Old 01-13-2017, 06:30 PM   #1
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
@pete.lete - Kpower Industries Kswap - Gridlife ClubTR
Follow me on Instagram to keep up to date!!!
https://www.instagram.com/pete.lete/
The main goal of the build was to be clean looking as possible. I wanted something that I could daily, but be pretty competitive at the track with.
The car was supercharged before with a C38 kraftwerks kit that gave me nothing but problems, snapping belts, and pulley failures. After Kraftwerks completely decided to ignore my improvement/enhancements requests and their lack of customer service, I decided to part ways. It was supercharged for about 30k miles on the stock motor that saw years of track days and daily driving.
Now fast forward to today, I'm currently running a JDL UEL GTX2860r Turbo kit that I am EXTREMELY happy with. I should have really just done this from the start. The GTX2860r is a way more efficient compressor than the C38 unit. With the turbo I can run LESS boost, but get MORE power. The C38 just wasn't as efficient.
Modifications
Drivetrain
JDL UEL GTX2860r Turbo Kit
HRI Tuned/James Martin
ID1050x Injectors
DW65c Fuel Pump
Moto-East Flex Fuel Kit
Mishimoto Oil Cooler 19 Row Core, -10an Aeroquip Lines, -10an Mocal Fittings
Racer X Oil Cooler Thermostat
ACT Clutch kit (SB8-XTSS)
Synthetic 0w-40 Castrol Edge Euro formula
Motul Gear 300 Transmission and Diff Fluid
Mishimoto Catch Can
Verus Engineering Radiator/Fan Combo
Custom 3 Port Mac Valve EBCS
Suspension/Brakes
StopTech Stainless Steel Brake Lines
StopTech C43 and C42 front and rear bbk
PFC 11 brake pads
Complete Ground Control Coilovers with Strut bar Suspension System
440in/lbs Front and Rear Spring Combo
Whiteline Gearbox Positive Shift Kit
SPC Rear Lower Adjustable Control Arms
SPC Rear Adjustable Toe Arms
SPC Front Camber Bolts
Perrin Rear Shifter Bushing
Alignment Specs
-3.5 Front
-2.5 Rear
0 Toe Front
1/16th Toe in total rear
This is most likely subject to change as time goes on, I may be adding more front and rear camber. Possibly doing a -3.5 in the front and -2.5 in the back, and possibly changing toe to something. Still need to do more research. In addition, at a certain point alignment specs become more of a personal preference.
Exhaust
Bronze Coated JDL UEL Turbo Manifold
3" JDL Dual Resonated Ultra Quiet Front Pipe
3" Dezod Motorsports Catback
Interior
Flex Fuel Zeitronix Gauge
AEM 30-4406 -30-35 PSI Boost Gauge
AEM 30-4110 UEGO Air/Fuel Ratio Gauge
Cravenspeed Gauge Pod Mount
JPM Coachworks Shift Boot
JPM Coachworks E-Brake Boot
Carbon Fiber Wrapped Dash
Favorite Highlights from 2020 Time Attack:
pgranberg11 is offline   Reply With Quote
The Following 2 Users Say Thank You to pgranberg11 For This Useful Post:
Lonewolf (01-15-2017), pillbox (07-29-2019)
Old 01-15-2017, 04:31 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
Nice thread...looking forward to updates
The Following User Says Thank You to Lonewolf For This Useful Post:
pgranberg11 (01-16-2017)
Old 01-16-2017, 12:53 PM   #3
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
coming up this week, JDL emailed me back for my Ultra Quiet Over Front Pipe and I'll be ordering my Perrin 3 inch resonated exhaust!!! woohoo!
Old 01-16-2017, 02:39 PM   #4
Evil Rocky
Drives: FRS
That's an awesome Build you have so far!!
