#15 |
Hmmm, very interesting. Sorry, Shaky. That's a bummer.
Hell, I didn't even know oil pump failure was a thing. Learning new stuff every day. Thanks for sharing.
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Decay107 (02-09-2017), extrashaky (02-07-2017) |
#16 | |
Drives: BRZ DGM Limited
As time goes on if we see the dealers fixing these engines more willingly than they did at first, I believe that will be a signal that Subaru is realizing there is a design issue with this engine. But of coarse they will never tell you that. |
#17 | |
| The Following 6 Users Say Thank You to Tcoat For This Useful Post: | DAEMANO (02-07-2017), extrashaky (02-07-2017), jcw99 (02-08-2017), strat61caster (02-08-2017), userjack6880 (02-08-2017), VerusEric (02-08-2017) |
#18 |
Off Topic
Plus, while some have failed on high hp engines, others have failed on stock engines, and many more engines have held with multiple hundreds of hp above OEM. It's more likely that the failures just happened to be on the weak end of manufacturing tolerances and those owners got the short end of the straw.
#19 | |
Drives: 2014 BRZ Limited
It's actually a little more interesting if I'm the only one who ever sees this. Who would really care about another blown engine post if 50% of them were doing it? |
#20 | |
Hope they build on to your new short block nice & clean so it doesn't weep. fingers crossed for you.
| The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
#21 |
Drives: t
it was not a miss-shift?
#22 |
A miss shift isn't going to blow an oil pump apart. Although you did hit on the suspected cause of some of the blown engines even if the owner insisted that they never did.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (02-08-2017) |
#23 |
Drives: '13 BRZ
Interesting to see this fail at OEM power levels. The only other oil pump gear failure that I am aware of being documented on the forum is a spitfire's build thread, that shattered somewhere around 700hp. I don't recall the rev limit on the car but I believe he did head work as well. Link below.
http://www.ft86club.com/forums/showp...&postcount=250 I feel like this would just be a mad mis-shift or extremely poor luck with a defect in manufacturing... Either way, good luck OP. |
| The Following User Says Thank You to BRZoomTX For This Useful Post: | Sportsguy83 (02-08-2017) |
#24 | |
I can think of no reasonable scenario in which one can mis-shift a stock BRZ upshifting from first into any other gear that would damage the engine. |
| The Following User Says Thank You to extrashaky For This Useful Post: | Clipdat (02-08-2017) |
#25 |
that elusive 0.5 gear
#26 | |
Also...
Obviously that engine was under a lot more stress, so you could expect more risk of failure in general. However, intuitively I would not expect the oil pump gear to be under significantly more stress in a boosted application unless he was revving really high. Even then, I wouldn't expect it to come apart like that. I have a four dimensional transmission. I downshift into 1/2 to bump the car sideways. |
| The Following User Says Thank You to extrashaky For This Useful Post: | Tcoat (02-08-2017) |
#27 |
I need this.
| FS: Cusco AOS & Dw65c Fuel Pump 50 Miles ONLY | ScionFR-S | Engine, Exhaust, Bolt-Ons | 0 | 08-06-2015 09:25 AM |
| Rear window shattered by itself | superleggera | Issues | Warranty | Recalls / TSB | 36 | 03-29-2015 05:06 PM |
| Shattered passenger mirror | ninch | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 09-26-2013 05:30 PM |
| Passenger window shattered. Warranty? | eckoflyte | AUSTRALIA | 15 | 03-26-2013 09:01 AM |
| Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) | R2RO | Issues | Warranty | Recalls / TSB | 3 | 02-04-2013 10:06 PM |
