#7799 | |
Drives: 2013 FR-S Argento
#7800 | |
Drives: 2013 Subaru BRZ Limited (Black)
Yes. I have talked to mike. I'm running non-intercooled at moment, and only on the 72.5mm pulley. Mike mentioned that I might be OK considering the above -- We will find out soon! I don't expect to be up at 280-290 necessarily -- as I'm not running intercooler, or 69mm pulley. We will see what mike says! |
#7801 | |
Grip>Slip
#7802 | |
#7803 | |
I'm going to monitor temps and blow-by and may do catch cans and intercooler just for longevity. I've not seen high temps under daily driving yet. This will be my last power upgrade on this car unless I build the motor! |
#7804 |
Grip>Slip
Anyone upgraded the intercooler's pump to this one? Any improvements?
http://www.moto-east.com/store/subar...oler-pump.html |
#7805 | |
Drives: 2013 Scion FRS
Don't waste you're money on IC!
ScreamingElectron - SnakeShit |
#7806 | |
Drives: 2013 Firestorm FRS
It's MASSIVE compared to the baby one that comes in the s/c kit. Should work really well. |
#7807 |
Drives: 2014 WRB BRZ
#7808 |
Drives: 2013 FRS- Hot Lava
So question for the innovate owners. I'm planning on purchasing this kit (already own another twin with the vortech kit) for my 2.0 as an "easy, bumper removal free" (to avoid the dreaded bumper gap) forced induction.
I recently took a drive in a twin with this kit+ stock air box and the sound was not where I wanted it to be. I know many people run the perrin intake (which significantly amplifies the sound) but I do not want to since you have to remove the bumper to install it. So, question: Are there any "short ram" style intakes (which do not sit inside the bumper) that can be used for this supercharger? I believe airraid works as well but I'd prefer an open filter. I dont track the car and live in Michigan, so I'm not worried about heat soak. Any suggestions? |
#7809 |
A lot of us here are on the quest for more power, and would probably avoid that kinda intake.
You should throw a post on the intake thread as well. What's up with not wanting to drop your fender?
#7810 |
Grip>Slip
#7811 | |
I don't know how much power goes through the injector wire, but there's no way it could support this pump reliably. |
#7812 |
Drives: UK GT86
Does the pump definitely draw more current rather than just being a bigger pump?
.: Stealth 86 :.
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