I am hoping to be posting my build soon. Maybe around march after put on more parts
Evil Rocky is offline   Reply With Quote
The Following User Says Thank You to Evil Rocky For This Useful Post:
Old 01-17-2017, 03:16 PM   #5
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
patiently waiting for my 3 inch JDL ultra quiet over front pipe to be shipped (hopefully today) and my perrin 3 inch resonated exhaust already shipped! Both should be here by the end of the week!!!
in other news, just purchased my first track weekend for the year for june with Gridlife
Old 01-17-2017, 05:33 PM   #6
WorldRallyB
Performance Ricer
Drives: 19 WRX, 19 ND2
Nice build
I'm assuming you're adjusting your current exhaust setup because its too loud? I've got the borla cat-back and looking at also going with the Tomei uncatted UELs. Would you be so kind as to let me know how well that front pipe works out for you? I might need to quiet my system down a bit too..
WorldRallyB is offline   Reply With Quote
The Following User Says Thank You to WorldRallyB For This Useful Post:
pgranberg11 (01-17-2017)
Old 01-17-2017, 06:08 PM   #7
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by WorldRallyB View Post
Nice build
Well to be honest, I didn't really think it was too loud at all. I actually really like the sound output. The main reason why I ended up getting a new exhaust was because the cat in my stock front pipe was pretty much gone and that was the only remaining piece of restrictive stock exhaust I had left to replace... I figured if I get a new front pipe with a 3 inch diameter, I may as well complement it with a 3 inch exhaust.
Thus, I saw the JDL front over pipe. There weren't really any other 3 inch front pipes, other than I think nameless makes one. I really liked the vband connection with the JDL. Same thing with the Perrin catback. What I noticed from videos was that the 3 inch exhaust with a catless header was way too loud and my current setup was already on the louder side... so hopefully with what I have on order shouldn't be too much louder than what I have already.
As soon as I get everything and installed, I'll probably be posting sound clips to compare the differences with my sound measuring mic.
Old 01-17-2017, 06:47 PM   #8
TilesMeague
TilesMeague's Avatar
Drives: 2013 SSM BRZ
I got a tomei EL paired up with my 3 inch perrin catback over the summer and it's been great. Warmed up it's nice and loud and for my long trips between the bay area and phoenix for school it only dulls my hearing for an hour or so that's 80 mph cruising with the seats down though. You'll love it!
Drop several gears and become slightly further away
Last edited by TilesMeague; 01-17-2017 at 06:48 PM. Reason: forgot to specify which part of my exhaust is perrin
TilesMeague is offline   Reply With Quote
Old 01-18-2017, 12:20 PM   #9
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
nice man! I can't wait until my new exhaust set up gets here.
Old 01-22-2017, 03:02 PM   #10
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
JPM Goodies came in today. Thanks FT86SpeedFactory!
Old 01-24-2017, 09:08 PM   #11
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Perrin 3" Resonated CBE and JDL Ultra Quiet Over Front Pipe
All I can say is wow. All this stuff is amazing quality. JDL especially blows me away with their welds. Can't wait to put this stuff on. Invidia N1 will be up for grabs once it's taken off and the tomei overpipe with o2 bung.
Perrin
JDL
Old 02-06-2017, 02:09 PM   #12
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Finally got some decent weather to install the exhaust!
JDL Ultra Quiet Over Front Pipe and Perrin 3 Inch Resonated.
I was worried about the clearance since it is a 3 inch pipe. Probably a few mm to spare. This is the overpipe of JDL. I honestly thought it was going to vibrate and rattle against the car, but not one noise. JDL makes great stuff.
The Following User Says Thank You to pgranberg11 For This Useful Post:
Hicklinc (01-25-2020)
Old 02-13-2017, 10:52 AM   #13
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I'll be selling my Perrin exhaust soon. I feel like it wasn't loud enough so I went and grabbed a Tomei 80R. Feel free to PM. It's still so new, I have all the stickers, license plate frame and accessories that it came with when it was shipped.
Old 02-13-2017, 11:06 AM   #14
jasonojordan
Drives: 2013 satin white brz limited
Nice welds on the JL stuff. Some of them welds on the Perrin stuff are not as clean as I would of expected for the price.
jasonojordan is offline   Reply With Quote
Team BRG build - 8R6 FRS 8R6 Member's Car Journals 92 08-09-2017 08:33 PM
GridLife 2015 Shark_Bait88 Great Lakes 0 05-11-2015 04:07 PM
Pete's Perrin Vortech build thread Pete Member's Car Journals 91 06-04-2013 02:38 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
