Old 03-01-2017, 08:34 PM   #1
Kutanks
Drives: 2013 Firestorm 6MT,2005 Saabaru 5MT
Potential new FR-S owner
Hey guys,
I just got back from putting a (refundable) deposit on a used 2013 red FR-S 6MT with 35,000 miles.
Car drove fine, nothing really stood out compared to other Twins I have driven. Going to go back on Saturday with pre-approved financing from my credit union and look at the car in the daylight.
They are asking for $15500 which is lower than most, although it's winter still and this is a small used lot not a new car franchise
Mods include CF shark-fin, Quad exhaust tips, tinted windows. There's also a sub-installed in the trunk which I will either have them keep for a cheaper price or just sell...it takes up pretty much the whole trunk
Is this a good deal for a late 2013 model? I will be having them take the car to a Toyota dealer for an inspection but I figure I can knock off a few hundred if they remove the aftermarket stereo
Hope to have one of my own very soon!
I've been looking for awhile and all the good deals for these seem to be automatic so finding a manual at this price seems almost too good to be true
Kutanks is offline   Reply With Quote
Old 03-01-2017, 08:41 PM   #2
Look like you have covered all the bases and the price is pretty good for your region. If it checks out at inspection you should be driving it soon.
Old 03-01-2017, 09:20 PM   #3
stevesnj
stevesnj's Avatar
Watch this guy above, he's from Canada and put's the letter "u" into words that shouldn't have them!
My 2016 Build thread
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
kakacarrotcake (03-08-2017), ktulu7 (04-27-2017)
Old 03-01-2017, 09:59 PM   #4
Kutanks
Yeah I've been doing my research. This is a great resource, I've wanted one since they've came out and now that I have been saving and building my credit for two years after college it's time.
This is going to be my second Subaru that isn't badged as such! Lmao
Old 03-01-2017, 10:15 PM   #5
Sounds good ......... geeeeeeet itttttttt!
Old 03-01-2017, 10:22 PM   #6
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
make sure all the recalls were taken care of. Wasn't there something about one being absolutely imperative and they would not do it once it was out of warranty? Didn't this just come up recently? Only way I would know about it is reading it on here.
why? is offline   Reply With Quote
Old 03-01-2017, 10:44 PM   #7
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Saabaru owner?
Sent from my SM-G930W8 using Tapatalk
daiheadjai is offline   Reply With Quote
The Following User Says Thank You to daiheadjai For This Useful Post:
finch1750 (03-03-2017)
Old 03-01-2017, 11:26 PM   #8
Kutanks
Yes I have a Saabaru (no turbo though) lol
What's the important recall? If it's a recall don't they have to fix it out of warranty? Or do you mean TSB?
Old 03-02-2017, 01:15 AM   #9
I'm not aware of any recalls for US versions of the FR-S .......
Old 03-02-2017, 10:58 PM   #10
slowautoxr
Drives: Subaru 2.5RS
That's a pretty good deal. I paid similar money for mine with under 25k miles.
Charles
2013 FR-S
slowautoxr is offline   Reply With Quote
Old 03-02-2017, 11:12 PM   #11
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
the 2013's had a TSB for cam sprocket issues and ecu fault code p0016-p0019. I just got mine fixed under warranty. Barely. 52k miles 4 years. cutoff is 60k 5 years. And it's a very common issue with the '13s around the same miles as mine. My dealer even said so. If I was in the market, I would avoid the '13s like mine unless the tsb was performed or something.
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 03-02-2017, 11:18 PM   #12
Kutanks
Well I am hoping for the best on the ppi. This is my first RWD car so I am easing into it
Cars I have previously I've had/ driven
2001 Sienna (dad totaled)
2001 Prius (first car that I drove, was a beater for a few years but junked due to rust and my sister's neglect)
2004 Prius (worst car ever I would have rather had the 2001 but my mom gave me the '04 eventually the battery died and it wasn't worth fixing)
After those miserable piles I started buying my own cars:
1999 Maxima Se (miss it would love another)
2005 Saabaru 5MT (current ride)
I love that the FR-S is a Toyota and a Subaru at the same time because I'd probably be going for a newer WRX if the twins didn't exist. This way I can keep my Saabaru since it's only at 100k
Old 03-03-2017, 12:29 AM   #13
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
They made non turbo Saabaru's?
That was an issue for early 2013s. And the issue arrived on other twins within a few thousand miles. Whole common enough to be known there are plenty of 2013s on the road unaffected. If it is in the TSB VIN range then maybe something to consider
Old 03-03-2017, 05:56 AM   #14
There are two FRS recalls:
1) Some ATs had a wire off that allowed you to remove the key while running. If you can't pull your key out then you are OK.
2) Recall from Southeast Toyota only. Added accessories not indicated on weight capacity sticker so sticker reads 5 to 10 pounds light.
One for Subaru:
1)Engine Control Module Reprogramming Vehicles Registered in the States of
CA, CT, MA, MD, ME, NJ, NY, OR, PA, RI, VT, WA. Reprogram ECU the monitor engine coolant temperature better and turn CEL on if not reaching operating temp.
None earth shattering. If you bought your car from a dealer and it is registered through Toyota/Subaru you will receive notifications of any recalls.
TSBs are NOT recalls in any form. They are simply instructions to the Techs on how to fix known issues. The car needs to be exhibiting the problem when brought in for them to fix it. Even then they are in no way forced to do the work even if in warranty. You can not just take your car in and say "there is a TSB so fix it" based just on the TSB ( although some dealers have been reported to do it).
http://www.ft86club.com/forums/showthread.php?t=21868
humfrz (03-03-2017), stevesnj (03-03-2017)
Potential Owner - FRS/BRZ ABS question DINOsaur51 Tracking / Autocross / HPDE / Drifting 4 11-07-2016 12:07 PM
Potential Future BRZ Owner tyrantcf BRZ First-Gen (2012+) — General Topics 4 04-04-2014 08:05 PM
Potential FRS owner - query CoolHandLuc Scion FR-S / Toyota 86 GT86 General Forum 21 03-30-2014 01:01 PM
Potential New Owner Here declivity NY / NJ / CT / PA 4 06-27-2012 11:21 AM
Potential owner questionnaire DMDZK BRZ First-Gen (2012+) — General Topics 65 02-28-2012 11:22 AM
