Drives: 2016 BRZ
Used AP racing Big Brake Front and Rear Kit
Hi All,
Okay, this is the full kit that was on my gt86 overseas. Front is 14 inch discs (356mm), 6 piston caliper, comes with the brake pads, and the goodridge stainless steel brake lines. The calipers come with all bolts and adapters. Rear is 13.5 inch discs (343mm), 4 piston caliper. They come with the brake pads, and the goodridge SS brake lines. The calipers come with all bolts and adapters. First of all, I know the caliper finish looks a little beat up. This was caused by the guys that took them off...overseas...obviously they weren't careful. Nevertheless, the brakes are 100% fuctional, and only have 1,000 miles on them. And this is exactly the same kit I am using on my BRZ I got here. It worked so fenomenally well, that I had to get another kit for the car I bought here. This is a bolt on kit, and it comes with all the bolts and adapters needed to fit your FRS/BRZ. Now, there is a catch. As far as I know, these will fit perfectly when using 19 inch wheels. However, if you have 18 inch wheels, I cannot guarantee they will fit. Maybe yes, maybe no, it will depend on the dimensions of your wheels. The pads, as you see on the photos, have 98% of life left. The discs are drilled, 2 piece discs. Don't mind the rust on the discs, that will instantly go away once you brake for the first time. For the front and rear complete kit as seen on the photos, $1,500. Does not include shipping. Pictures: |
#2 |
Drives: MR2, 2014 SWP Limited BRZ
Damn if these are still here after i come back from vacation - I might pick them up.
Do you know which specific model this AP kit is? Want to find the caliper template. |
#3 |
Drives: 2016 BRZ
#4 |
#5 |
Drives: BRZ, 2 WRXs, 818S, motorcycles, etc
PM sent.
#6 |
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
pming
#7 |
Drives: 2016 BRZ
Kit sold! Thanks for all your pm guys!
| FS: 6-pot/4-pot Front/Rear Big Brake kit by RR Racing | Kostamojen | Brakes, Suspension, Chassis | 1 | 10-04-2016 08:10 PM |
| Megan Racing Front/Rear Sway Bars at Redline360 | Redline360 | Brakes, Suspension, Chassis | 24 | 12-19-2014 11:12 AM |
| Big break kit rotor rubing on Buddy Club P-1 Racing LCA - Front | aquaman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 11-13-2014 09:41 PM |
| Racing Brake Front and Rear Kits | STX118 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 09-16-2014 11:03 AM |
| FS: AP Racing 6pot Front / 4pot Rear(RED) | CanibeatNoel | Brakes, Suspension, Chassis | 13 | 01-26-2014 03:44 AM |
