Old 02-22-2017, 10:26 AM   #43
PDM 2
Pokemon Master
PDM 2's Avatar
Drives: 2014 Scion FR-S
Exhaust compared to Q300? Really liking this exhaust.
'10 MazdaSpeed 3 Velocity Red Mica - SOLD
PDM 2
'14 Scion FR-S MT FireStorm Red STAGE 2 + - FIVE AXIS BODY KIT - HKS DROPIN - INVIDIA N1 - GRUPPE-S UEL- ENKEI LUSSO 18X7.5 +42 - ST COILOVERS
PDM 2 is offline
Old 02-22-2017, 10:42 AM   #44
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by CHMBRZ View Post
I want those wheels, but maybe go with the 17x9 +36 versions of that te37v SL and probably 245/40, not sure if the 255/40 would look right on the 17x9 model compared to the 17x9.5.
We think it looks pretty good. Here is another reference shot of 255/40 on 17x9 RPF1 that we ran way back in the day.
Originally Posted by Teclis View Post
Are these the same size as OEM? (diameter and so on)
Want to upgrade to these aswell ^^,
Cheers
Yes, these are direct OE replacements.
More aggressive! Right in the middle between the Q300 and N1.
FT-86 SpeedFactory is offline
The Following 3 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
CHMBRZ (02-22-2017), PDM 2 (02-22-2017), Teclis (02-22-2017)
Old 02-22-2017, 11:30 AM   #45
Whooppee777
Whooppee777's Avatar
Drives: 2014 DGM BRZ Limited
Originally Posted by FT-86 SpeedFactory View Post
Yes, the Mishimoto rad hoses will work with a Koyo.
We didn't install Mishimoto's fan shroud kit because we we're focusing on the radiator installation process. But it does plug right into the factory wiring harness and pulls a lot more air in compared to the stock fans.
Will the Mishimoto fan shroud kit bolt up to the Jackson Racing dual oil cooler radiator?
I Don't Appreciate Your Lack Of Sarcasm
'14 BRZ Limited
'17 Crosstrek
'87 Buick Grand National
Whooppee777 is offline
Old 02-28-2017, 03:57 PM   #46
Blue Bird
Blue Bird's Avatar
Drives: '14 BRZ
Is there one without the "pop and crackle"?
Blue Bird is offline
Old 03-08-2017, 02:56 AM   #47
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
How much does the MXP RS exhaust weigh in total? Savings from stock?
justinco is offline
Old 03-12-2017, 11:29 PM   #48
Rougenite
Drives: Raven FR-S
Its a direct replacement for the stock shroud, but thinner. So if you don't need to drill/move anything with the Jackson stuff, it should fit.
Rougenite is offline
Old 03-15-2017, 05:44 PM   #49
Whooppee777
That's what I'm hoping is the case, but if I had a dollar for every time I heard that and then later encountered an issue that required some form of customizing, I'd be in Trumps tax bracket.
'14 BRZ Limited
'17 Crosstrek
Old 03-21-2017, 07:13 PM   #50
FT-86 SpeedFactory
GCS Interior Footwell Lighting Kit
[ame="https://www.youtube.com/watch?v=MS4TBKhM1u8&t"]GCS Interior Lighting Kit - FT86SpeedFactory - YouTube[/ame]
New luxury vehicles like the 2017 BMW 5 Series come with ambient interior lights that set the mood of your drive. Granted the price of a new 5 series is about double that of our car, we still wanted to incorporate this luxury feature in our 86.
For the lights we chose to go with the GCS RGB Interior Footwell LED kit with Bluetooth connectivity so we can easily change the colors on the fly from our phone. Everything can be controlled through the Happy Lighting app that’s available for both iOS and Android. There is an almost endless amount of colors, pulses, and gradual color changes to choose from, and it will even pulse the lights to the beat of your music.
The kit comes with 4 LED light strips so we’ve got every seat covered, and we only need to connect two wires to power the entire system, which makes installation very quick. The hardest part about the install is running the LED wire through the center console from the driver’s footwell to the passenger side. But if you enlist a friend to sit at the other side, the process becomes much easier.
This aesthetic mod gives our 86 a greater sense of occasion when you’re behind the wheel. But if the bright LEDs that fill the footwells full of color are a bit too much, you can always tone down the brightness to suit your tastes.
