Old 03-02-2017, 09:30 AM   #1
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Greddy Revolution RS Single Exit Exhaust
Good morning! Last night my girlfriend and I installed my new exhaust (Greddy Revo RS). Sounds phenomenal. However, we had a hell of a time with the midpipe to frontpipe connection. The bolts and seal provided did not fit through the factory frontpipe. We tried reusing the factory bolt and spring and could not find a way to compress the spring enough to apply the nut on the other end. Through a lot of frustration, we ended up using spare bolts we had laying around the garage and used lock washers to make sure nothing would go anywhere. That being said, we still have a small gap between the Greddy midpipe and factory frontpipe. We checked for a leak and from what we could tell there wasn't. For now, the way we were able to connect it seems to work fine, but I don't feel 100% confident to leave it that way. We tried to find instructions or install videos/forums with this exhaust and completely failed. From what we could tell, there's nothing out there to help us. We are new to this, so any assistance anyone could provide would be greatly appreciated.
Is this normal for this exhaust?
Do I need to reuse the factory bolt and spring?
Should I take it to a shop and have someone take a look at the connection?
Thanks guys!
DaBoBo21 is offline   Reply With Quote
Old 03-02-2017, 11:55 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Thanks guys!
you dont have to use stock bolts. homedepot bolts are fine. as long as there is no leak, i wouldnt worry. did you connect from front to back? try to loose all connection and connects from front to back and see if fitment is better.
Old 03-02-2017, 12:06 PM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Its due to the donut gasket. Do you feel a leak under the car? If not, its fine. Snap a pic while down there to to help us confirm exactly what it looks like.
And yeah, OEM bolts wont work at all. Home depot or spare stuff is fine.
Old 03-02-2017, 12:30 PM   #4
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
We tried both ways, actually. Ended up having to go front to back in order to finish it.
Old 03-02-2017, 12:31 PM   #5
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Gotcha gotcha. I'll snap a picture and upload it here soon. Thank you!
Old 03-03-2017, 02:52 AM   #6
balci
I had the exact same problem, I guess we should notify greddy?
I ended up using the oem bolts and the donut gasket. doesn't look very nice but I didnt notice any leaks
balci is offline   Reply With Quote
The Following User Says Thank You to balci For This Useful Post:
DaBoBo21 (03-06-2017)
Old 03-03-2017, 11:52 AM   #7
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
I had the same trouble installing mine. It isn't a faulty design on Greddy's part. The catback is not meant to be used with the stock donut gasket. Without it on the stock bolts with springs fit through just fine. Mine however still leaks because my stock front pipe's flange is rusting away.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following User Says Thank You to Detroiter For This Useful Post:
Old 03-03-2017, 11:53 AM   #8
finch1750
finch1750's Avatar
Damn I'm glad I live in CA. That sucks
Old 03-03-2017, 11:57 AM   #9
Detroiter
Detroiter's Avatar
Damn I'm glad Inlive in CA. That sucks
Welcome to the hell that is Michigan, home of cars rusting apart and coney islands
Raven
Old 03-03-2017, 12:24 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
How is it not meant to be used with the stock doughnut gasket? When I installed my Greddy Supreme SP catback I installed a new OEM doughnut gasket and re-used the factory spring bolts.
@mpross how did your install go?
Originally Posted by humfrz
I'm old and lazy
Old 03-03-2017, 12:36 PM   #11
Detroiter
Detroiter's Avatar
All I can speak for is mine specifically but there was no way in hell the midpipe was getting far enough onto the front pipe with the donut gasket there to even put the bolts through. It isn't flanged out like the stock one is. Also it came with 2 flat gaskets also. 1 for the midpipe to muffler section and I'm assuming 1 for the midpipe to frontpipe.
Raven
Old 03-03-2017, 12:40 PM   #12
Detroiter
Detroiter's Avatar
Just checked with Greddy's site and the Supreme SP specifically states to use the stock spring bolts and donut gasket while the revolution RS on the other hand does not. It probably has to do with the Supreme SP being a 2.5" system and the revolution RS being a 3".
Raven
The Following 2 Users Say Thank You to Detroiter For This Useful Post:
Clipdat (03-03-2017), DaBoBo21 (03-06-2017)
Old 03-03-2017, 01:27 PM   #13
Clipdat
Proud of BOXER
Clipdat's Avatar
Oh, that makes sense!
Damn, well they certainly don't make installing this easy, do they?
@thecarfilmer how did you install yours? Any issues?
I'm old and lazy
Old 03-03-2017, 09:06 PM   #14
Pekingduck
Drives: 4 wheels
But we get noise pollution tickets 🙁
Pekingduck is offline   Reply With Quote
Greddy Supreme SP Exhaust & Revolution RS Single Exhaust Evasive Motorsports Groupbuys 119 01-31-2017 02:53 PM
WTB: GREDDY REVOLUTION RS EXHAUST thecarfilmer Want-To-Buy Requests 0 10-30-2016 10:23 PM
Single Exit exhaust (Passenger Side Exit) SlammedSilly Engine, Exhaust, Transmission 25 06-09-2016 01:17 PM
Greddy Revolution RS Single Exit Exhaust Duhrell Want-To-Buy Requests 1 06-04-2016 07:25 PM
FS : Greddy Single Exhaust Revolution Rs (local pickup only) Chrisgalactic Engine, Exhaust, Bolt-Ons 36 03-07-2016 02:16 PM
