Old 02-05-2017, 01:23 PM   #141
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Originally Posted by Mad1723 View Post
From what I'm reading, Flex fuel first if you have access to E85. HBP will increase the power output dramatically and needs higher octane anyway, so start with E85 first. It should be plenty more power from there.
Also isn't the power gain from E-85 a bit safer of a move than an HBP. From what I've read, and correct me if I'm wrong, the HBP is far more likely to cause a rod failure with the big increase in TQ.
Silverfox is offline   Reply With Quote
Old 02-05-2017, 04:43 PM   #142
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Yes, this is what I heard too. E85 gives good gains while maintaining safe power levels, HBP gives huge gains at the risk of grenading stock transmissions and engines.
Mad1723 is offline   Reply With Quote
Old 02-24-2017, 04:59 PM   #143
eherschend
VitViper clarifies on his blog.
http://blog.vittuned.com/jackson-rac...ft-86-fr-sbrz/
eherschend is offline   Reply With Quote
Old 02-24-2017, 05:26 PM   #144
Mad1723
Mad1723's Avatar
Well that was a really nice read, thanks for that. As I'm shopping for the C38 kit, that's good to know!
Old 03-07-2017, 04:17 PM   #145
Shady195
Drives: '13 10 Series FRS #1203
Let me get in on this...
SBD V2 Turbo kit (original 12 blade CHRA)
Ported Turbo
2.5" Over/FP
3" HKS Hi Power Single Exit
DW 700CC Injectors
DW 300 340LPH Pump
Moto-East Flex fuel kit
Tuned by Moto-East on their DynoJet
Base Tune 270WHP (Honestly felt identical to my SBD with Openflash Tune)
~300whp on 93
~380whp wit E57
~320WHP at a hard set 10PSI on E57 (Mainly for when I go drifting)
[IMG]https://lh3.googleusercontent.com/5U0BX9XRd5xKpXrq6yQjcTX4je9XpWDXY1jz84SjcTh3XgCbHE 8wrn10lTIIfIML0-K3RzSffgsCzZcXGvegL0zh_3vCd4PGlRXUF3WqB_QaWz7HRfqw UCjvvOCLsp0U96B_sARIwUmUmDvpzbarAk5Iq46pDdhTSBxly0 tzjWMH4IZ7BIeQ61sb5ia1KhhaOczaO4Dw5RNVdK5TWFu1L9Jo um7dPk8oSZHk75C5B8olQoh-0kNep45trJmIckN9TF9djp8QAnAHtSJJY1G1p6eAfuP5Ua3bRl citD6jme5_LrCv-8XFit9ajT9_9e9kE8JT87dP8Qa0cdODEKpaoKyVDGHnbxG38es DnDkEcldu2AkhOTyk9j2YtZ1NSGLIj***S6ZtPwi_nfYzGNY24 c3afacihkr9BqEjTePtSocDO0I9nOWfXVsUURe6ShFjSdhadpW WE8bB7l8BFaMZdKmwSSOZjH23R6bwRe7zp3oQXEdT-LnoH25HjfkjxCTv19ogz6dl1aPFGrEgbYDMIBNAmPBDw2AJefq hOrME4eU4yviqJX5a0bihSVJOw8FuvRCcs_-9gI5Aga_Xlt3qhsd7eFu--oXX5aMhN7Cuyb5TbjwDe_y7tlsKBsDJe4QBdQlb9YpaFgzbSLH c7-ypvvJa6nDwODSFur73BdLo-Q=w1092-h871-no[/IMG]
Shady195 is offline   Reply With Quote
Old 03-10-2017, 03:27 PM   #146
eherschend
312 HP
232 TQ
Tuned by Bill from Delicious Tuning
C38 kit
HKS EL
Greddy Axle back
Flex Fuel
Grams Throttle body
Car feels awesome!
Old 03-13-2017, 12:02 PM   #147
Full_Throttle_86
Drives: 2013 Hot Lava FR-S
FI Dyno thread
Full Blown base kit
57 trim turbo
2.5 over pipe
Invidia cat less front pipe
Buddy Club spec 2 cat back
On 93
Tuned by Graham at Boosted Performance tuning. On the stock clutch and didn't want to push it much farther.
Full_Throttle_86 is offline   Reply With Quote
Old 03-16-2017, 01:35 AM   #148
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
SME Turbo Kit (Garret GTX2867r)
3 inch turbo back catted
Greddy EVO GT
Running 98 RON pump gas
softgrip is offline   Reply With Quote
Old 03-18-2017, 09:48 AM   #149
Shady195
Not sure if its just a product of the kit your running but that curve looks like poop..
Hopefully any revisions he makes smooths that out.
Old 03-18-2017, 03:34 PM   #150
Amputechture
Drives: 2014 BRZ
The torque dip around 3,500 felt like absolute shit. If I upshifted and ended up in that range it felt dead in the water. No idea what he did to correct it but it feels great now, and my torque starts hitting hard at 3,800ish. Not a product of the JDL kit at all, my prior e-tune didn't exhibit the behaviors....nor does it right now fortunately. We were renting a dyno and it was a bit rushed to finish in time so what you see above is where he stopped at. All is well that ends well though, I should have an updated graph in a few months once I finish things off.
Amputechture is offline   Reply With Quote
Old 04-17-2017, 11:23 AM   #151
allmotorrex
allmotorrex's Avatar
Drives: 08 4x4 offroad tacoma/ raven fr-s
- P&L turbo kit with Precision ball bearing 5858
- Renegade 112 (e85)
- 3 maps (8 psi, 11 psi, 13 psi)
- 2.75" overpipe/catless midpipe, 3" Greddy RS single exit, 900 DW injectors, DW 65 fuel pump, flex fuel kit
- e-tuned by James Martin at HRItuning
319 whp/ 237 wtq @ 8 psi
341 whp/ 261 wtq @ 11 psi
386 whp/ 286 wtq @ 13 psi
allmotorrex is offline   Reply With Quote
Old 04-22-2017, 03:06 AM   #152
KDOS702
Drives: 2015 Scion FR-S
Jdl single scroll turbo kit with Garrett gtx3071r dual ball bearing turbo.
Built motor with 10:1 compression ratio.
Full 3" jdl piping (catless), with greddy revolution RS 3" single exit exhaust.
91 pump gas 😢.
316 whp
267 wtq
Dyno tuned by Dallin Brewer at Soulless Performance in Gilbert, AZ.
KDOS702 is offline   Reply With Quote
Old 04-25-2017, 11:23 AM   #153
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
Custom gtx3076 kit - currently on 93 octane and limited to <10psi (still on stock clutch).
Kit was seeing close to 400whp with E85 on another car.
It was also dialed back a bit for safety as this is a track car:
GTHachiRoku is offline   Reply With Quote
Old 06-14-2017, 05:01 PM   #154
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Stock engine with 2017+ Intake manifold
JDL V2 UEL Kit with Garrett GT2860rs (Disco Potato)
Delicious Tuning Flash N Go ( No revisions yet )
Delicious Tuning Flex Fuel kit
DW 700 CC injectors
Intake Pump
12psi on e85
JDLAutoDesign is offline   Reply With Quote
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
