Old 02-22-2017, 07:40 PM   #99
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Maybe they increased the spring tension to compensate for the spoiler weight?
Even if it takes 20 pounds though I can't see you damaging the spoiler. It isn't made of fine china or paper mache.
They did increase the shocks pressure, according to the comparative document that leaked out a while ago. Because of the spoiler weight supposedly.
nico_rsx is offline   Reply With Quote
The Following 2 Users Say Thank You to nico_rsx For This Useful Post:
BRZ FTW (02-22-2017), Tcoat (02-22-2017)
Old 02-22-2017, 08:15 PM   #100
2017-BRZ
Drives: 2017Crystal White Pearl BRZ Limited
Originally Posted by KB_BRZ View Post
UPDATE:
So the pandora app on the radio unit doesn't work through bluetooth unless it is plugged in via USB. You can run the pandora app on your phone and play it on the radio unit through the bluetooth audio source.
Still one of the things I dislike about the car because the name/artist only stays on the first song played. As songs end and a new one is played, the screen is like frozen on the first name/artist.
I have an LG V10 phone and all the apps work via bluetooth. Caveat is I have to make sure bluetooth is ON BEFORE starting the engine..
2017-BRZ is offline   Reply With Quote
Old 02-23-2017, 12:58 AM   #101
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Originally Posted by johan View Post
It's dramatically different than the older cars. I never had a problem with my '15 FR-S. These '17 BRZs, there's something weird about the spoiler being on there - it requires a bizarre amount of force to get it to latch.
Yep. I thought my trunk latch was locked shut the first few times I tried closing the trunk (on my BRZ). The trunk lid would just bounce off it and not shut. Seems to be not as bad recently, like it is slowing working in.
Originally Posted by thomasmryan View Post
Still trying to figure out this dip thing ppl speak of...
Ben Harper came to town and played in the Tennessee theater. Near the end of the show, he set the microphone down and sang accapello. There was that one drunk idiot in the crowd that yelled out 'free bird'. The torque dip hype is free bird.
Let me clear up your perceived hype with a visual. There are countless dyno graphs out there that illustrate the dip in the torque curve.
Here are my dyno graphs from both my 2013 FRS (dotted) and 2017 BRZ (solid) when they were stock. If you are not feeling that dip in the torque curve in your car, then I guess you got one of the magical builds that doesn't have it
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
funwheeldrive (02-23-2017)
Old 02-23-2017, 01:05 AM   #102
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Because you can't feel it at partial throttle. During normal driving most people won't realize it's there.
Old 02-23-2017, 01:11 AM   #103
Andrew025
Andrew025's Avatar
Originally Posted by BRZ FTW View Post
I complained also. The radio is worse than my '15 but, you have a good point. I've resolved to just change it out. Now to source a full length series yellow dash trim...
Try changing the vocal imaging or whatever they call it to +8.
It helps a lot with the sound.
The Following User Says Thank You to Andrew025 For This Useful Post:
BRZ FTW (02-23-2017)
Old 02-23-2017, 01:39 AM   #104
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I don't know, I feel it everyday driving to/from work. Well, I did, the car is tuned now and the dip is gone.
Maybe that is it. Folks that have not driven a tuned car might know any different and the torque dip feels normal, or is not even felt like you said.
Anyways this horse has been bludgeoned enough I'd say...
Old 02-23-2017, 02:37 AM   #105
Andrew025
Andrew025's Avatar
I've gone through many tunes/stages with my previous BRZ, so I'm aware of what it does/doesn't feel like. I definitely don't feel the dip if I'm not more than 1/4 throttle or so (or something around there, don't have an exact number for you).
You're not making or putting down your full potential torque if you're not at WOT... Which is why you don't feel it if you're never putting down whatever number the bottom of the dip is.
Old 02-23-2017, 04:28 AM   #106
Esseff
Drives: 2017 BRZ Ltd White
I complained also. The radio is worse than my '15 but, you have a good point. I've resolved to just change it out...
Yes, I thought the audio quality was woeful when i first got it. No bass and way too much treble. I played around with the eq presets but still couldn't make it sound acceptable. The bass preset still didn't solve the treble problem.
I finally did a custom preset with the bass way up and the treble way down, and now it sounds great. Not audiophile quality but I'm very happy with it.
Mind you the head units seem to change from country to country so my Au model is probably different to the US midel.
Esseff is offline   Reply With Quote
Old 02-23-2017, 09:36 AM   #107
nima314
Drives: Subaru BRZ 2017 (almost)
Audio through usb is much better quality than the horrendous Bluetooth. Changing my head unit to alpine z270 or whatever its called coming in a couple months android auto. Will let you know how much nicer audio sounds with that
Sent from my Nexus 6P using Tapatalk
nima314 is offline   Reply With Quote
Old 02-23-2017, 09:45 AM   #108
Da Brz
Drives: 2016 Subaru BRZ
I know that when I first got my car, I thought the sound quality was horrible across the board. Like, bad enough that I was gonna at least complain the next time I took it in for service.
But I found a bunch of stuff in the settings that needed to be turned off. Like HD Radio. And the automatic volume control -- an option I actually like -- was way too high. There was a couple other things I turned off, too. I think there was a bass booster I turned on though.
But anyway, yeah, it sounds fine now.
It's like buying a new TV, you need to go into the settings and calibrate it to how you want it.
Da Brz is offline   Reply With Quote
The Following 2 Users Say Thank You to Da Brz For This Useful Post:
BRZ FTW (02-23-2017), justinco (02-23-2017)
Old 02-23-2017, 08:34 PM   #109
ansibe
Drives: White BRZ
I don't know, I feel it everyday driving to/from work. ... Anyways this horse has been bludgeoned enough I'd say...
I'm taking one more crack at it, sorry ... Worst.Dip.Ever. There, I'm done.
ansibe is offline   Reply With Quote
The Following User Says Thank You to ansibe For This Useful Post:
Somerandom18 (02-23-2017)
Old 02-23-2017, 09:28 PM   #110
2017-BRZ
Actually reminds me of a high lag turbo motor..lmao.
3k,,wait..for it..4k..little more.....5k woosh........
The Following User Says Thank You to 2017-BRZ For This Useful Post:
Old 03-07-2017, 11:12 PM   #111
2017-BRZ
I'm just appreciating very much more so being a proud owner of a 2017.. THANK YOU.
justinco (03-08-2017)
2017 BRZ things I hate. 1+CAN+1 CANADA 32 05-23-2017 10:50 AM
dislike your plain Toyota key? check my custom flip tibsy92 AUSTRALIA 38 02-22-2014 10:24 PM
3 likes, 1 dislike RaceR Scion FR-S / Toyota 86 GT86 General Forum 36 12-18-2012 06:11 PM
dislike about the FR-S xc Scion FR-S / Toyota 86 GT86 General Forum 83 11-28-2011 11:56 PM
