Old 02-09-2017, 02:50 PM   #1
allowe
allowe's Avatar
My car after the accident
I've been in an accident last month. I got my car fixed and so far it's good.
2 things I've noticed:
[IMG]https://uploads.tapatalk-cdn.com/20170209/1b59f2621bb1d03c185***e4e08aa62a.jpg[/IMG]
Is there usually a gap this big between the tail lights ?
Mxp exhaust. Anyone have one? Is it unequal like that? I found the rubber hinges moved almost off the exhaust. I put them back in properly. The exhaust sounds fine and the same but I can't remember if it was like that before or not
Thanks for reading my post
allowe is offline   Reply With Quote
Old 02-09-2017, 04:23 PM   #2
burningjello
burningjello's Avatar
Drives: 2016 FR-S
The Taillight gap is not normal as far as I'm aware.
burningjello is offline   Reply With Quote
The Following User Says Thank You to burningjello For This Useful Post:
allowe (02-09-2017)
Old 02-09-2017, 04:27 PM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I don't have that taillight gap on mine but as far as exhaust tips go, that's fairly common for them to be slightly off, I've even seen OEM tips crooked.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 2 Users Say Thank You to 8RZ For This Useful Post:
allowe (02-09-2017), flyboy (02-13-2017)
Old 02-09-2017, 04:32 PM   #4
allowe
allowe's Avatar
Holy crap can anyone kindly send me a picture of theirs? So I can go after my body shop. And the exhaust is more to the side that's normal the middle part of the exhaust if u see isn't centered too. Thank u both for ur input
Old 02-09-2017, 06:24 PM   #5
burningjello
Drives: 2016 FR-S
I can take a picture of mine in an hour.
Old 02-09-2017, 06:25 PM   #6
allowe
allowe's Avatar
Thank you !!
Old 02-09-2017, 07:03 PM   #7
Thank you !!
Watch they don't try to "fix" that by just cranking the bolts on the housing down tighter. You will end up with a badly cracked and leaky housing if they do.
Old 02-09-2017, 07:19 PM   #8
allowe
allowe's Avatar
You always find a way to make me more paranoid thank you. Lol just kidding but in all seriousness, you're probably right. If it's just cosmetic, I'm fine with leaving it the way it is but if it's Guna cause water to go maybe inside my car or cause rust anywhere, I'm Guna be after them until they fix it properly. Overall, the car is good... aside from the trunk looking a tiny bit darker than the body panel but it's blended well with the whole car body... Could be dirty... I guess
Old 02-09-2017, 07:48 PM   #9
allowe
allowe's Avatar
Thanks a lot eh! I looked up photos of the exhaust and the centre part is usually that crooked with all mxp performance exhausts! As for the tip, I'm Guna open it and try to bend it a bit to straighten it out
Old 02-09-2017, 08:00 PM   #10
Impureclient
Drives: 2015 FR-S
For taillight fit reference.
The Following User Says Thank You to Impureclient For This Useful Post:
allowe (02-09-2017)
Old 02-09-2017, 08:03 PM   #11
burningjello
Drives: 2016 FR-S
Pm'd images to you
allowe (02-09-2017)
Old 02-09-2017, 08:07 PM   #12
Glad you got your car back, all fixed up......
As far as the suspected "gap" between the tail light housing and the body, as long as it doesn't let moisture in ...... no problem. If it bothers you, Bubba suggests you lay a bead of clear silicone sealer around that part of the tail light.
As far as the tail pipes ....... how much time do you spend looking at the back of your car .... ?? If you don't think they are even, Bubba suggests you stick a length of water pipe in each one, have a friend heat up the tail pipe at the last bend, and bend them till you're happy.
These jobs are 3 beer jobs, two for you and one for your buddy with the torch.
allowe (02-09-2017)
Old 02-09-2017, 08:10 PM   #13
allowe
allowe's Avatar
Pm'd images to you
thanks I got them !
Thanks for that photo!
Jeez there is a huge gap. Again I don't mind I just don't want to have rust because of that gap. I'm Guna spray them red pretty soon (probably next week). I'll take them off and see what's up
Again thanks to both of ya!
Old 02-09-2017, 08:14 PM   #14
burningjello
Drives: 2016 FR-S
thanks I got them !
Happy to help!
allowe (02-09-2017)
My accident :( afsefo Cosmetic Modification (Interior/Exterior/Lighting) 16 02-12-2014 12:08 PM
Got into an accident Toadal Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 25 11-16-2013 04:18 PM
First accident in FR-S Xinshadow Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 08-02-2013 02:35 PM
accident #2 Linniea Scion FR-S / Toyota 86 GT86 General Forum 60 03-25-2013 01:09 PM
