Old 03-03-2017, 03:34 PM   #141
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
I'm ready to pull the trigger on the intake if it will make my life easier. I'll take any performance gains as well 🤗
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Old 03-03-2017, 03:37 PM   #142
Reamer
Drives: 2015 FRS
It looks nice in the engine bay, but I am skeptical of any real gains that the stock airbox didn't have with a filter and intake tube that eliminated the sound tube. There's no a huge amount of room, but it isn't touching IIRC.
Sent from my Pixel using Tapatalk
Reamer is offline   Reply With Quote
Old 03-03-2017, 03:43 PM   #143
Kestrel
Kestrel's Avatar
I just installed the Legsport snorkel and felt good things. I'm interested to see how they play together.
The Following User Says Thank You to Kestrel For This Useful Post:
Reamer (03-03-2017)
Old 03-03-2017, 09:26 PM   #144
Reamer
Drives: 2015 FRS
If you could post pictures of how close the fittings are to the intake box I'd be eternally grateful. I just installed the JR rad and the fittings rub the stock air box a bit.
The Following User Says Thank You to Reamer For This Useful Post:
Kestrel (03-03-2017)
Old 03-03-2017, 09:34 PM   #145
Kestrel
Kestrel's Avatar
Looks good to me! Thanks a lot
Reamer (03-03-2017)
Old 03-08-2017, 12:57 AM   #146
GT86Asia
Drives: 2016 BRZ
I got mine installed last month, so let me share my limited experience with the dual radiator thus far.
Firstly, I say limited, because I'm still braking in the newly built motor, so I can't go past 4500rpm, that's my red line right now, still another 1,800 miles to go....
In any case, I can share my experience before and after the dual radiator during warm up, idle, and cruising, and fitmet.
1) Fitmet is perfect, I have the edelbrock, and the extra long 4-2-1 headers, which are very close to the electric fan with the stock radiator. With the Jackson one, there is absolutely no change, it fits exactly as the OEM does. It's really a brilliantly fitment designed radiator. And the fan is not any closer to the headers than before.
2) The engine oil will warm up significatly faster than before it had this dual radiator installed. with the edelbrock and e85, it would take up to 20 minutes on 60-70 ambient temp to warm up the oil while idling from cold to operating temp. With the dual radiator, it takes 8-10 minutes.
3) While idling, coolant temp and oil temp will mirror each other for the most part. Something never happened before. However, before the radiator was installed, when idling coolant temps would stay much cooler than they do now. Since the oil will bring the coolant temp up, specially at low rates of speed and in traffic. Before, without the dual radiator, coolant temps would hardly ever change, even out in the track, coolant temps would increase at the most by 2-3%. Now with the coolant cooling the oil, coolant temps can and will vary up to 15% from stock coolant temp.
Like I mentioned, this is most noticeable when there is lack of air flow, i.e. while idling or in traffic.
4)When cruising at highway speeds, it's actually the other way. It is notably harder to increase the oil temp, compared to before. The oil temp likes to stay in the lower range of operating temps, which is a good thing! I still have yet to pass beyond 206F, even after driving for over one hour.
However, you must take into account that my redline is currently 4500rpms. Eventhough, you can still go about 100mph and be under 4500rpm on the freeway.
5) I'm still learning the temperature behavior on the car after the jackson radiator was installed, but I wont be able to fully test it until after the brake-in is done, and I put the 22psi pulley on and retune the car.
Nevertheless, I like it very much so far, and the benefits are very real, even with limited testing thus far.
I'll share some photos on a follow up post!
Cheers!
GT86Asia is offline   Reply With Quote
The Following 9 Users Say Thank You to GT86Asia For This Useful Post:
BRZ FTW (03-08-2017), CxG (01-10-2018), Harvie1031 (03-08-2017), jbailey8748 (05-25-2018), mrg666 (08-10-2017), Reamer (03-08-2017), SPCorBUST (03-08-2017), tCsonfrs (03-11-2017), weederr33 (04-17-2019)
Old 03-08-2017, 10:29 AM   #147
BRZ FTW
Drives: 2017 Subaru BRZ
Cheers!
Exactly the type of review I was looking for. Thanks!
BRZ FTW is offline   Reply With Quote
The Following User Says Thank You to BRZ FTW For This Useful Post:
Old 03-11-2017, 11:39 AM   #148
GT86Asia
Drives: 2016 BRZ
Here are a few shots of my Jackson dual radiator installed with my long headers and the edelbrock.
The Following 2 Users Say Thank You to GT86Asia For This Useful Post:
Reamer (03-11-2017), Tor (04-12-2017)
Old 03-11-2017, 01:38 PM   #149
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
this kit is all fun and games until you install a turbo kit and try to clear the AN fittings on the sandwhich plate LOLOL
tofurun is offline   Reply With Quote
Old 03-11-2017, 02:30 PM   #150
GT86Asia
Drives: 2016 BRZ
yeah, turbos are just soo complicated
Old 03-24-2017, 04:39 AM   #151
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Jackson Racing View Post
[CENTER]
FOR RELEASE April 25th, 2016
Contact: Jackson Racing: info@jacksonracing.com Tel: 909-927-8500......
I want your thoughts on using the radiator/oil cooler coupled with an LS specific sandwich plate (and custom oil lines sourced locally) for my LS2 swap.
Will this be able to provide enough cooling capacity? I obviously know you have no data and this would be an educated guess. The car will rarely see the track, mostly street hard driving.
Old 03-26-2017, 02:51 AM   #152
choi0706
Drives: t
+1
choi0706 is offline   Reply With Quote
Old 04-12-2017, 06:58 AM   #153
Reamer
Drives: 2015 FRS
So what's the recommended way to do an oil change with this kit and to make sure the oil in the oil cooler is changed too?
Sent from my HTC 10 using Tapatalk
Old 04-12-2017, 03:32 PM   #154
Kestrel
Kestrel's Avatar
Anyone using a lower profile oil cap to get more of an angle for the oil lines? I'm looking at trying the Prova as a possibility as it seems nearly flat.
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 05:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 11:26 AM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 02:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 11:04 AM
