Old 02-28-2017, 03:33 PM   #29
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Just to clarify. The clunking when initially putting the car into gear wasn't what I was trying to convey. I don't want to cause any confusion. We're all here to help one another...
The clunk/ clank I am hearing is from 1-2 and 2-3 once gas is applied. What I've gathered from this thread is that there is slack between components and the clunking/ clanking together of those components is to be expected with a MT RWD FRS/BRZ.
DaBoBo21 is offline   Reply With Quote
Old 02-28-2017, 03:34 PM   #30
Da Brz
Drives: 2016 Subaru BRZ
Might be the LSD/SC? Are you turning when it does it?
Lay off the throttle, hot rod!
Da Brz is offline   Reply With Quote
Old 02-28-2017, 03:38 PM   #31
That ain't right. Get it checked.
Old 02-28-2017, 03:38 PM   #32
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Haha. It's random at times. On the straights, or a turn. It's not a very loud sound. I hear it mostly when the windows are up, and both A/C and radio are off. At that point you can hear pretty much everything going on with the car. When it happens, it's under a light load. I don't drive my BRZ very aggressively, especially on my daily commute.
Old 02-28-2017, 03:42 PM   #33
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Been doing it since I drove it off the lot, sir. I think we were on the same page earlier in the thread.
Old 02-28-2017, 03:48 PM   #34
This^ It is just the LSD doing it's limited slip job. Again nothing to worry about.
Old 02-28-2017, 04:59 PM   #35
Haha... ok. Going back and rereading your OP I didn't want to be the guy that dismisses an odd sound.
Old 02-28-2017, 06:38 PM   #36
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Oh no, I appreciate the feedback! It's hard to be clear over a thread lol. I value what everyone suggests. Feeling a bit better about it after the responses.
The Following User Says Thank You to DaBoBo21 For This Useful Post:
Ultramaroon (02-28-2017)
Old 03-01-2017, 07:30 PM   #37
zberz
Drives: 2015 Lightning Red BRZ
The driveline slack on my last car scared the crap out of me at first, but it was my first manual RWD. I still think it was more than normal, but never had any issues because of it. The brz is nothing in comparison. You get used to it and will probably start driving better to minimize it. :-) The clunk from neutral to first and first to second still happens no matter how hard I try.
Sent from my SM-J700T using Tapatalk
zberz is offline   Reply With Quote
Old 03-07-2017, 10:51 AM   #38
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Metal On Metal While In Gear
Hey guys.. Me being in the military, no question is a stupid question. Over the last 3K miles or so, I've noticed that when I'm next to a large surface (like a wall or median), I can hear what sounds like metal on metal rotating against each other. It does not happen all the time, but recently it has become more noticeable. I hear it a lower speeds (15-30 MPH), and it's pretty loud. It's made me a bit worried that it could be my flywheel/ pressure plate or something inside the clutch assembly. Like I have said before, I do not drive this car hard, and I've only put 5400 miles on her over the past sevenish months.
Could this be something with the clutch/flywheel/pressure plate? Maybe something unevenly worn? Or not adjusted correctly?
Where are you Humfrz? lol
Old 03-07-2017, 10:58 AM   #39
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Just to add, the car is driving great. Shifts are good, engagments are smooth, so no issues there. Just want to pin point what this noise is.
I know the TOB is an issue with these things, so maybe that could be a possibility?
Old 03-07-2017, 11:16 AM   #40
If all works then don't worry about it. If it was the TOB you would hear it all the time not just under the very specific circumstances you described.
Should you start to have more symptoms of an issue than just a noise then start to look for issues but every single noise does not mean their is a problem. These are one of the noisiest cars I have ever driven but it is just weird sounds not signs of impending doom.
DaBoBo21 (03-07-2017)
Old 03-07-2017, 11:23 AM   #41
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
You're most likely right.
Tcoat (03-07-2017)
Old 03-07-2017, 11:29 AM   #42
They sound like old Russian farm tractors. I just turn the radio up and ignore the weird sounds and haven't broken a thing yet.
Automatic Transmission: Loud Clank Moshpit37 Engine, Exhaust, Transmission 5 05-23-2015 07:21 PM
Clank from suspension/give in steering wheel over bump Shady195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-09-2014 08:15 AM
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-04-2014 11:26 PM
Engagement Ring Hix Miscellaneous 7 03-07-2013 02:28 PM
Engagement... so expensive. merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 43 08-02-2012 09:55 PM
