Drives: 2015 Ultramarine Scion FR-S (MT)
Clutch noise, should I be worried?
So, yesterday when I was driving from the morning to afternoon there was no noise whatsoever. Everything was fine, and this morning I wake up to a weird noise I haven't heard before. It's pretty loud in my opinion, and it's a little louder outside, should I be worried?
http://vid1356.photobucket.com/album...ps5o6rlos7.mp4 |
#2 | |
Nothing life threatening to worry about. Sometimes, the point where the clutch slave cylinder's arm contacts the clutch fork gets dry and makes a squeak. Some say @Ultramaroon , that you can sneak some grease past the dust cover on the slave cylinder onto the socket on the clutch fork which will eliminate the squeak. A longer term solution would be to open up the bell housing and grease up the clutch fork. humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Ultramaroon (02-16-2017), WolF_RS (02-16-2017) |
#3 |
Drives: BRZ SWP Limited -6MT
it is annoying no doubt. mine does it too.
#4 |
Mine makes more of a squeaky cutting noise. I noticed it on other frses that I test drove before buying mine. Doesn't seem like it's something to worry about
#5 |
Drives: 2013 Scion FRS
A squeak in the pedal is common, but so are bad TOB's. How many miles? And is the sound from pushing the clutch, or releasing the clutch, or when the clutch is depressed, or when the clutch is pressed in?
"Chasing speed with patience" |
#6 | |
![]() http://vid1356.photobucket.com/album...ps5o6rlos7.mp4 humfrz |
#7 | |
I almost want to blame the weather/car temp as i have noticed that plays a role in my squeak, but lube is a good option that i should try as well. It could even be the pedal itself. "Chasing speed with patience" |
#8 |
I've seen/heard it enough times with friends' twins there's no way it's the pedal. It has varying degrees of creepiness but it's always the main pivot.
Quick & dirty: 1. Detach the slave cylinder. Leave the hydraulics alone. 2. Remove the dust boot from the fork. 3. Reach down behind the fork with a finger and feel for the pivot. It's going to be tight because of the retaining clip. 4. Squeeze a decent glob of Lucas Red & Tacky #2 in there with your finger. 5. Jiggle the fork to distribute the grease as much as possible. It'll work in more on its own. 6. Put a dab of grease in the top pivot where the slave pin goes. 7. Reassemble. ![]() Ok, @humfrz, who else needed to see this post? I know I forgot someone.
#9 | |
I forget who I referred to you last time ....... hell, that was yesterday ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (02-17-2017) |
#10 |
Thanks for the help guys! I'll look in to in this weekend once the rain settles in SoCal
#11 |
thats neat, ive never seen a cross section of clutch assembly
#12 |
I know, right? Stumbled upon it last night.
#13 | |
It may also be the fork (tines?) where the TOB pivots.
#14 | |
Drives: 2013 Supercharged BRZ, E85, Ohlins
Update 19 Feb: After re-lubricating the clutch fork pivot thoroughly ( a plastic spoon works well for this BTW) the noise still persisted, but only with a cold engine. Zero noise when warm ( including off but warm.) Zero noise when moving clutch fork / Clutch slave cylinder by hand. I suspected the the return spring in the clutch master cylinder. We depressed the clutch and sprayed the internals of CMC piston assembly (located above the gas pedal) with TriFlow, and that has eliminated the clutch squeak completely in the short term. We'll see how long that lasts, may switch to other grease product if needed, or replace CMC, or both. IIRC, some dealers had suggested this as a possible cause of squeaks; In my case that was it. Can't hurt to have lubricated the clutch fork pivot too. Both these procedures are easy maintenance items. |
| The Following User Says Thank You to canyons For This Useful Post: | Ultramaroon (02-19-2017) |
| Clutch noise new to-day | Skye | Issues | Warranty | Recalls / TSB | 16 | 11-19-2016 11:42 AM |
| Worried about my clutch? | Bushhy | Issues | Warranty | Recalls / TSB | 11 | 07-01-2016 09:20 AM |
| noise when releasing clutch | andrew5826 | Issues | Warranty | Recalls / TSB | 5 | 02-17-2014 06:41 PM |
| Winding Noise From Clutch | Bach415 | Northern California | 0 | 06-24-2013 07:19 PM |
| Starting to get worried - Engine noise | Laika | BRZ First-Gen (2012+) — General Topics | 49 | 07-02-2012 03:45 PM |
