Drives: Argento FR-S
STANCE V1.0 Rear LCA
Price: $300
Location: Chino Hills, CA Willing to ship at buyers expense. Message me to purchase. ![]() "STANCE Adjustable Lower control arm is made from billet aluminum for strength and durability. Lower arm is used to adjust camber and the range is negative 1deg ~ 6deg. STANCE uses Aurora Rod ends. The most important part of aftermarket suspension links are the rod ends. Aurora spherical rod ends are one of the most expensive and high quality rod ends on the market, and for good reason. Aurora ends are used in both military and NASA Applications. There is no other rod end that can match the quality, precision and durability of Aurora's rod ends. Stance uses Aurora's 3pcs billet rod end bearings. Aurora bearings use a sintered steel ball to handle extremely high loads. Rod ends feature special chemical bonded PTFE liners for smooth operation, less noise, and long life. The rod end housings are heat treated and zinc coated for strength and durability. STANCE LCA is designed to raise the hub mounting point about 20mm,compared to stock, which lowers the car about 25mm. This allows for longer stroke dampers found on the STANCE FR-S application, and have more height adjustment range. This design is especially helpful for 1way height adjustable coilovers like KW, which loses stroke as you lower the car."
#2 |
Drives: ZN6
Interested check inbox
#3 |
BUMP
#4 |
Drives: 2014 red subaru brz
yo0ur lca
pmed
#5 |
Drives: 2016 scion 86
| Houston, TX: Stance Rear LCA | The Slow One | Brakes, Suspension, Chassis | 4 | 01-05-2014 11:23 PM |
