Old 02-14-2017, 12:07 PM   #27399
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by Cole View Post
Hmm. 2 things. Just realized, there's no speaker on this case for the mobo. If I plug headphones into the 3.5mm jack, would i hear the problem code beeps? Second, could this be because I'm using an HDMI port, instead of a VGA cable?
Try VGA if you have it, but HDMI should work.
Isn't his team in the wrong slot? Not to it would help this but I thought it went in the closest slot
By design, most mobos recommend putting RAM in slots 2 and 4 first. So if it's a single stick, I usually put it in slot 2.
Andrew025 is offline
Old 02-14-2017, 12:08 PM   #27400
Andrew025
Andrew025's Avatar
This doesn't look right
Yeah... doesn't look like it's quite in all the way.
Old 02-14-2017, 12:11 PM   #27401
Ashikabi
Ashikabi's Avatar
@Cole! You didn't put it in all the way.
Ashikabi is offline
Old 02-14-2017, 12:11 PM   #27402
Cole
Not a troll
Cole's Avatar
What do you mean? It's as plugged in as it will be, fans on the GPU are spinning
Cole is offline
Old 02-14-2017, 12:14 PM   #27403
Andrew025
Andrew025's Avatar
It looks crooked since it isn't flush with the case. The case may just be weird though.
Old 02-14-2017, 12:15 PM   #27404
Ashikabi
Ashikabi's Avatar
There should't be a big gap. Looks like it's only partially seated. Just take it out and try again with a slight bias to seating the rear first. Make sure there aren't any screws or slot covers blocking it. Should have a hole to screw to the case
Ashikabi is offline
Old 02-14-2017, 12:18 PM   #27405
gramicci101
Off Topic
My wife hates it when I put my ram in the wrong slot.
I mean... what?
gramicci101 is offline
The Following User Says Thank You to gramicci101 For This Useful Post:
soulreapersteve (02-14-2017)
Old 02-14-2017, 12:19 PM   #27406
Andrew025
Andrew025's Avatar
This is how mine looks.
It's not perfectly flush, but way less of a gap than yours.
Old 02-14-2017, 12:27 PM   #27407
Cole
Not a troll
Cole's Avatar
I had the screw out so that I could remove the card. Still no luck with the screw in.
Cole is offline
Old 02-14-2017, 12:59 PM   #27408
I mean... what?
This is the computer build channel ......
humfrz is offline
Old 02-14-2017, 01:19 PM   #27409
Cole
Not a troll
Cole's Avatar
I give up. I'm ready to take it to a shop and get them to troubleshoot.
Cole is offline
Old 02-14-2017, 01:21 PM   #27410
Andrew025
Andrew025's Avatar
You unplugged everything and tried turning it on? HDD, fans, basically everything but the mobo.
Old 02-14-2017, 01:39 PM   #27411
Originally Posted by Sarlacc View Post
If only that were so. I've tinkered with puters since Commodore had a bright future. Laptops, desktops, workstations, servers, rack blades. I've built many of them from parts. And the component manufacturers' lack of a holistic approach to airflow has bewildered me since the beginning. It looks like the need for heat dissipation comes as a surprise, every time.
We must be opening different machines. I remember shitty old cabinets from the '90s but every commercial machine I've seen since '00-ish has been "somewhat" thoughtfully laid out. Compaq, Dell, HP... Granted the best and heaviest ones were the IBM AIX Desktop servers but those were damn spendy.
I guess as long as you don't have 2 fans fighting each other, more can't hurt.
Ultramaroon is offline
Sarlacc (02-14-2017)
Old 02-14-2017, 02:04 PM   #27412
@Cole 's GF ...... put in in
Cole ....... I did
GF .....put it in all the way
Cole ...... I did
GF ....... oh
humfrz is offline
Ashikabi (02-14-2017), davesrave (02-14-2017)
