#211 | |
That Guy
Drives: 2013 asphalt FRS MT
#212 |
Drives: Asphalt Scion FR-S
Negative ghostrider Sent from my iPhone using Tapatalk
2013 Asphalt HRI Tuned-K&N DropIn-Tomei UEL-Tomei OP-Invidia FP-Nameless Muffled Trackpipe...and corn
#213 |
Drives: 2013 FRS Whiteout
I've seen the engines for $3000 but transmissions are all over the place, I wish I could buy them in bulk and be able to include them in the price but it's too variable to do so. You can save a few dollars here and there when piecing a kit together, example, this car has a $1700 precision turbo but it could be a $700 borg warner, it has a custom intake manifold that we sourced for $900 and modified, but it could be stock. You could get a $500 clutch instead of a $900 clutch. But the end result will vary and I don't know about you but if I'm going this far into modifiing the car, why do things twice?
#214 | |
That Guy
Just to be clear, I wasn't trying to nickle and dime the price. I just honestly had no idea. Also, that's about $40000 CAD. Which is WAY outside of my budget for car mods. I'm just here for the porn, wet dreams, and to learn.
#215 |
Drives: 2017 WR BLUE BRZ
#216 |
#217 | |
Drives: Grrrr
$25k for a budget swap. With an open ended completion time. One year plus and counting. OK |
#218 |
Drives: 2JZ FRS
Well, the car is done as well as all the r&d and electrical work. So now that everything is finished it wouldn't take anywhere near that long to repeat. That price includes all labor, you can obviously do it yourself. It also includes a car that does every single thing a stock frs does, not a ghetto swap. Can you do it cheaper? Of course. Will it be crude? Probably. The amount of time we spent with the electronics package is well worth it. The capabilities of the ecu are endless and the car has every oem feature, some even more refined than oem.
#219 |
Could literally knock this swap out in a month if all the parts were present. Oh and all the money from the customer would have to be present. Probably 2 weeks in reality. Who's next ?
#220 | |
How much extra fab work would be needed if this is being done in a garage? I remember reading that you had to modify the CX mounts? Sent from my iPhone using Tapatalk
#221 |
There's some drilling for that. The tunnel has to be clearanced, the trans mount should be welded for sturdiness, the shifter opening must be modified, the core support has to be modified, the firewall needs some adjustment,it's not just slip it in there affair.
#222 | ||
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
#223 |
Drives: 2001 Impreza 2.5 RS
except cruise control and emissions monitoring.
Colin Beck
#224 |
Drives: BRZ + Ducati M796
The 2jz can obviously handle tons of power. The r154 can hold over 500whp-700hp from what I read. Is the rear end a weak link at those power levels? How much more is the V160?
Just curious, is this a swap people do because they don't want an old Supra or can't find one or just really like the 86? Because this and a car is like $50k+. Seems like buying a Supra would be cheaper, or dropping a 2jz into something else would be cheaper. It is cool n all but just curious. |
| Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 08:53 AM |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| WTB A/T BRZ/FR-S CA Budget 21k | Euan | Want-To-Buy Requests | 4 | 07-20-2015 11:50 PM |
| $2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 11:23 AM |
| There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 08:14 AM |
