe and Australia has an octane rating of 95 RON, and in North America it is AKI/RdON/PON 91-93 (RON 96–98). However, higher octane "Super Unleaded" - often formulated with higher quality additives, is usually set at around 98 RON in mainland Europe; but this can vary by market. Most oil/petroleum companies now 'market' their own Super Unleaded petrols under a unique name - and the current name for Shell Super Unleaded fuel is "V-Power". Like most Super Unleaded petrols, V-Power also contains higher concentrations of detergents and other additives to help clean the engine and smooth its operation.
In Australia, from October 2006, Shell and Coles Express re-branded Optimax to V-Power (98 RON). V-Power Racing, the ultra-high performance variant has a rating of 100 RON although Shell have decided to phase out V-Power Racing from 21 July to mid August 2008, instead recommending V-Power[2]. The previously obtainable higher grade V-Power Racing which contained 5% ethanol to boost V-Power's octane rating to 100 RON has now been phased out by Shell due to a "changing market".....
In the United Kingdom and Denmark (where Super Unleaded must be a minimum of 97 RON), V-Power has a rating of 99 RON (whereas V-Powers' predecessor Shell Optimax was rated at 98 RON). There is one other 99 RON fuel available in the UK, namely Tesco MOMENTUM99.
Seems u are correct.....
The Following User Says Thank You to FT-86GOD For This Useful Post:
EsoBOFH (06-29-2012)
Old 06-29-2012, 12:30 PM   #23
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
Costco, Arco, and Thrifty 91. There is a pump by my house with 100 but not sure how I feel about paying $9/gallon.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 06-29-2012, 12:33 PM   #24
fenton
Using Husky 94, 10% ethanol blend.
fenton is offline   Reply With Quote
Old 06-29-2012, 12:38 PM   #25
rcm47
rcm47's Avatar
Drives: 13’ FRS (traded), 18’ CWP BRZ tS
Originally Posted by russv View Post
I live in California and am using 91 octane Chevron, the highest octane available .
Same here.
rcm47 is offline   Reply With Quote
Old 06-29-2012, 12:46 PM   #26
miodculae
FRS Adept
miodculae's Avatar
Drives: Firestorm FRS
What happened to 87 ? Nobody ? Its not like you're harming the engine.
miodculae is offline   Reply With Quote
Old 06-29-2012, 12:50 PM   #27
drifter
Drives: truck and old car
California's highest octane is 91. Should we be using some kinda of octane booster? If so, what is recommended? thanks
Old 06-29-2012, 12:56 PM   #28
Starscream15
Starscream15's Avatar
Drives: 2013 Subaru BRZ - DGM
91 Non-Oxy
Starscream15 is offline   Reply With Quote
