Old 02-25-2017, 10:27 PM   #463
Originally Posted by switchlanez View Post
I think those were due to installation error. One of the installation steps is very error prone as described in the poll I linked above.
No, it's because they're pieces of shit.
Old 02-25-2017, 10:33 PM   #464
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Not mine and everyone who voted in that poll, apparently.
The Following User Says Thank You to switchlanez For This Useful Post:
stevesnj (02-26-2017)
Old 02-25-2017, 10:48 PM   #465
That's nice. Good for you guys.
Old 02-26-2017, 03:53 AM   #466
switchlanez
Old 02-26-2017, 04:11 AM   #467
Maybe a bit harsh but after studying the issue firsthand and seeing it play out in several installations, I've come to the conclusion that the design is for shit. No amount of opposing consensus and polling is going to convince me otherwise.
Opinion does not trump physics.
Teseo (02-26-2017), weederr33 (02-26-2017), xxBrun0xx (02-26-2017)
Old 02-26-2017, 11:36 AM   #468
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I will agree the designed seemed lazy. I'm no engineer (more of biomechanics), but it seems like an easy way to shorten the throws. But I'd rather them have done what the JDM short shifters did. Not that they reduce throw or height much either. I've just been putting off taking mine off.
MS, CSCS, TSAC-F, CPT
Old 02-26-2017, 01:01 PM   #469
I remember you saying yours came loose again. Did it loosen but quit backing out at some point because of the loctite?
Old 02-26-2017, 01:30 PM   #470
Teseo
Drives: frs
What if use epoxy?
Old 02-26-2017, 01:44 PM   #471
weederr33
weederr33's Avatar
It loosened up despite having loctite on it. However, I didn't apply enough loctite to the end of the bolt like I should have. It hasn't come loose since, but I still don't like the feel it gives to the throws honestly.
The Following User Says Thank You to weederr33 For This Useful Post:
Ultramaroon (02-26-2017)
Old 02-26-2017, 02:00 PM   #472
Originally Posted by Teseo View Post
What if use epoxy?
The part wedges on crooked which causes the cap screw to bind. Why fuck with parts that don't fit?
Spend a few extra bucks and get a proper short shift lever.
Old 02-26-2017, 02:05 PM   #473
Teseo
Drives: frs
Enlight me, which one and why. Senpai
Old 02-26-2017, 02:05 PM   #474
weederr33
weederr33's Avatar
At some point, I'd like to get the STI JDM short shifter. Just expensive :s
Old 02-26-2017, 02:23 PM   #475
switchlanez
The screw cap wouldn't fit straight and torque at first but I reread the instructions closely, set the O-ring, and was able to torque it. I refused to settle til I heard my torque wrench click which is a good check to ensure it won't back out.
Didn't even apply any Loctite, added 1k+ miles and still no issues. That's my physics, not opinion.
Old 02-26-2017, 02:25 PM   #476
The only two that I know of are the STI JDM unit and the kartboy. I don't have either because I'm working on a custom one. More like I have something half finished and will get around to it someday.
The decrease in leverage will be about the same. It will feel the same as your current assembly. I understand the hesitation. It gets old having to yank so hard.
Stock throw is fine to me. It could be a little bit shorter but then there would be even more complaints about hard downshifts and missed second gear shifts when cold.
sato (02-26-2017), Teseo (02-26-2017), weederr33 (02-26-2017)
TRD Quickshifter lovebeingbleu98 Brakes, Suspension, Chassis 3 02-13-2014 12:14 AM
Amazing Wax geb2391 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-12-2013 04:42 PM
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 08:23 PM
Concept-Three-LED's DRL's are AMAZING! soros151 Cosmetic Modification (Interior/Exterior/Lighting) 4 11-09-2012 01:42 AM
