Old 02-10-2017, 08:05 PM   #4439
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Originally Posted by LOLS2K View Post
Appreciate it, thanks!
Joesurf79 is offline   Reply With Quote
Old 02-10-2017, 08:38 PM   #4440
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
https://www.beastronix.com/products/...e-pedal-dance/
https://www.beastronix.com/shop/
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 02-11-2017, 09:43 PM   #4441
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
D'oh! I put the RCE yellow springs on in December... Maybe I need to bump up to stiffer springs. And at that point, my dampers are likely overpowered?
Photo is of a car lifting its inside front wheel in the Toe at the Glen at 68 MPH.
Front Spring Rate = 1598#. Front Bar = 38mm with six adjustment holes; bar is set on 4th stiffest hole.
So, the front end of this car is extremely stiffly sprung, and it's still lifting the wheel. It was a non-issue as far as driving the car fast.
dradernh is offline   Reply With Quote
Old 02-11-2017, 09:55 PM   #4442
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
Front wheel lift on those cars is extremely common. Chassis flex and softer rear springs with that huge front bar play more of a factor than the front springs.
trippinbillies40 is offline   Reply With Quote
Old 02-11-2017, 10:07 PM   #4443
dradernh
You nailed it.
Any thoughts on Joesurf79's query?
Old 02-12-2017, 01:03 AM   #4444
trippinbillies40
Drives: '22 WRB
You nailed it.
Honestly no, sorry I'm genuinely surprised he's lifting a wheel up front outside of jut pounding off of curbs. My car never lifted a wheel on track unless I bounced off of curbs.
That having been said, I agree that I wouldn't worry about it too much. A 20mm front bar on soft and a 16mm rear bar would probably solve the lift.
Also, if it's really rolling over that much, you probably need more than 3 degrees of camber up front. 3.2-3.4 probably on that setup. Just a guess though.
Old 02-12-2017, 10:09 AM   #4445
Joesurf79
Joesurf79's Avatar
Appreciate all the feedback guys! Looking at the lift on that beemer, I now think that mine might be much ado about nothing. This is the pic with the wheel lift that got me curious.
Old 02-12-2017, 10:51 AM   #4446
trippinbillies40
Drives: '22 WRB
Looks uphill and on camber which will also plant a ton of extra grip and make the vehicle more susceptible to lifting a wheel. I don't think you have anything to worry about!
Old 02-12-2017, 10:59 AM   #4447
Pat
Pat's Avatar
Drives: 2023 BRZ
Setup on E36s is way different than ours. I wouldn't try to apply too much from those to the BRZ platform.
Old 02-12-2017, 11:45 AM   #4448
dradernh
While it's not super easy to read, the photo looks to me like you've still got ~2/3 of your RF tire at least kissing the pavement.
OT, but the stiffness of that particular E36 is an extremely unconventional setup for the chassis. It was built for pros and won the 1998 Speedvision GS championship with Borcheller and Pilgrim driving. (Speedvision became Grand-Am, which became today's Continental Tire SportsCar Challenge.)
<end OT>
Old 02-12-2017, 12:34 PM   #4449
cjd
cjd's Avatar
Drives: 2017 BRZ
Yup. The shadow angle makes for an easy mis-read, note the rear tire has sunlight reaching all the way to contact patch, so does the front, but because of the under-car shadow proximity it looks like its lifted, but it isnt. I'd say even 80% contact RF still.
C
Old 02-12-2017, 08:15 PM   #4450
Joesurf79
Joesurf79's Avatar
C
Ah, I see what you're saying! Zoomed in and out a bunch and now I agree, it's an optical illusion almost. Car feels great to me as is, then seeing that, I thought it would feel better if all the wheels were on the ground haha! Thanks for the catch guys,
Less worry, more seat time it is.
Old 03-06-2017, 11:08 PM   #4451
JoeC
Drives: Subaru BRZ Limited
I just bought a set of Maxxis RC-1 to run on dedicated track wheels. I do HPDE and would like to maximize the life and grip of the tires. I've read about a method of initially putting one solid heat cycle in them and then letting them sit for a minimum of 24 hours. To do so I'd sacrifice part of one session and then have to run my street tires for the rest of the weekend.
Other things I've read indicate that it doesn't make much of a difference. What are your thoughts? should I do this single heat cycle method or just run them all weekend?
JoeC is offline   Reply With Quote
Old 03-07-2017, 03:53 AM   #4452
CSG Mike
CSG Mike's Avatar
It doesn't matter for the RC1.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
