Old 02-19-2017, 06:49 PM   #15793
arxm
Drives: 2013 FR-S, 2023 BRZ
i dipped my emblems and attempted to change my exhaust tips, i want it to look cool but not be any louder than stock however when taking off the old tips, one nut rounded off and one snapped off so I'm gonna have to get creative as to how I'm gonna take them off now
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 02-19-2017, 06:57 PM   #15794
Ashikabi
Ashikabi's Avatar
Drill them out or cut them off, get new hardware
Old 02-19-2017, 09:03 PM   #15795
g33k
g33k's Avatar
Drives: 2009 Nissan Altima, 2015 Scion FR-S
Reinstalled my lip after it had fallen off and got damaged. Had a friend refinish it and patch up the holes that the scrapping made. Now it is secured with nuts and bolts. I also plastidipped the lip prior to installing.
Had to use some self tapping screws in the very front couldn't get enough clearance to use the nuts and bolts. Also don't have a jack or jack stands so used the downhill slope of my driveway to get some extra clearance.
See when I decided to add the side skirts.
Sent from my XT1650 using Tapatalk
g33k is offline   Reply With Quote
Old 02-20-2017, 07:57 PM   #15796
arxm
yeah i was hoping i could come up with something easier but I'm just gonna cut them, its gonna have to wait till next weekend though
Old 02-21-2017, 05:01 PM   #15797
Kaotic Lazagna
Drives: GR Corolla
Started the engine and let it idle for 30 minutes. Lol. Haven't driven her in 8 days.
Old 02-22-2017, 12:16 PM   #15798
zeal86
zeal86's Avatar
Drives:
This morning I pushed forward on my rear seat delete fabrication...
Installed the rear support brackets I completed last night. Took mental notes for version 3 of my center channel template...
Everything is coming together nicely!
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
MJones_RB (02-28-2017)
Old 02-23-2017, 02:00 PM   #15799
slowautoxr
Drives: Subaru 2.5RS
I unplugged the DRL's.
Charles
2013 FR-S
slowautoxr is offline   Reply With Quote
Old 02-23-2017, 02:34 PM   #15800
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
AFAIK, that is not good for the engine to start it and not drive it like that, probably worse than just not starting it and letting it sit.
Originally Posted by humfrz
I'm old and lazy
Old 02-23-2017, 03:03 PM   #15801
Kaotic Lazagna
Drives: GR Corolla
I know idling engines aren't the best, but it's either that or risk the battery going flat again. I did drive it today to work tho. Lol
Old 02-23-2017, 03:06 PM   #15802
Clipdat
Proud of BOXER
Clipdat's Avatar
I thought the battery only gets recharged from the alternator when the car is actually in motion going down the street.
Again, just my understanding, but I could very well be wrong.
I'm old and lazy
Old 02-23-2017, 03:21 PM   #15803
Ashikabi
Ashikabi's Avatar
I don't believe driving has anything to do with it. The alternator is being spun by the belt so it should be charging the battery any time the engine is running
The Following User Says Thank You to Ashikabi For This Useful Post:
Clipdat (02-23-2017)
Old 02-23-2017, 03:23 PM   #15804
arxm
I'm pretty sure the alternator is always charging the battery when the engine is on, since its being driven by an accessory belt attached to the crankshaft it would seem to make sense but I've never actually looked into that
The Following User Says Thank You to arxm For This Useful Post:
Old 02-23-2017, 03:35 PM   #15805
Kaotic Lazagna
Drives: GR Corolla
Nope, as long as the engine is on, it'll charge the battery. It'll charge quicker if driving.
I only said it wasn't good to idle since it take waaaaaay longer to warm up to operating temp.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
Old 02-24-2017, 01:40 AM   #15806
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
More than you need, or maybe want to know here:
See within: Charging system basics, voltage regulation, current demand and flow.
http://www.bcae1.com/charging.htm
ToySub1946 is offline   Reply With Quote
The Following 4 Users Say Thank You to ToySub1946 For This Useful Post:
BirdTRD (02-24-2017), guybo (02-24-2017), humfrz (02-24-2017), notout86 (02-26-2017)
