Old 03-01-2017, 09:35 AM   #15
Freddy@PTUNING
Freddy@PTUNING's Avatar
Drives: Honda S2000 & Acura RSX Type-S
Send a message via AIM to Freddy@PTUNING
Glad you are happy with the results Dave!
Freddy@PTUNING is offline   Reply With Quote
Old 03-01-2017, 12:00 PM   #16
Manic
Is not fast.
Manic's Avatar
Drives: 2014 Whiteout M/T
Kinda related, would there be a shop similar to Spencer Fab but more so for the transmission? I'm getting really tired of the synchro grind which Toyota refuses to address, and I don't know when I'll be able to get a hold of a 2017 transmission.
"America is all about speed. Hot, nasty, badass speed." - Eleanor Roosevelt, 1936
Manic is offline   Reply With Quote
Old 03-01-2017, 01:05 PM   #17
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Spencer does have a trans swap available
Jrdad is offline   Reply With Quote
Old 03-01-2017, 01:48 PM   #18
Manic
Is not fast.
Manic's Avatar
I had seen that they had an option for a T5 swap, but I was looking more along the lines of a 6-speed reinforcement replacement like they have with the stock 4.1 FD diff. I like the AZ6 in our cars, I just wish I had gotten one of the beefier ones. I'll probably get a 4th to 5th gear synchro grind once a week which is pretty upsetting.
Guess I'll just keep an eye out for the reinforced 2017 transmissions.
Old 03-01-2017, 01:59 PM   #19
fika84
fika84's Avatar
Why does this only apply to boosted 86s?
I'm rocking a 4.88 in an IS300 diff for NA Highly recommend it. 4.56 might be a little better suited for track (depending on track layout), but the 4.88 is a blast on the street.
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
jcw99 (08-30-2019), why? (08-31-2019)
Old 03-02-2017, 11:13 AM   #20
Simon86
Drives: 13 Scion Frs
Would doing this swap mess with your speedo reading like if you were to swap to bigger wheels and tires?
Simon86 is offline   Reply With Quote
Old 03-02-2017, 11:29 AM   #21
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I don't believe so, just flipped through the block diagrams and the only speed sensors are at the wheels so changing F/D won't mess up your speedo.
ineedyourdiddly
Old 03-02-2017, 05:28 PM   #22
lee1rbc
lee1rbc's Avatar
I have wondered about this. I was datalogging first gear after upgraded my wheels 225/45 and while I am getting better traction it goes threw first so fast that my turbo never breaks 6.5psi. Once I shift to 2nd it goes to 10.5psi. Basically there just isn't enough resistance in first to reach full boost. My car makes 12h.p. per psi, so I could gain 30 to 40hp in first with 3.91s.
2013 BRZ Limited current mods: TD05 20g turbo - Invidia over pipe and catted down pipe - Magnaflow catback - Enkei Fujin wheels. BFG comp 2 A/S 225-45-17.
lee1rbc is offline   Reply With Quote
Old 03-02-2017, 05:45 PM   #23
mrk1
Drives: Sterling BRZ Ltd
Final drive change does not effect the speedo. The speedo reads off wheel speed sensors. If you use the dash gear indicator it can be off but a tune can be programmed to compensate for this.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-02-2017, 05:59 PM   #24
bababooey
Drives: BRZ SWP Limited -6MT
so changing it (from stock to 4.88) would put the engine at 7500 (redline) but be traveling less than 60mph (or whatever the top of stock 2nd MT is)? thus quicker acceleration? OR does it go the opposite direction turning lower rpms in 2nd going 60 mph.
bababooey is offline   Reply With Quote
Old 03-02-2017, 06:19 PM   #25
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Interesting... wonder what 2nd gear tops out at now
Cockatoo is offline   Reply With Quote
Old 03-02-2017, 07:40 PM   #26
mrk1
So in a NA car going numerically higher then stock (4.10) will result in quicker acceleration. Centrifugal SC can also benefit in this change since these SC need RPM.
In the example of this thread the car is turbocharged. In this case going lower then stock gives more time in gear, this is advantageous for a turbo as that means more time to build boost and stay on boost and there for you go faster.
If you go numerically higher on a turbo car you will still accell quick but your really selling yourself sort by not letting the turbo do its job. You'll blow right through that rpm range where the turbo is happiest.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
bababooey (03-03-2017)
Old 03-02-2017, 07:44 PM   #27
mrk1
There are plenty of RPM/MPH calculators out there online. Enter your trans ratios, tire size, and final drive ratio.
The Build Thread
Old 03-02-2017, 09:41 PM   #28
nocoolname
Only the guts of the MK3 supra can be swapped into a BRZ or IS300 case then mounted in the car. The MK3 case uses different style mounts.
Does the BRZ use a 8" ring gear as well? I read somewhere once of being able to use the 8" gear sets for a Toyota pick-up in the IS300 housing. If the pinion shaft was the same length and spline for the BRZ flange then it could be some cheap gear swaps.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
The Following User Says Thank You to nocoolname For This Useful Post:
jeepmor (05-11-2022)
IS300 M85/M98 rear diff - does it fit? PantsDants Engine, Exhaust, Transmission 39 03-28-2017 08:28 PM
Lexus is300 diff swap M98 3.91 ogrowup Engine, Exhaust, Transmission 5 02-28-2017 10:45 AM
Lexus IS300 Second Car - Thoughts? somecrazyazn Other Vehicles & General Automotive Discussions 48 05-05-2014 05:47 PM
vs Lexus IS300? SteelReign FR-S / BRZ vs.... 38 03-27-2012 11:48 AM
