Northern California NorCal
Old 02-14-2017, 11:58 AM   #1
Hyp
Drives: BRZ 2015
Throw out bearing
My throw out bearing started squeaking and only had the car for 2 years. Do you guys have any recommendations on which subaru dealership to go to in the bay to have it replaced under warranty?
Hyp is offline   Reply With Quote
Old 02-14-2017, 12:00 PM   #2
gramicci101
Off Topic
It's a wearing part, and you've had it for two years. They won't replace it under warranty unless it very obviously broke due to a material defect and not merely wear from usage.
Old 02-14-2017, 12:03 PM   #3
Hyp
Drives: BRZ 2015
Was afraid of that. Been quoted around $500 at shops for the replacement.
Old 02-14-2017, 12:16 PM   #4
gramicci101
Off Topic
Before you do that, do some reading around here first. Squeaking throw out bearings are not uncommon, so it's helpful to see what others have done to address the problem. One potential cause is the clutch fork flexing under load. Velox has made a billet clutch fork to address that issue, and people report that it seems to have fixed their problem. Others have reported that simply regreasing the fork, bearing, and pivot point helped greatly, at much lower cost.
http://www.ft86club.com/forums/showthread.php?t=104963
@Ultramaroon, @humfrz, thoughts?
The Following 3 Users Say Thank You to gramicci101 For This Useful Post:
humfrz (02-14-2017), Teseo (02-14-2017), Ultramaroon (02-14-2017)
Old 02-14-2017, 12:27 PM   #5
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
I charge:
$360 Labor
$20 TOB
*optional* $189 for the Velox clutch fork, to make sure it doesn't happen pre-maturely again.
The TOB failure on these cars is incredibly common, as well as many other Subaru's. From my experience it is best to take care of it ASAP, as full blown bearing failure can damage the clutch assembly and front input shaft cover of the transmission.
The Racers Line is offline   Reply With Quote
The Following 4 Users Say Thank You to The Racers Line For This Useful Post:
exE36M3 (02-15-2017), funwheeldrive (03-14-2017), gramicci101 (02-14-2017), Teseo (02-14-2017)
Old 02-14-2017, 12:32 PM   #6
gramicci101
Off Topic
Thanks, Neal.
Old 02-14-2017, 12:35 PM   #7
Welcome to ..... The Forum, there Hyp .........
So, you car has a squeak in the clutch system.
First off, please tell us more about this squeak.
* how many miles on your car ?
* does it just squeak when you depress or let up on the clutch ?
* or does it squeak/squeal continually when the clutch is depressed ?
* or does it squeak/squeal while the clutch is not depressed, but the engine is running ?
* is the sound more of a squeak or a squeal ?
Come back.
strat61caster (02-15-2017), Ultramaroon (02-14-2017)
Old 02-14-2017, 01:47 PM   #8
I'm following along and agree with @humfrz' questions. We need to know if the squeak is coming from the fork pivots (while the clutch pedal is moving), or the actual TOB.
humfrz (02-14-2017), strat61caster (02-15-2017)
Old 02-15-2017, 01:17 AM   #9
Hyp
Drives: BRZ 2015
Come back.
So my car has 20k on it. When I wake up in the morning to go to work clutch makes no noise at all when egaging the pedal. But after driving say 15 min when I engage the pedal all the way down you hear a loud squeak. When releasing the clutch you hear the squeak. I only hear the squeak when I engage the clutch passed 70%. Makes no noise when im on neutral. Found this video on YouTube and mine makes the same exact sound
Thanks for the help everyone!
Old 02-15-2017, 01:44 AM   #10
Well, if it squeaks and the engine is NOT running, it's NOT the TOB.
So, if it squeaks, regardless of whether or not the engine is running, it's most likely a dry clutch release arm (clutch fork).
I understand it can be somewhat greased by sneaking past the rubber boot and stuffing some grease on the end of the arm (at the joint where the clutch slave cylinder arm contacts the clutch release arm or clutch fork).
@Ultramaroon will be along shortly to explain how to do that.
Old 02-15-2017, 01:45 AM   #11
Yeah, that's a dry pivot. Annoying but not a sign of imminent failure.
Old 02-15-2017, 02:10 AM   #12
I couldn't find my post where I first explained it. I'll do something tomorrow night. Past my bedtime. Zzzzzzzzzzz...
Old 02-15-2017, 12:30 PM   #13
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Mine has made that sound for at least two years now, too lazy to do anything about it. Maybe I'll feel industrious someday.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Clipdat (02-15-2017), Ultramaroon (02-15-2017)
Old 02-15-2017, 01:48 PM   #14
You can swap your clutch slave while you're in there feeling industrious.
...someday.
#ourCars
Melted Throw Out Bearing danthedirt Issues | Warranty | Recalls / TSB 59 01-25-2018 05:32 PM
Post If You Have Had Your Throw-Out Bearing Go Bad! Bushhy Issues | Warranty | Recalls / TSB 8 10-24-2016 05:34 PM
Throw-out bearing mhigham Issues | Warranty | Recalls / TSB 71 08-18-2016 10:21 AM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 04:45 AM
throw out bearing clips... Shit Luck Engine, Exhaust, Transmission 0 04-12-2014 06:34 PM
