| CANADA Canada |
Good Job Subaru!
Drives: '18 440i GC, '24 CX-50 Meridian
Dealer Rustproofing a good idea?
Hello fellow Canucks,
I'm sure this has been beat to death before, but I've done my searching on the forums and cannot really find a concise answer. So, here goes: While putting in the order for my BRZ, the dealer offered me a permanent (wax-based, IIRC) rustproofing for around 750 bucks. I told them I would consider it. So now I am here, considering it. I know that the wax based solution from them involves no drilling, and has a lifetime warranty, which is good. But I'm debating if its worth it. Here is my situation: - Drive around 25000 kms per year, and will be driving the car all-year-round. - Live in Thornhill (Vaughan) and commute into Toronto every day, so plenty of salt on the roads for sure. - Planning to keep the car for a long time. I know that the cars come from the factory with an anti-corrosion coating on the underside of the vehicle, and that the body panels are dual-side galvanized steel. (Check here for reference, click on the Exterior tab) So, should I even worry about any kind of undercoating at all? I've often heard that regular washes at a touch-less wash with the undercarriage spray (around twice a month) will help with keeping the car minty. Krown is out of the question because drilling holes throughout the entire car is no-bueno. Thanks! |
#2 |
Drives: 13 mt fr-s
protect your investment if your going to drive it in the winter...
| The Following User Says Thank You to scottman For This Useful Post: | JBezugs (02-28-2017) |
#3 |
Not a troll
Just wash the car regularly at a place that can do the undercarriage. I have no rust proofing and the only rust is on untreated bolts. That's two full winters of driving, too.
| The Following User Says Thank You to Cole For This Useful Post: | JBezugs (02-28-2017) |
#4 |
Milton 86 Club
Drives: Lexus IS350, GT86, Mini Cooper, CBR
I agree with @Cole - I'm 3 winters in, daily driving for 100k kms now and no rust underneath or elsewhere. Just wash regularly and keep the salt off
| The Following User Says Thank You to Rakshaa For This Useful Post: | JBezugs (02-28-2017) |
#5 |
Wes
I got it, I thought why not. But it's a sloppy job. Tons of overspray. They missed some sports and covered other spots that were supposed to be left alone, like the suspension moving parts
| The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | JBezugs (02-28-2017) |
#6 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | JBezugs (02-28-2017) |
#7 |
Good Job Subaru!
Thanks for all of your input guys, between this, my own reasoning against it, and some snooping around the web, I've decided not to take the bait.
| The Following User Says Thank You to JBezugs For This Useful Post: | Rakshaa (02-28-2017) |
#8 |
Drives: Burz
I'd recommend the following
-Don't pay dealer, 700 bucks gives you around 6 years of annual rustproofing -Drill holes, ensures a proper job is done and full application |
#9 |
Drives: wrb brz
Had mine done with Krown guy used factory access points then drilled only 2 holes total to do the rear inner fenders, otherwise he said you can do no holes and cover 98%of the car
| The Following User Says Thank You to bass_114 For This Useful Post: | wparsons (02-28-2017) |
#10 |
Drives: 2014 scion frs
I had it done on both my current vehicles at the same toyota dealer. One time application only with what looks like a yellowish, resin or wax in the engine compartment and black coating on the frame. My Frs is not winter driven but my 08 Tundra certainly is. I plan on keeping my vehicles until fall apart so I found that the dealer applied stuff (they did an excellent job) gave me a head start on my own rust prevention program.
I get underneath every spring and hose the sand/salt out of there, let it dry, then hit any rust spot with Rust Check (green can). My frame looks great, better than a 4 year old chevy that has been krowned yearly. Have a look at a vehicle they have done and see what sort of job they did. Plus lifetime warranty. Rust never sleeps, unfortunately. |
#11 |
Huge E85 fan!
Drives: 2016 Scion FRS
[ame="https://www.youtube.com/watch?v=ZCT3jm1A-5U"]Seinfeld - The Dealership - YouTube[/ame]
| The Following User Says Thank You to guybo For This Useful Post: | JBezugs (03-01-2017) |
#12 |
Drives: 2015 FRS
Krown is amazing. Compare a 10 year old car to another 10 year old krowned sprayed car and you will be amazed. They drill holes for a reason.
| Is this a good idea?.. | Chimera | Scion FR-S / Toyota 86 GT86 General Forum | 69 | 08-18-2016 05:51 PM |
| Is it a good idea.. | Droid | BRZ First-Gen (2012+) — General Topics | 64 | 11-08-2014 05:14 PM |
| Is it a good idea to have both DRL and Headlights on at night? | Weeber | BRZ First-Gen (2012+) — General Topics | 7 | 11-13-2013 07:31 PM |
| Is going all catless on a na fa20 motor such a good idea? | Astroboy | Engine, Exhaust, Transmission | 105 | 09-14-2013 09:48 PM |
| Considering selling my BMW 335i to get FR-S... Good or Bad idea? | iBurnTires | Scion FR-S / Toyota 86 GT86 General Forum | 112 | 08-02-2012 08:46 PM |
