Old 03-01-2017, 01:45 PM   #2073
funwheeldrive
The axles on these cars are notoriously weak. I broke both sides while I was stock and was able to get them replaced under warranty. I'm actually surprised that the OEM replacements lasted after the Edelbrock.
You were stock and they still broke?!
The car wasn't even lowered?
Old 03-01-2017, 02:13 PM   #2074
Bfranklyn86
Drives: GT86 Harrop S/C
Originally Posted by Silverfox View Post
I was bummed I had to tow it off, but other than that I knew it was a possible eventuality.
I have 56k on the car (about 10k on the edelbrock). Making about 330whp on e-85.
Decent power. Was that the stock pulley and stock exhaust? I'd love to put that kind of power down with my TVS1320 and would be very happy to pay for replacement axles should they be required!
Bfranklyn86 is offline   Reply With Quote
The Following User Says Thank You to Bfranklyn86 For This Useful Post:
Silverfox (03-01-2017)
Old 03-01-2017, 02:15 PM   #2075
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Stock pulley, e-85, ace header, hks front pipe, ace catback.
8psi tune.
Approx 330whp 245 ftlbs
Silverfox is offline   Reply With Quote
Old 03-01-2017, 02:39 PM   #2076
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Yes, stock, but it's gone thru a number of hard launches for autoX and track days.
No, not lowered. The shop foreman kept trying to deny me because I was on coilovers, which were set to stock height. I had to drive home, grab a tape measure, grab the shop foreman and measure the ride height on a car they had on the floor to get it sorted.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Old 03-01-2017, 11:20 PM   #2077
Silverfox
Silverfox's Avatar
Well it wasn't the axle. Somehow my hardware and bushing on the rear driver side control arm came undone 🤔
Old 03-01-2017, 11:44 PM   #2078
BigFatFlip
BigFatFlip's Avatar
Sounds cheaper to fix than axles then?
Silverfox (03-02-2017)
Old 03-01-2017, 11:50 PM   #2079
Silverfox
Silverfox's Avatar
Hopefully. I should get the full story tomorrow. Still going to purchase a DSS axle for the future.
When the control arm broke I was only at half e-85/91. I haven't even felt what she can do yet 💥🤤
Old 03-02-2017, 05:12 PM   #2080
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
There are at least 2 versions of Edelbrock factory tunes that I know of: original release tune and the later released CARB tune. Would a smog test station be able to tell whether or not it is flashed to the CARB tune?
Old 03-02-2017, 06:45 PM   #2081
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
As far as i know they dont even really care or check as long as they can see he sticker. Then they just run the OBDII reader and if it passes all its checks then you are good to go.
I could be wrong though...
I'm probably wrong...
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following User Says Thank You to Xxyion For This Useful Post:
switchlanez (03-02-2017)
Old 03-02-2017, 07:46 PM   #2082
BigFatFlip
BigFatFlip's Avatar
My understanding is that the test station only checks for fault codes when doing the OBD2 check, so its not able to see the difference on tune. The CARB sticker is there so that the tech can correspond the EO number to the SC when doing a visual inspection.
Old 03-03-2017, 02:40 AM   #2083
silverlining
Just ordered this for my 2013 BRZ. I'm happy with the OFT stage 1 tune I have, but I was planning on adding bigger port injectors and a catless header to the bottom of the car when I install it. I also notice it comes with its own TMAP and MAF sensors [I think I goofed when I ordered a 3 bar MAP sensor right away...]. I'm less sure about how this would affect the tune I have. Should I just message Shiv immediately before installing or (provided I flash the ECU with the right injector settings) or should my stage 1 tune work for a while?
I guess a more general form of the above is, what exactly gets affected in the CARB ECU tunes for this supercharger? Sensor settings? Ignition timings? Etc.?
silverlining is offline   Reply With Quote
Old 03-03-2017, 03:26 AM   #2084
Bfranklyn86
8psi tune.
Thanks. Is that a catted front pipe? Do you know what your numbers were on 91/93?
Old 03-03-2017, 09:41 AM   #2085
Silverfox
Silverfox's Avatar
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
Catless dual resonated front pipe.
On 91 I was around
270whp 215ftlbs at 11psi (dynojet)
254whp 205ftlbs at 11 psi (mustang dyno)
The Following User Says Thank You to Silverfox For This Useful Post:
Bfranklyn86 (03-03-2017)
Old 03-03-2017, 10:20 AM   #2086
BigFatFlip
BigFatFlip's Avatar
Not entirely sure what you are trying to do here. I'll try to decipher.
-Are you working with Shiv on getting an OFT tune for the supercharger? I personally don't have an OFT but from what I know about it, your "stage 1" won't work. You will have to get a Edelbrock specific tune from Shiv.
-I don't know what tunes Shiv has given you, but I would hazard a guess he will have to adjust it if you are planning on using injectors and header. I would also guess that he can also tune it using either the TMAP that comes with the kit or any aftermarket MAP sensors. Again, you will have to get a custom tune from Shiv.
-The CARB tune is based on ECUtek and not OFT, so if you are trying to be CARB legal, you'll have to switch. As far as specific parameters? I have no idea.
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
