Old 07-28-2015, 02:30 PM   #15
migueralliart
migueralliart's Avatar
Drives: 2013 Firestorm FRS
Originally Posted by weederr33 View Post
When you got your side skirts and rear spats, did you need to sand them down or have any fitment issues? I'm going to be purchasing some soon and was curious. Also, how exactly did they go about installing them? Any tips? Thanks!
I think the body shop did some prepping but it wasn't a lot. He painted them all red and then taped and painted matte black for some sections.
I did the install at home and have never done any body work but I'm a skilled mechanic so it wasn't that hard. Only drilling required is for the front bumper to attach brackets and all you need is a hole saw adapter the right size. The markings are behind the bumper so you don't even need to measure the drill guides are there too.
There is only one hack thou. When you install the side skirts you need to use a dremel to cut a line in your fender inner plastic or mud guard so that it sits perfectly even. I'll see if I can take some pics later.
migueralliart is offline   Reply With Quote
The Following User Says Thank You to migueralliart For This Useful Post:
weederr33 (07-28-2015)
Old 07-28-2015, 02:33 PM   #16
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Thanks! Did you use 3M tape for attachment?
MS, CSCS, TSAC-F, CPT
weederr33 is online now   Reply With Quote
Old 07-28-2015, 02:48 PM   #17
raven1231
I got mine from xcessmotors on ebay. I think he sells it but it is bundled with something else now.
If you search for T style scion frs or TR-D wing frs it will show up. I paid about 80$ shipped.
That's another thing I forgot to add, if anyone cares to know the total cost of the kit ended up being:
580$ for the front kit painted
140$ for the TRD side skirts
81$ for the bumper aprons
200$ for painting
80$ rear wing plus 65$ for paint
1 day of work installing everything.
So 1146$ for everything installed if you do it yourself. Not bad
Not bad at all! I might have to get this!
Old 07-28-2015, 05:15 PM   #18
MemphisR
Memphis
MemphisR's Avatar
Drives: 1989 MR2 S/C, 2014 Scion FR-S
Did you use the brackets for the Nur spec? or just double sided tape?
"It's ok... It's not structural."- Mikey
MemphisR is offline   Reply With Quote
Old 07-28-2015, 05:22 PM   #19
migueralliart
The Nur Spec uses brackets to clip in. It has push clips on the underside of the car and it comes with tapes pre-applied and strips to pull them out once in place. It really isn't that difficult. If you can remove the bumper the rest is very easy.
Once you remove the bumper and drill the holes you install the clips in place (with screws) and they stay with the bumper. I clipped in both sides then clipped the center section. After that I installed the bumper and proceeded with putting all the push in clips and removing the adhesive strips with care.
Old 02-28-2017, 11:53 PM   #20
Nonstopper0
Nonstopper0's Avatar
Drives: 2013 Grey Varis Widebody FR-S
i cant find that front lip on japan parts? what is it called exactly?
Nonstopper0 is offline   Reply With Quote
Old 03-01-2017, 01:09 AM   #21
weederr33
weederr33's Avatar
Nur Spec front lip. or Toyota aero. It's hard to find but you can find it on Nigel JDM. Japan parts doesn't have it anymore to my knowledge. Then again... I'm selling my front lip if you're interested.
Old 03-01-2017, 10:36 AM   #22
ChinatownDragon
Drives: 2016 Ablaze FR-S MT
How much are you selling it for?
ChinatownDragon is offline   Reply With Quote
Old 03-01-2017, 12:38 PM   #23
weederr33
weederr33's Avatar
PM me, bruv
Old 03-01-2017, 02:06 PM   #24
mclovin85
mclovin85's Avatar
Drives: scion fr-s
Thanks for the feedback!
Had the time to clean the car and install the front end. Need new rims pretty bad.
this is a clean build.. kinda wanna get the same kit now, where did you purchase the kit? and does the exhaust tips make a difference in noise?
mclovin85 is offline   Reply With Quote
The Following User Says Thank You to mclovin85 For This Useful Post:
MisterSheep (04-09-2017)
Old 04-09-2017, 08:15 PM   #25
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Looks a lot like how my car does now.. still working on getting the rear situated.
Instagram: trevor.parque
Old 04-09-2017, 08:17 PM   #26
MisterSheep
Killed Scion
I would ask around and keep your eyes open for the Nur-Spec stuff. A lot of it, especially in white, have been completely sold out due to the parts being discontinued. I got some of my TRD parts, like the sideskirts, from japanparts.com. I would try japanparts.com, 86worx.com, or nigeljdmparts.com.
Old 04-09-2017, 08:20 PM   #27
weederr33
weederr33's Avatar
I've got the Nur Spec front lip for sale if you're interested.
Old 04-10-2017, 01:52 PM   #28
mclovin85
mclovin85's Avatar
Drives: scion fr-s
im down! are you just getting rid of the front lip? what about the side skirts and back spats?
(IN STOCK) Rocket Bunny front bumper, fenders, diffuser, side skirts, wing BenSopra Motorsport USA Exterior Parts - The Rest 6 04-01-2015 07:23 PM
Forcewerkz Scion FRS Front Lip, Side Skirts, and Rear Spats premiumsport14 Exterior Parts - The Rest 3 07-04-2014 04:08 AM
Johnmotoring Side skirts, front lip, and rear aprons SliverBrz Exterior Parts (Aero, Lighting, Etc.) 33 02-21-2014 06:38 PM
STi Style Carbon Fiber Front Lip/Side Skirts/Rear [BRZ] JPxM0Dz Cosmetic Modification (Interior/Exterior/Lighting) 31 12-03-2013 11:57 PM
Polyurethane Front Lip,Side Skirts and Rear Spats Perry Cosmetic Modification (Interior/Exterior/Lighting) 11 11-09-2013 04:44 PM
