Old 02-18-2017, 01:05 AM   #15
You may consider expanding on that.
Old 02-18-2017, 10:01 AM   #16
Tokay444
Originally Posted by Pat View Post
You may be ignoring the root cause.
Root cause has been addressed by Toyota, with rockers with better pin retention.
Old 02-18-2017, 10:08 AM   #17
Pat
Pat's Avatar
Drives: 2023 BRZ
Yes, that may be the root cause. I'm not convinced we can determine the root cause, though, give the other information provided. There are certainly other factors at play in this particular situation.
Old 02-18-2017, 11:18 AM   #18
DJCarbine
Thupercharged
DJCarbine's Avatar
Don't leave us hanging, what other factors?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Ultramaroon (02-18-2017)
Old 02-18-2017, 01:51 PM   #19
Hyper4mance2k (02-20-2017)
Old 02-18-2017, 01:57 PM   #20
Pat
Pat's Avatar
Drives: 2023 BRZ
Don't you think the addition of a supercharger may have caused the engine to run outside of it's designed parameters?
Old 02-18-2017, 02:05 PM   #21
You're evading the question. You said other factors were at play. Like what? More importantly, how? What's your theory?
Old 02-18-2017, 03:00 PM   #22
Pat
Pat's Avatar
Drives: 2023 BRZ
Quite simply, I'm open to the idea that adding additional stress to the engine in the form of a supercharger that it was not designed to accept would add additional stress, thereby making failure more likely. I'm not saying I know how or why, or even pinpointing the most likely areas of failure. I am just saying that I am open to the possibility of it being a factor. To outright deny the possibility of something like this being a factor I think is just close minded.
If someone can prove to me somehow that it is impossible the forced induction could be a factor, I'm all ears.
Old 02-18-2017, 03:19 PM   #23
Ok, so you don't know and you want someone to spoon feed you. Got it.
Tokay444 (02-18-2017)
Old 02-18-2017, 03:25 PM   #24
Look, If you want to learn, ask politely. Don't come in acting like you have some secret inside info.
I'm happy to share.
Old 02-18-2017, 04:25 PM   #25
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Yeah, not thinking that an engine not designed for FI that throws a rocker out of the head MAY be related to the supercharger is pretty dumb. When you blow an engine you are increasing the pressure inside the cylinders, this increases how hard it is to push those valves which is done indirectly by.... the rockers. Maybe that's a weak point, but I can guarantee that they don't normally go on a NA engine at 30k miles.
You supercharged your car that was designed for NA. The engine expired at 30k miles. Not coincidence IMHO. I agree with @Pat 100%.
guybo is offline   Reply With Quote
Old 02-18-2017, 06:19 PM   #26
Haha... ok Do you know how to do the math? Let's start by assuming a typiclal thermal efficiency of about 20%. Do you get why we need to know that? Shall we continue?
See, you and Pat need to be invested in this little exercise. Otherwise I'm just being suckered into doing enough math to prove my point. Can you do the math to prove yours?
Old 02-18-2017, 06:30 PM   #27
Pat
Pat's Avatar
Drives: 2023 BRZ
Please stop. Take a deep breath. Go back and read what I originally wrote carefully. This entire time I simply stated there is a possibility it was at least partially caused by something other than poorly designed rockers. That's it. Nothing more. I'm not here to start a fight or piss anyone off.
Old 02-18-2017, 06:49 PM   #28
You started with "You may be ignoring the root cause."
Then, because I wanted to be wrong about my interpretation of what a lazy and insulting statement that was, I asked you to expand on your thoughts. Maybe I really could learn something.
You doubled down with something along the lines of "prove it to me."
Well? Other than poorly manufactured rockers, what's your take? Make it worthwhile for me to prove it to you.
Drakiv (02-19-2017)
Hole in valve cover burdickjp Issues | Warranty | Recalls / TSB 25 11-29-2016 09:37 PM
Here's my luck… rocker arm put a hole in the valve cover -eXpo- Issues | Warranty | Recalls / TSB 10 09-23-2015 11:58 PM
WTB Frs Passenger Exhaust Hole Cover OMGArisman Want-To-Buy Requests 0 07-20-2015 12:16 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
Missing Key Hole Cover? Mrpolarbear Issues | Warranty | Recalls / TSB 12 08-10-2014 06:24 PM
