Old 02-02-2017, 02:26 AM   #15639
ToyotaFan84
ToyotaFan84's Avatar
Drives: 2016 FR-S
Filled her up. The new TRD rims look great but the car isn't as tail happy as it used to be.
I was planning on stopping here, but the TRD louvers have caught my eye...
ToyotaFan84 is offline   Reply With Quote
Old 02-02-2017, 08:10 AM   #15640
Ashikabi
Ashikabi's Avatar
There may be new louvers on the market soon at an estimated cost far below TRD. There is a thread on here somewhere for it. I suggest you check it out before committing money
Old 02-02-2017, 02:45 PM   #15641
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Originally Posted by JNthe86 View Post
Did my first engine bay detail. I'll have to do it a couple more times to reverse 4 years of nastiness.
Looks great? What product did you use to get it so glossy?
MJones_RB is offline   Reply With Quote
Old 02-02-2017, 04:54 PM   #15642
Taka
Taka's Avatar
Drives: FRS
+1, what product did you use?
Taka is offline   Reply With Quote
Old 02-02-2017, 06:20 PM   #15643
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
ACT Clutch
Throwout bearing has been getting significantly worse over these past few months that it was finally time to replace it. Might as well do the clutch in the process!
Installed the SB7-HDSS ACT Clutch Kit along with a Velox Billet Clutch Fork + Pivot. Used Red Line MT-90 to fill.
Transmission now feels better than new
dhuang is offline   Reply With Quote
Old 02-03-2017, 01:12 PM   #15644
Teseo
Drives: frs
Hope i can join to hellaflush
Nah, just a little
Old 02-03-2017, 02:49 PM   #15645
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
Got my 2017 Aluminum Intake manifold all buttoned up!
Gearbanger is offline   Reply With Quote
Old 02-03-2017, 05:02 PM   #15646
arxm
Drives: 2013 FR-S, 2023 BRZ
ok guys, slight issue, my passenger window is a bit finicky as to when it wants to work and has left me driving home with the window down more than once this winter. Something I've noticed is that the window won't slide back up when closing the door so the door isn't properly sealed and I'm worried I'm gonna get water in my car and screw something up. The only indicator i have to a problem is that the window switch light flashes on the passenger door. I have some pics of how the window is seating and how it isn't fully closing. Do you guys know what I could be looking for, is it a relay, motor or maybe my window motor is gone?
I cant resize the pics rn so i put a link to my google photos with the pic in question https://goo.gl/photos/fR1G7cENLUsBmw4F9
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 02-03-2017, 05:31 PM   #15647
Ashikabi
Ashikabi's Avatar
Roll the window all the way down and hold in the button for a while. This "resets" the window
Old 02-03-2017, 06:37 PM   #15648
dhuang
dhuang's Avatar
Replaced spark plugs. Took 2 hours on a lift w/o having to raise the engine -- what a pain to do.
Plugs still look pretty good @ 65k.
Old 02-03-2017, 07:19 PM   #15649
arxm
I've tried the reset trick a few times, it works for a day or so but then does the same thing again and starts acting up
Old 02-03-2017, 07:24 PM   #15650
Ashikabi
Ashikabi's Avatar
Then I'm not sure. I don't know what causes it to forget that it's down
Old 02-03-2017, 08:15 PM   #15651
Cole
Not a troll
Cole's Avatar
Ordered a new shift boot and parking brake boot today
Cole is offline   Reply With Quote
Old 02-03-2017, 08:36 PM   #15652
arxm
no worries, ill keep digging