Old 04-17-2017, 06:50 PM   #51
Qc86
Drives: 2017 Toyota 86 M6
How are those fortune auto prime coilovers? I'm in the market to buy a set of coilovers and was wondering how they do on the streets and at the track? Ill do some occasional track days and auto x and I only use my 86 as a weekend car. Wanna get rid of the body roll and the stock huge wheel gap!
Qc86 is offline
Old 04-24-2017, 01:19 PM   #52
FT-86 SpeedFactory
The Fortune Auto Prime coils are pretty comfortable on the street and with a quick damper adjustments they stiffens up quite well. They're a great sub 1k coilover that offer custom springs rates, but since this wont be a daily, maybe consider a coilover built for track days.
Old 04-24-2017, 01:22 PM   #53
FT-86 SpeedFactory
Intec Fender Insert Turn Signals
The FRS, BRZ, and 86 each have their own uniquely styled fender garnish, but sadly none of them are functional. So in order to get some practical use out of what is normally just decoration, we installed the fender turn signals from Intec.
Currently these Intec fender insets are only available in gloss black, but that’s perfectly fine with us since it matches our gloss black emblems. On the inside the light strip is powered by an amber LED and it can easily be seen in the daylight.
This will be a very simple install and these fender inserts full replacements and fit just like the oem ganish. For any FRS or GT86 this will be a simple plug and play install since the turn signals are separate from the headlights, and Intec provides a plug and play harness for this application.
But if you own a BRZ or 86 like we do, the turn signals are integrated into the headlight, so you’ll have to do a small modification to the harness and tap into the headlight wires. It may sound complicated, but it’s a pretty straight forward install. I explain this more in detail in the video.
[ame="https://www.youtube.com/watch?v=03QY6Q3NIFQ"]Intec Fender Turn Signals - FT86SpeedFactory - YouTube[/ame]
Old 05-30-2017, 06:58 PM   #54
FT-86 SpeedFactory
Pedal Upgrades
A common complaint with these car is that the brake and accelerator pedals are spaced too far apart, making it a little more challenging to get consistent rev matches for heel and toe. However there are a couple options to tackle this problem, and the two solutions can be combined for better results.
The first options is the SRP pedal covers
[ame="https://www.youtube.com/watch?v=Dwc3PVXrT-0"]How to Upgrade your Pedals - FT86SpeedFactory - YouTube[/ame]
These bolt on to the factory pedals and give the gas pedal an extra ¾” that extends on the side to make it much easier to blip the throttle.
They come in a full pedal set with a grid texture that adds a bit of extra grip and also gives the pedals a completely different look, which in my opinion looks much better than stock. But if you just want the extended gas pedal they sell them separately in a finish that matches the stock pedals.
The second option is the Velox throttle pedal spacer kit
[ame="https://www.youtube.com/watch?v=FBJyfgXvFWI"]Quick Heel Toe Mod - Velox Pedal Spacer - YouTube[/ame]
If you don’t like the idea of drilling into your stock pedals and would rather install something quick and easy, then the Velox Spacer Kit may be a better option for you. It’s goes in between the throttle pedal assembly and the firewall and moves the pedal 15-20mm (adjustable) to the left closer to the brake, and 25mm forward, closer to the driver.
Since there are only four bolts and one electrical connection you need to worry about for this install, it shouldn’t take more than 20 minutes.
Both options are going to help make your driving more consistent, but when they’re combined you’re left with a pedal setup that’s close enough to land every throttle blip, yet spaced far enough apart that you can still comfortably operate the pedals wearing boots.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Scrappydoo (05-30-2017)
Old 05-31-2017, 12:00 AM   #55
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Those side turn signals would be so much better without that stupid lettering
SuperTom is offline
Old 06-01-2017, 04:34 PM   #56
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
I have three questions,
1. There are a few people selling the component that houses the toggle switches And the duel zone climate controls for the BRZ and the limited-edition Toyota 860 would that be a plug-and-play unit in the new 2017 Toyota 86?
2. Would the instrument cluster with the info screen on right side from a Toyota 860 limited edition, be a plug and play if you also had the steering wheel controls for the right side of the steering wheel?
If not what would it take to make them work?
Thanks,
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-10-2019 12:03 AM
2017 Toyota 86 Driftz Southwest 3 06-04-2016 03:52 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
FT-86 SpeedFactory Vortech Supercharger Build FT-86 SpeedFactory Forced Induction 91 09-26-2013 09:02 AM
>>FT-86 SpeedFactory One Lap of America Build<< FT-86 SpeedFactory FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 84 05-23-2013 05:22 PM
