Old 06-28-2012, 08:47 AM   #57
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by WingsofWar View Post
what kind of powerband gains are you targeting Don? Care to share your chosen compressor map?
I ask, because at the moment im talking with lots of turbo builders for this particular engine..and everyone's thoughts are on very far ends of the spectrum. It would be nice to know that someone out there is trying to build a purchasable turbo kit, built, priced, and proven for the average blue collar Joe, which the FRS-BRZ target market was originally made for.
Id be a shame to see shops miss the mark on this car because its easy to get caught up on the idea that customers want POWER and they will pay a premium for it. When i fear this isn't the case for this particular car.
Anyway, keep up the good work! cant wait to see more pictures, especially your chosen turbo location and compressor outlet clocking solution.
The turbo in the picture is a Garret GT28R. Its considered to be the "Disco Potato" line. If this turns out to be to laggy i'll switch to something smaller. In this particular size we can upgrade from 350hp capable to nearly 450hp with some of the new GTX lined turbos. However I believe that the standard GT will work far better at lower boosts than the GTX line. Same as the EFR stuff. Just requires you to work them to hard to get the results. I don't think this kit will be to far out of reach. I'm going to use the stock header. So no crazy expenditures there. I'm planning on fitting this behind the engine. Front mount intercooler is only up to 350hp at this time w/out cutting. Sure we'll make larger turbo kits, but I dont think this car needs more than 350hp. Its 160hp now and a blast to drive. I can't imagine what doubling the power to the ground will be and having a flatter torque curve from 3k-4k and rising on up. It will be some sort of a monster. We have 130-140ft lbs now peak. And no where near that in the torque valley. We should be able to get north of 200ftlbs in the valley I would think.
Now for those people who want 600hp, No problem, I can do this all the same, but we need to start somewhere and figure out whats going to work reliably for the time being.
-Don
Don@Accelerated is offline   Reply With Quote
The Following 8 Users Say Thank You to Don@Accelerated For This Useful Post:
Guff (07-01-2012), jedibow (06-28-2012), JiB (06-28-2012), Longhorn248 (07-06-2012), TRD_07 (08-01-2012), ultra (06-28-2012), usptwins (04-19-2013), WingsofWar (06-28-2012)
Old 06-28-2012, 08:54 AM   #58
sirus
86 Owner
sirus's Avatar
Drives: White GTS 86
On the road. Check your mirrors!
sirus is offline   Reply With Quote
Old 06-28-2012, 09:13 AM   #59
sdiver68
sdiver68's Avatar
Drives: 2013 BRZ Limited
-Don
I think there would be a market for a very modest approach...250whp, flat TQ curve, reliable as hell for track and/or Auto-X use and proportianally lower cost than the more ambitious kits.
sdiver68 is offline   Reply With Quote
The Following User Says Thank You to sdiver68 For This Useful Post:
Slartibartfast (06-29-2012)
Old 06-28-2012, 09:24 AM   #60
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
Really nice to see that this is focussing on "no cut" for a basic kit. That's very important for us Australians, the moment we take a saw to something we have to get it engineered (prices go from $1000 upward, realistically). Also, most engineers don't seem to know that much about cars that don't involve enormous V8s. Trying to find one that'll approve little turbo projects is hard.
Nezz is offline   Reply With Quote
Old 06-28-2012, 09:55 AM   #61
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
-Don
Yes please.... Subscribed...
FT-86GOD is offline   Reply With Quote
Old 06-28-2012, 09:58 AM   #62
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
watching this
cant wait to see the finished product!
Kuzuri is offline   Reply With Quote
Old 06-28-2012, 02:05 PM   #63
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
I have something that I'm working with. I'm really not going to take any control from the ecu. The direct injection and the port injection work with each other and I see many issues with trying to fool with them. I'm just taking it one day at a time. Honestly I would love to just remove that direct injection bolshit!
Larger port injectors? and maybe an FPR?
Or are you planing on running a piggyback? My concern with running a turbo on this car isn't the fuel (mostly due to direct injection) but ignition timing, how do you plan to address the ignition timing?
If it is classified I understand...
Thank you,
G
jedibow is offline   Reply With Quote
Old 06-28-2012, 02:13 PM   #64
jedibow
Picture of the peashooter chosen to do the job.
This is a Dual Ball Bearing Garrett Unit. Comes w/ the internal gate, but dont' know that it will end up that way.
-Don
That wouldn't be a GT-2871 would it
Old 06-28-2012, 02:21 PM   #65
jedibow
-Don
There will not be any lag at all, I had one of these on my sentra, and I reached full spool by 2800 RPM's around 16psi, transient response was amazing, and top end pull was decent.
Good choice on the turbo! the EFR line would be to large (read no useable boost until past 4000 RPM) and they do not like small boost pressure ratios, until we have a bottom end option to say run 20 psi plus they shouldn't be considered...
G
Old 06-28-2012, 04:23 PM   #66
Don@Accelerated
That particular turbo is a GT2860RS. The smaller of the two.
Old 06-28-2012, 04:24 PM   #67
Don@Accelerated
I'm currently working on that. Ill make it known when its sorted out.
-Don
Thank you,
G
Old 06-28-2012, 04:41 PM   #68
xcelir8brz
Current AP customer, now subscribed. So, Don, are you saying, this will be 30WHP gain on top of your exhaust system or with it?
xcelir8brz is offline   Reply With Quote
Old 06-28-2012, 05:59 PM   #69
slow_frs
Drives: turbo scion tc
G
?? efr are instant spool people switch their sc colbalts to efr turbos and make 20 psi all day instantly, and no im not a cobalt fan i dispise them
slow_frs is offline   Reply With Quote
Old 06-28-2012, 07:22 PM   #70
jet86
Mad Sciontist
jet86's Avatar
Drives: gt86
If the disco spud is too laggy I'd suggest to go with the GTX2863r. A size smaller but more efficient and same hp rating. I highly rate the new GTX turbos. All I ever use these days.
jet86 is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 11:24 AM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-03-2012 11:24 PM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 07:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 08:14 PM
