Old 03-02-2017, 05:28 AM   #1
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Question TOYOTA 86 Bonnet Hood Gas Strut
Does anyone know any Bonnet Gas strut that are cheaper than $63 or compatible versions for the FRS / Toyota 86?
Like this one on Ebay:
http://www.ebay.com.au/itm/151194941...84.m1436.l2649
FRS2017 is offline   Reply With Quote
Old 03-02-2017, 07:24 AM   #2
sqd
sqd's Avatar
Drives: '13 SWP GT86
63 AUD is like under 48 USD... Not calling you cheap, but come on :p I don't think you'll find, or want, a cheaper product than that
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 03-02-2017, 09:51 AM   #3
XK4
XK4's Avatar
Drives: 2017 BRZ, Pure Red with PP
Gas Strut Limitation
If you plan on doing your own wrenching you might want to reconsider installing gas struts. You will loose the ability that the stock support has of moving to the second position and holding the hood (bonnet) in an almost vertical position. Makes for very easy access to the engine bay.
Just my 2 cents.
XK4 is offline   Reply With Quote
Old 03-02-2017, 10:10 AM   #4
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Just my 2 cents.
Yes very true, and back when we were working on this project we found that kits like the one OP listed actually open the hood less than the stock position for the hood prop. So when we designed our kit we made sure our opening position was significantly higher:
[ame="https://www.youtube.com/watch?v=jEmVNpBaUGQ"]GrimmSpeed Engineering - FT86 Hood Strut Testing - YouTube[/ame]
Good luck to you though OP, as I couldn't build a decent kit at cost in my garage for that price.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
Old 03-02-2017, 10:58 AM   #5
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i used to have gas strut previous vehicles for look..but i dont install them anymore. much easier to work with just regular one.
Old 03-02-2017, 11:58 AM   #6
Brayden_23
Drives: Asphalt 2015 FRS
I have the Grimmspeed ones and can vouch for how wide it opens the hood. Makes working underneath there very easy. A bit out of your price range but they are good value
Brayden_23 is offline   Reply With Quote
Old 03-02-2017, 02:37 PM   #7
XK4
XK4's Avatar
Chase
Engineering
Thanks. Good to know.
Old 03-03-2017, 04:49 PM   #8
wrh3
billswebspace.com
wrh3's Avatar
Drives: 2017 Alfa 4C, 2019 Fiat 124 Abarth
Chase
Engineering
Another vote for Grimmspeed here.....some things you might be able to get out cheap on but this is not one I would want to go cheap on
Bill
BillsWebSpace.com
wrh3 is offline   Reply With Quote
Old 03-03-2017, 06:56 PM   #9
Gunman
Drives: 2019 Mazda Miata RF
Grimmspeed!
Old 03-04-2017, 01:00 AM   #10
FRS2017
Enthusiast 86
FRS2017's Avatar
Ok thanks for the feedback chaps...........will think about it
Old 03-04-2017, 03:25 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Just my 2 cents.
I have the opposite thought. The stock support runs right the middle of everything and gets in the way tremendously imo. And like mentioned the GS raise the hood higher then the first position, not sure about the second but it is plenty of clearance. Need anything more and it would be time to just take the hood off
**TOM'S Japan HOOD Bonnet Dampeners - First 3 Pieces in USA! ONLY 1 LEFT at 468POWER! 468Power Engine, Exhaust, Bolt-Ons 11 09-17-2013 10:10 AM
Hood/Bonnet Lifting At Speed Kefuddle Issues | Warranty | Recalls / TSB 14 06-14-2013 05:44 AM
Zeta Performance - Hood/Bonnet Damper Kit ZetaPerformance Exterior Parts - The Rest 56 05-03-2013 03:27 PM
Zeta Performance - Hood/Bonnet Damper Kit ZetaPerformance Cosmetic Modification (Interior/Exterior/Lighting) 6 03-28-2013 06:14 PM
FS: Gimmick Motorsports Black Hood/Bonnet Damper kit green_comet Australia Classifieds 1 11-06-2012 09:59 PM
