Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 03-02-2017, 08:48 AM   #15
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
Originally Posted by Esseff View Post
Spark plugs require the whole underside if the engine bay and exhsust manifold removed. 3hr job!
Who decided THAT was a good idea?
That's different though. Problems as a result of choosing to use a boxer engine are something that someone should recognize and research prior to purchase. The fuel filter thing is just an idiotic decision on the OEM's part. There's nothing stopping them from putting it in a more accessible location. Heck, I might get some AN fittings the first time I have to do mine and do it for them.
Yardjass is offline   Reply With Quote
Old 03-02-2017, 10:24 PM   #16
ZZT86
ZZT86's Avatar
Drives: BR86
You cannot remove the in-tank filter & make do with an external as easily as you think. If it's anything like those found on the Camry & Celica which I've done they're a canister filter housing which holds all the in-tank components in place, ie: fuel pump, fuel pickup strainer, sender unit/float plus wiring. It's an easy job to do just takes more time.
As for the plugs - well I've heard with the right tools & patience it can be a DIY, obviously smaller hands help.
ZZT86 is offline   Reply With Quote
Old 03-03-2017, 06:11 AM   #17
Mr_Jay
Drives: Toyota 86 GTS
Would it void warranty if this work was performed by another mechanic that wasn't Toyota? Eg: Subaru specialist?
Mr_Jay is offline   Reply With Quote
Old 03-05-2017, 05:01 AM   #18
ZZT86
ZZT86's Avatar
Drives: BR86
I can't see it being an issue, just keep proof of plugs & that it was done, ie: Tax Invoice from mechanic. I will attempt to do this myself when the time comes as I do with all servicing.
Old 03-08-2017, 05:22 AM   #19
Bodalenko
Steve Bodalenko
I was warned of this service by the manager of the Toyota dealer I purchased from. Said he's only heard of one 86 having it since they were released.
If it's done at 60 months it's after the warranty period anyway, 3 yr warranty here in Oz, and there wouldn't be too many owners doing 96,000kms in the warranty period. 32,000k's a year for three years would be a mighty effort.
I'm currently at 23,000k's after 4 years, less than 6,000k per year so if my usage stays the same I'm likely to be at just 35,000k's when this major service is due.
There's a how to on the forum re the plug change and mentions the special tools you need.
Bodalenko is offline   Reply With Quote
Known Major Issues I should know about.... Darkone BRZ First-Gen (2012+) — General Topics 41 01-04-2017 09:51 PM
Major Mods.. Jaden Scion FR-S / Toyota 86 GT86 General Forum 72 08-28-2015 10:16 PM
Where Should I Take My BRZ for 30k Major Service? (SGV Area Preferably?) Choco Southern California 2 01-13-2015 06:50 PM
AZP Aug/Sep Discounts on Major Service & TPMS Cloning! AZP Installs NY / NJ / CT / PA 0 08-17-2014 09:53 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
