Old 02-13-2017, 02:31 PM   #3067
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by jvincent View Post
Driver mod?
I almost put the exact same thing earlier this morning.
There's no point to putting parts on a car that's perfect, and with no described problems there's no point in changing anything. Up the driving skills until you can pinpoint something you don't like.
Otherwise you're just throwing money at it for no good reason.
ineedyourdiddly
Clipdat (02-13-2017)
Old 02-13-2017, 02:40 PM   #3068
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Thanks!
Driver mod. Front control arm bushings. Rear upper control arm bushings.
- Andrew
Yeah, point taken. I just wasn't sure if there were any "obvious" bushings/braces that would make a big positive impact.
Originally Posted by humfrz
I'm old and lazy
Old 02-13-2017, 02:53 PM   #3069
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Thanks!
Rear UCA bushing makes a huge difference. Very solid feeling to the rear compared to stock. Cons are they are a pita to install and nvh and discomfort significantly increases
Old 02-16-2017, 11:50 AM   #3070
BDKane01
BDKane01's Avatar
Drives: 2016 Subaru BRZ Limited CWP MT
Hey guys, I would like some recommendations on coil overs. I plan to buy some coils by the end of the year..right now I am doing abit of research.
16' BRZ limited
Activity: DD(mostly highway), in warm climate, planned 6 auto-x this year, novice events, some defensive driving courses. Maybe some HDPE events.
Budget: $1500-2200
Desired drop: 1"-2"
Wheels: 17x9-18x8.5
No current supporting mods.
Hindsight is 20/20
BDKane01 is offline   Reply With Quote
Old 02-16-2017, 01:49 PM   #3071
varora
Drives: 968
Hi, what do you think will be the best match for the sachs dampers in the 2017 pp models, the rce yellows or tarmac?
varora is offline   Reply With Quote
Old 02-16-2017, 02:10 PM   #3072
BRZ FTW
Drives: 2017 Subaru BRZ
curious as well but i'm very hesitant to modify the stock PP suspension. compared to my '15, the PP on my '17 is far superior!
BRZ FTW is offline   Reply With Quote
Old 02-16-2017, 05:03 PM   #3073
The Yellows.
- Andrew
Old 02-16-2017, 05:10 PM   #3074
16' BRZ limited
Budget: $1500-2200
Desired drop: 1"-2"
Wheels: 17x9-18x8.5
Our upcoming GTWORX Bilstein coilovers would be a good fit. Good ride, great handling, and Bilstein quality. They're non-adjustable for damping, which keeps things simple.
If you want something with a lot of damper adjustments, KW V3 would be worth looking at as well. Our RCE T2 coilovers are a custom valved and spring version of them that is a little more track oriented. But they would be just past your budget.
- Andrew
BDKane01 (02-17-2017), Clipdat (02-16-2017)
Old 02-16-2017, 05:15 PM   #3075
goldenfri
goldenfri's Avatar
Drives: 2017 BRZ Limited PP
Send a message via AIM to goldenfri
Same here, the PP setup is very good and quite balanced, but I don't love the monster truck look. I used to have the swift-Rs on my S2000 CR dampers and they were great on the street with a bias towards oversteer (which I prefer) so that is the first place I looked but their rear springs are a good bit stiffer than the yellows and Subaru said with the 2017 they softened the rear springs because of the bigger rear bar. We don't have any real spring numbers for 2017 that I have seen though. So I dunno, I might end up trying out the yellows to see how I like them, I am concerned that the swift-Rs would be too much for the rear with the bigger bar back there. This is my DD (S2000 is track car) so it's not critical and coils are overkill, but I want a somewhat comfortable setup that doesn't understeer.
goldenfri is offline   Reply With Quote
Old 02-16-2017, 10:58 PM   #3076
I wouldn't use Spec Rs on stock shocks.
- Andrew
goldenfri (02-17-2017)
Old 02-17-2017, 07:39 AM   #3077
BDKane01
BDKane01's Avatar
- Andrew
Awesome! Thanks for the response. I will look into that. I believe that having the ability to adjust dampers would be ideal for me. I drive my BRZ on a military base and the roads can wildly vary depending on where I am.
Could you give me some advice on how to gain more knowledge of suspension and the components as a consumer? I don't think I would need to spend as much time on things as an engineer. However, I do want to learn enough that I know exactly what I am looking for as a consumer.
Hindsight is 20/20
Old 02-17-2017, 08:30 AM   #3078
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Articles like this one below are a great place to start growing your knowledge.
http://www.turnology.com/tech-storie...ber-with-koni/
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
BDKane01 (02-19-2017)
Old 02-17-2017, 09:59 AM   #3079
goldenfri
goldenfri's Avatar
- Andrew
Why?
Old 02-17-2017, 01:46 PM   #3080
Originally Posted by goldenfri View Post
Why?
Too stiff for the OEM shocks, even on the older and firmer OEM shocks. Rears especially
Our RCE Tarmac lowering springs are about the same rate and we don't recommend running them on OEM shocks, so this isn't a knock on the Swifts, just us being realistic.
- Andrew
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
