Old 01-20-2015, 04:06 AM   #1
ck-GT86
ck-GT86's Avatar
Drives: '13 Raven FR-S, MT
Smile Reverse Bar Brake/Light Mod - Nsidius Industries Harness
I've been searching around for a harness to turn the reverse bar into a functional light. Browsing around the forums, I found one other harness that yes, does allow for (3) different lighting methods, but I wasn't fond of idea of having to splice wiring.
A quick Google search brought me to Nsidius Industries, claiming to have a direct plug-n-play harness that'll do exactly what I've been looking for. Frankly, never heard of the name, they've never been mentioned from what I've seen on the forums. So I dug a little deeper; I was pleasantly surprised to find they were only a couple of cities away. Sweet.
Sent a few emails back and forth...spoke to Jorge (who runs Nsidius) and met up with him to get the harness.
In short, I'll say this: the harness is top-notch. All the wiring is heat-shrinked, uses OEM connectors, requires no splicing, retains all factory wiring, and most of the instructions are easy to follow.
Here is the link to their harness: http://www.nsidiusindustries.com/pro...t-wire-harness
I opted to have a "custom" harness so that the light functions only as a rear-fog light. It's considered custom because the standard harness functions as a rear-fog light whenever your lights are turned on, but also it illuminates brighter when the brake pedal is pressed. In my opinion, three brake lights is enough already -- a fourth located below the tails is a bit overkill.
Follow my guide below as I discovered a few tricks along the way.
Harness - neatly packaged
Harness - up close, look at the quality
Reverse Bar Removal
- no need to jack up your rear end, I did this having Sportlines installed (it was a tight-squeeze though)
- there are (2) black clips that hold in the sides
- (2) bolts screwed into the top, size 10 socket
- once clips and bolts have been removed, wiggle the light backwards towards the front of the car. poke and pry up the two black clips from the rear (as seen below). pop it out
Reverse Bar Removed
Flip Reverse Bar Over
1" Washer
- the instructions call on for a step drill bit, I dont have one so I improvised using a 1" flat washer and a Dremel
Trace w/Sharpie
Cut and Sand
Notch
- notch a slit for the harness using a mini-filer. I had to go a bit wider in order to get the harness to fit
Twist on Harness
Wire Routing
- might be a Subaru thing because I could not find the grommet in the instructions to route the wiring through on my FR-S.
- found a different grommet located underneath the plastic around the trunk latch
- remove plastic trim, held in by (3) clips
- remove grommet
Wire Routing (continued)
- feed wire up through rear bumper to grommet located underneath the negative grounding wire
Cut the Grommet and Reattach
Plugs
- the harness has (2) OEM plugs. One end needs to plug into the factory wiring, and the other connects from the harness to the tail-light
Grounding
- the instructions say to connect the ground wire from the harness to the nut that holds the tail-light in.
- use a long 8 socket to remove the nut
- feed ground wire through, tighten down
Gorilla Tape
- if you're paranoid like me, go ahead and tape the grommet you cut to feed the wire through. I used a few strips of Gorilla tape -- it shouldn't come off
Testing
- flick the lights on to test functionality before you reinstall
- step on the brakes if you have a standard harness to see if the lights sync
Reinstalled
On with Reverse Lights
Overall it took about an hour to do. Simple and safe install, you won't be disappointed.
.ck
|| My Build Thread ||
ck-GT86 is offline   Reply With Quote
The Following 5 Users Say Thank You to ck-GT86 For This Useful Post:
HATED1 (01-20-2015), Jolaessss (01-22-2015), Kiske (01-23-2015), Nails (06-28-2017), SkAsphalt (01-22-2015)
Old 01-20-2015, 05:48 AM   #2
HATED1
HATED1's Avatar
Drives: 86
What type of bulb comes with it?
HATED1 is offline   Reply With Quote
Old 01-21-2015, 09:35 PM   #3
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
Nice write up. I installed one on my car too and love it.
The bulb is a standard bulb not an led but its plenty bright
Sent from my XT1254 using Tapatalk
AllStar0419 is offline   Reply With Quote
The Following User Says Thank You to AllStar0419 For This Useful Post:
HATED1 (01-22-2015)
Old 01-22-2015, 01:52 PM   #4
NSIDIUS_Industries
Drives: WRB BRZ
Great write up christian! Yes, its a standard dual filament 3157 Bulb. It is bright and really no need to go with an LED
NSIDIUS_Industries is offline   Reply With Quote
The Following 2 Users Say Thank You to NSIDIUS_Industries For This Useful Post:
ck-GT86 (01-22-2015), HATED1 (01-22-2015)
Old 01-22-2015, 02:23 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Only benefit of the LED is low energy demands..in case you wire it to a switch and forget to turn it off...which...a friend.....has done in the past...yes a friend...
The Following 2 Users Say Thank You to SkAsphalt For This Useful Post:
Old 01-22-2015, 11:27 PM   #6
NSIDIUS_Industries
Drives: WRB BRZ
^^Correct, no worries with this kit as its tied into the tail light circuit and will only turn on when the tail lights are triggered on.
Old 02-10-2017, 09:24 PM   #7
NSIDIUS_Industries
Drives: WRB BRZ
bump! We have found a few tricks to do this install without taking out the reverse light assembly if done with a step drill. Takes us less than 30 min with a couple of tools.
NSIDIUS Industries Automotive Goods
www.NSIDIUSIndustries.com
brake light, light mod, nsidius, reverse bar
Reverse wiring harness for amp pseudo Electronics | Audio | NAV | Infotainment 1 10-26-2014 02:17 PM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
FS: Rear Reverse / Fog light Delete with Harness taimysho0 Exterior Parts (Aero, Lighting, Etc.) 13 06-03-2013 11:29 AM
Evolution Industries Light weight Flywheel :) 20valvewynn83 Engine, Exhaust, Transmission 6 12-14-2012 05:35 PM
