Old 02-14-2017, 10:39 AM   #27385
Ashikabi
Ashikabi's Avatar
Who was looking for a Grimmspeed license plate relocation bracket? There is one in the classifieds
Ashikabi is offline
Old 02-14-2017, 11:10 AM   #27386
Cole
Not a troll
Cole's Avatar
Haha shit. I'm not getting any video output on my computer
Cole is offline
Old 02-14-2017, 11:11 AM   #27387
gramicci101
Off Topic
Have you tried turning it off and back on again?
gramicci101 is offline
Old 02-14-2017, 11:19 AM   #27388
Ashikabi
Ashikabi's Avatar
Is it plugged in? Are you sure it's plugged in? Check again anyways. Check if video card is seated right. Are you familiar with the locking mechanism on video card slots? Are you plugged into the card as opposed to plugged into the motherboard onboard video port? Are you absolutely certain it's plugged in? Does the video card have a power plug on it? Is that plugged in?
Ashikabi is offline
The Following User Says Thank You to Ashikabi For This Useful Post:
Dadhawk (02-14-2017)
Old 02-14-2017, 11:22 AM   #27389
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Shit got real tonight boys. Just missing RAM and the SSD. I figure it's best if I just have the SSD plugged in while setting the computer up, rather than both HDs in.
Cable management is super lame too. Especially in this micro atx case. Next case will be a not 35 dollar micro atx case.
My current build is in a mini ITX case. I think my fingers are permanently broken at this point.
jawn is offline
Old 02-14-2017, 11:33 AM   #27390
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Go home boys, he covered all of it.
Andrew025 is offline
The Following 2 Users Say Thank You to Andrew025 For This Useful Post:
Dadhawk (02-14-2017), soulreapersteve (02-14-2017)
Old 02-14-2017, 11:43 AM   #27391
Cole
Not a troll
Cole's Avatar
Yes
Yes
I did
I did
Yes
Yes, mobo has no video out capabilities
Yes
No
No, because no plug.
Cole is offline
Old 02-14-2017, 11:47 AM   #27392
Andrew025
Andrew025's Avatar
Yes
Yes
I did
I did
Yes
Yes
No
Try plugging into the onboard video if you haven't.
How many beeps do you hear when turning it on?
Take a picture of the inside if you can.
Old 02-14-2017, 11:51 AM   #27393
Cole
Not a troll
Cole's Avatar
There's no onboard video. Zero beeps. Picture will be up in a minute.
Cole is offline
Old 02-14-2017, 11:53 AM   #27394
Cole
Not a troll
Cole's Avatar
Cole is offline
Old 02-14-2017, 11:59 AM   #27395
Andrew025
Andrew025's Avatar
If everything is plugged in correctly, you can start by unplugging things.
Disconnect everything (even the fan and RAM (may be a compatibility issue, or try it in a different slot)) and add one by one.
Old 02-14-2017, 12:02 PM   #27396
Cole
Not a troll
Cole's Avatar
Hmm. 2 things. Just realized, there's no speaker on this case for the mobo. If I plug headphones into the 3.5mm jack, would i hear the problem code beeps? Second, could this be because I'm using an HDMI port, instead of a VGA cable?
Cole is offline
Old 02-14-2017, 12:04 PM   #27397
Ashikabi
Ashikabi's Avatar
Isn't his ram in the wrong slot? Not to it would help this but I thought it went in the closest slot
Ashikabi is offline
Old 02-14-2017, 12:06 PM   #27398
Ashikabi
Ashikabi's Avatar
This doesn't look right
Ashikabi is offline
