| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
#15 |
Drives: 2013 Black GT86
I'm leaking oil right now from my oil filter. I'm tightened to specification at first and once I noticed the oil leak, tightened it more, I'm still leaking oil. Should I replace the filter?
#16 | |
Drives: Raven FR-S 6M
1. debris from the old seal wasn't cleaned off 2. seal on the filter is damaged 3. filter is too tight or too loose
“The World is Flat”
[||•]=(86)=[•||] |
#17 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
Considering how cheap it is I would. Mine did this once before i started cleaning the tray before putting the new one on. Dont know if thats what caused it or what. If it happens again with the new one then i would imagine there is a problem
#18 |
Custom Title
Drives: GT86
I found this link on google and thought I'd share my experience with this issue. My car seems to be leaking from a gasket under a plastic part that is connected to the bottom of the engine. It's on the front of the engine, on the drivers side. I found an image online that shows the exact location of the part. (see red arrow).
Does anyone know what this part is, so I may purchase a new gasket for it, and replace it? Thank you.
#19 |
Custom Title
Drives: GT86
here is a poor image of the part on my car;
#20 |
That's a local low point that collects anything leaking from above. Look for the highest wet spot.
If it's really that gasket, -o-ring, actually- then you're looking at what's called a camshaft position sensor. Look for it in the service manual. See my sig line.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#21 | |
Custom Title
Drives: GT86
Ah, thank you so much - very helpful. I'll just add a tiny graphic here. I can't seem to find the "thank you" button on here...![]() Upon further investigation, it is a 2-drip-per-week-leak and it's either this part or the head gasket, in which case i'll try to fill the void with rtv from down undah on a non-driving day to see if that helps. The alternative is to spend approx. $2k for a tech to replace all the gaskets on the engine. And this doesn't sound too bad either, given the thought that everything would be replaced and visualized for further internal inspection.
Eat, Sleep, Drive, Work, Drive, Ride, Eat, Sleep. Repeat
#22 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
If that's not the culprit, most likely it's the timing chain cover.
Might be simpler to name it Dr. Drippy and top up the oil when needed. Bring back total loss oiling.
"I gotta rock." -- Charley Brown |
| The Following 3 Users Say Thank You to bcj For This Useful Post: |
#23 | |
Drives: FR-S,GTI
| The Following User Says Thank You to WNDSRFR For This Useful Post: | CockpitCruiser (11-07-2021) |
#24 |
Drives: Crapcan
It is mostly labor since the engine has to come out to do the job properly. It is really quite a bit of work.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | CockpitCruiser (11-07-2021) |
#25 | |
![]() Welcome!
| The Following User Says Thank You to Ultramaroon For This Useful Post: | CockpitCruiser (11-07-2021) |
#26 | |
Custom Title
Drives: GT86
You are exactomundo. It IS the chain cover. Thank you
#27 | |
Custom Title
Drives: GT86
I'm workin on it but it's difficult to leave meaningful comments on former conversations until I get to 10
| The Following User Says Thank You to CockpitCruiser For This Useful Post: | Ultramaroon (11-02-2021) |
#28 |
One more!
| The Following User Says Thank You to Tcoat For This Useful Post: | CockpitCruiser (11-07-2021) |
| Best places for stickers | lastexile1987 | Cosmetic Modification (Interior/Exterior/Lighting) | 58 | 02-01-2020 01:32 AM |
| Places to get stuff | Qwimby2 | BRZ First-Gen (2012+) — General Topics | 4 | 12-24-2015 09:30 PM |
| Best Places to go? | BPM | CANADA | 0 | 10-25-2013 02:56 AM |
| Best places to take my car for a wash | slowbrz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 7 | 06-14-2013 04:01 PM |
| places you've been, or want to go | wallace03 | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 06-18-2012 02:40 AM |
